    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 359.1k Views 54 Watching
    • K
      Kecko
      hey guys,
      i got another problem.
      the script is working well but the python won’t start with booting my PI.
      i don’t know how often i repeated all the steps. I am using the method 2.2 Using PIR-Script.
      i also put this line in my rc.local:
      • python /home/pi/pir.py &
      anyone got an idea what i’m doing wrong?
      EDIT:
      Sorry I have just read the post of @Magno99900. So you just created a complete new .py script? i will try this later! Thanks so far :grinning_face_with_smiling_eyes:
      • MarosM
        Maros
        I’ve just connected PIR sensor to my MM as written in step 2.1 Using PIR-Module
        everything is connected MM is started but the screen is not turning off.
        Can someone help me how can i check if PIR sensor is working and if it’s why the screen is still on ?
        i’ve changed settings to
        module: ‘MMM-PIR-Sensor’,
        powerSavingDelay: 60 // (seconds) how long the monitor will be turned on
        • MarosM
          Maros
          I found out that PIR sensor is ok.
          i’ve created python script from this page ( https://tutorials-raspberrypi.com/connect-and-control-raspberry-pi-motion-detector-pir/ )and found out that i’ve switched Ground and 5V. I’ve corrected them and now when i execute : sudo python pir.py i get
          There was a movement!
          before there was nothing, so i guess PIR sensor is OK
          but it’s still not working to turn off the screen.
          • MarosM
            Maros
            OK everything is working after creating scripts from step 2.2 :)
            • MarosM
              Maros
              is there possibility to turn off PIR at specified time ? f.e. from 9pm untill 7am it will be off so if there will be movement display will not turn on.
              • cruunnerrC
                cruunnerr
                @Maros
                Glad u got it working. :)
                So u use the script from point 2.2 ?
                Then u could kill the pir.py at 9pm and start at 7am via cronjob. With that u were able to define each day for itself :)
                The command to kill the pir.py script is
                sudo pkill $(ps aux | grep python pir.py | awk '{ print $2 }')
                So the easiest way is to just edit your crontab. Try it like this:
                1. nano killpir.sh
                2. Write this into file and save with CTRL+X and Yes
                1. chmod +x killpir.sh
                2. sudo nano /etc/crontab
                3. Write this into file and save with CTRL+X and Yes:
                0 21 * * * /usr/bin/sh /home/pi/killpir.sh
                0 7 * * * /usr/bin/python /home/pi/pir.py
                So for example your crontab looks like this:
                # /etc/crontab: system-wide crontab
                # Unlike any other crontab you don't have to run the `crontab'
                # command to install the new version when you edit this file
                # and files in /etc/cron.d. These files also have username fields,
                # that none of the other crontabs do.
                SHELL=/bin/sh
                PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
                # m h dom mon dow user  command
                17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
                25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
                47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
                52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
                0 21    * * *   root    /usr/bin/sh /home/pi/killpir.sh
                0 7     * * *   root    /usr/bin/python /home/pi/pir.py
                Didn’t try this solution at all, but hope/think this works :)
                I would be glad about a feedback ;)
                • MarosM
                  Maros
                  @cruunnerr ok thank you i’ll try it and let you know if it work.
                  just one question is it not needed to start pir.py in background ?
                  /usr/bin/python /home/pi/pir.py &
                  • cruunnerrC
                    cruunnerr
                    cron will start the pir.py in background. The scenario will be like:
                    Boot up magic mirror = starts pir.py via rc.local
                    at 21pm = stops pir.py via cron
                    at 7am = starts pir.py via cron
                    from this on the circle is closed and cron will repeat this every day (in background)
                    well… i think so… maybe i am wrong :/
                    When u reboot the mirror between 21pm and 7am the pir.py will be active for sure until the next 21pm will be reached … ;)
                    edit:
                    it would also be possible to implement a while-loop in the pir.py script to check if it is between 21pm and 7am.
                    But i never worked with that yet -.-
                    maybe u can get what u want here or here or here
                    • MarosM
                      Maros
                      ok i’ve checked and it’s not working fully.
                      problem is with /usr/bin/sh /home/pi/killpir.sh
                      there is no /usr/bin/sh only rsh
                      edit.
                      ok i’ve changed path to /bin/sh and now i get error :
                      grep: pir.py: No such file or directory
                      pkill: no matching criteria specified
                      Try `pkill --help’ for more information.
                      even if pir.py is running (i can see it in ps -ef |grep pir)
                      edit ok i was able to fix it i’ve edited killpir.sh to
                      sudo kill $(ps aux | grep python | grep pir.py | awk ‘{ print $2 }’)
                      now it will kill process pir.py
                      but problem is that even if this script (pir.py) is not running the mirror still turns on when there is movement and turns off after 30s no movement … strange
                      • cruunnerrