    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 359.1k Views 54 Watching
    • cruunnerrC
      cruunnerr
      Hey mate,
      the way that will work in every case is to use a relay to interrupt the voltage for the pir.
      Then write two little bash files and execute them via cronjob.
      turn on relay with GPIO 7 and give the PIR voltage:
      gpio mode 7 out
      gpio write 7 1
      turn off the relay with GPIO 7 and interrupt the PIR voltage:
      gpio mode 7 out
      gpio write 7 0
      otherwise u could use if statement with a datetime check within the python script. something like this: https://stackoverflow.com/questions/10048249/how-do-i-determine-if-current-time-is-within-a-specified-range-using-pythons-da/10048290
      If i find some time, i will try to adjust the python script from this tutorial…
      • K
        Kecko
        Hey, big thanks for this tutorial!
        i want to use method 2.2 the PIR-Script.
        My Problem is: it looks like there is always a movement detected!
        i stuck on the point
        “You can check if your button works by simply typing python pir.py. Every time u move through the PIR or press the button it will show you several …
        End the test with “ctrl+c”
        It always print “…” for me.
        That means that there is a movement all time right?
        even if I disconnect the GPIO Pin there are all the dots…
        i Realy cant figure out what i do wrong in this case… i mean it is only copy and paste and i did it the third time right now. also tried the MMM-PIR-Sensor module… not happy with it.
        i realy dont know what to do now!
        • cruunnerrC
          cruunnerr
          Not much time, so here comes just a short think…
          1. You have two cogs on the pir. Move the time delay completely left or right (so it will just give a very short impulse).
          2. Set the Shutoff-delay in the script to 5 seconds (just to try)
          3. Try another GPIO…
          4. try a pull-up or pull-down resistor like used at thy button-method
          Bild Text
          K 1 Reply Last reply
          Reply Quote 2
          • K
            Kecko @cruunnerr
            @cruunnerr oh my god… i love you
            it was realy just the Time-delay Adjust!!!
            i turned it completly left and it seems to work now!
            but i have to say i must work with the command display_power=0 - display_power=1
            so if the hdmi turns off my display shows for 1 second no signal
            if the display turns on it shows HDMI1
            but thats fine… i guess it is a “problem” of the display itself.
            thank you for the fast and easy response
            your tutorial is realy great i love it. also a noob can work with it!
            maybe you should add a line with a tip for the Time-delay Adjust
            • K
              komodoteler @cruunnerr
              @cruunnerr Hello, My PIR works completely fine (with method #6, just turn black) but I also plan to build my mirror as floor mirror and wondering the same as @blebbens
              I tried your suggestion but unfortunately doesn’t seems to work. the screen is on instantly if motion detected. Any other suggestion?
                Magno99900
                Hey, so I’ve been trying to get this working over the past few days using method 2.2 (pir script) I’ve verified that monitor_on/off.sh works as they should as does pir.py when run from terminal. The problem seems to be that I’m unable to get the script to auto start on boot. Any suggestions would be greatly appreciated.
                • K
                  komodoteler @Magno99900
                  @magno99900
                  Make sure you run chmod - chmod +x pir.py
                  Then add it to startup:
                  1. run - sudo nano /etc/rc.local
                  2. Add this (above the “exit 0”): python /home/pi/pir.py &
                  3. Save
                  Reboot to test
                  M 1 Reply Last reply
                    Magno99900 @komodoteler
                    @komodoteler I’ll try again once I get off work, but i know I did chmod on pir.py and I currently have it in rc.local but I don’t currently have the “&” after it’s entry. When I looked at the first post it says to put it there but doesn’t display it in the code section.
                    Updated: Added the “&” still didn’t work, so I replaced the pir.py script that I was previously using and all seems to be great now. thanks again for the help.
                    • K
                      Kecko
                      hey guys,
                      i got another problem.
                      the script is working well but the python won’t start with booting my PI.
                      i don’t know how often i repeated all the steps. I am using the method 2.2 Using PIR-Script.
                      i also put this line in my rc.local:
                      • python /home/pi/pir.py &
                      anyone got an idea what i’m doing wrong?
                      EDIT:
                      Sorry I have just read the post of @Magno99900. So you just created a complete new .py script? i will try this later! Thanks so far :grinning_face_with_smiling_eyes:
                      • MarosM
                        Maros
                        I’ve just connected PIR sensor to my MM as written in step 2.1 Using PIR-Module
                        everything is connected MM is started but the screen is not turning off.
                        Can someone help me how can i check if PIR sensor is working and if it’s why the screen is still on ?
                        i’ve changed settings to
                        module: ‘MMM-PIR-Sensor’,
                        powerSavingDelay: 60 // (seconds) how long the monitor will be turned on
                        • MarosM
                          Maros
                          I found out that PIR sensor is ok.
                          i’ve created python script from this page ( https://tutorials-raspberrypi.com/connect-and-control-raspberry-pi-motion-detector-pir/ )and found out that i’ve switched Ground and 5V. I’ve corrected them and now when i execute : sudo python pir.py i get
                          There was a movement!
                          before there was nothing, so i guess PIR sensor is OK
                          but it’s still not working to turn off the screen.
                          • MarosM
                            Maros
                            OK everything is working after creating scripts from step 2.2 :)
                            • MarosM
                              Maros
                              is there possibility to turn off PIR at specified time ? f.e. from 9pm untill 7am it will be off so if there will be movement display will not turn on.
                              • cruunnerrC
                                cruunnerr
                                @Maros
                                Glad u got it working. :)
                                So u use the script from point 2.2 ?
                                Then u could kill the pir.py at 9pm and start at 7am via cronjob. With that u were able to define each day for itself :)
                                The command to kill the pir.py script is
                                sudo pkill $(ps aux | grep python pir.py | awk '{ print $2 }')
                                So the easiest way is to just edit your crontab. Try it like this:
                                1. nano killpir.sh
                                2. Write this into file and save with CTRL+X and Yes
                                1. chmod +x killpir.sh
                                2. sudo nano /etc/crontab
                                3. Write this into file and save with CTRL+X and Yes:
                                0 21 * * * /usr/bin/sh /home/pi/killpir.sh
                                0 7 * * * /usr/bin/python /home/pi/pir.py
                                So for example your crontab looks like this:
                                # /etc/crontab: system-wide crontab
                                # Unlike any other crontab you don't have to run the `crontab'
                                # command to install the new version when you edit this file
                                # and files in /etc/cron.d. These files also have username fields,
                                # that none of the other crontabs do.
                                SHELL=/bin/sh
                                PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
                                # m h dom mon dow user  command
                                17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
                                25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
                                47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
                                52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
                                0 21    * * *   root    /usr/bin/sh /home/pi/killpir.sh
                                0 7     * * *   root    /usr/bin/python /home/pi/pir.py
                                Didn’t try this solution at all, but hope/think this works :)
                                I would be glad about a feedback ;)
                                • MarosM
                                  Maros
                                  @cruunnerr ok thank you i’ll try it and let you know if it work.
                                  just one question is it not needed to start pir.py in background ?
                                  /usr/bin/python /home/pi/pir.py &
                                  • cruunnerrC
                                    cruunnerr
                                    cron will start the pir.py in background. The scenario will be like:
                                    Boot up magic mirror = starts pir.py via rc.local
                                    at 21pm = stops pir.py via cron
                                    at 7am = starts pir.py via cron
                                    from this on the circle is closed and cron will repeat this every day (in background)
                                    well… i think so… maybe i am wrong :/
                                    When u reboot the mirror between 21pm and 7am the pir.py will be active for sure until the next 21pm will be reached … ;)
                                    edit:
                                    it would also be possible to implement a while-loop in the pir.py script to check if it is between 21pm and 7am.
                                    But i never worked with that yet -.-
                                    maybe u can get what u want here or here or here
                                    • MarosM
                                      Maros
                                      ok i’ve checked and it’s not working fully.
                                      problem is with /usr/bin/sh /home/pi/killpir.sh
                                      there is no /usr/bin/sh only rsh
                                      edit.
                                      ok i’ve changed path to /bin/sh and now i get error :
                                      grep: pir.py: No such file or directory
                                      pkill: no matching criteria specified
                                      Try `pkill --help’ for more information.
                                      even if pir.py is running (i can see it in ps -ef |grep pir)
                                      edit ok i was able to fix it i’ve edited killpir.sh to
                                      sudo kill $(ps aux | grep python | grep pir.py | awk ‘{ print $2 }’)
                                      now it will kill process pir.py
                                      but problem is that even if this script (pir.py) is not running the mirror still turns on when there is movement and turns off after 30s no movement … strange
                                      • cruunnerrC
                                        cruunnerr
                                        When the pir.py isn’t running, then it isn’t this script which turns on your monitor.
                                        Do you have the MM-PIR module active?
                                        Please try to edit your rc.local and delete the autostart of the pir.py to see, if the monitor still turns on/off when there is movement.
                                        if not, then the pkill command isn’t working, which would confuse me, because i just tried it by myself on my mirror.
                                        via ssh i just entered the sudo pkill $(ps aux | grep python pir.py | awk '{ print $2 }')" command and my pir wasn’t working.
                                        and to your first problem, which u solved by yourself…
                                        u could also try to edit the killpir.py to this:
                                        #!/bin/bash
                                        then u should be able to just let your cronjob look like:
                                        0 21 * * * root /home/pi/killpir.sh
                                        • MarosM
                                          Maros
                                          Yes i’ve active mmm-pir module.
                                          I’ll try your solution and let you know
                                          Thank you ;)
                                          • MarosM
                                            Maros
                                            i’ve removed line from rc.local and mirror is still working as should (turn on when there is movement and turn off after 30s as set up in MMM-PIR module)
                                            • 4 / 9
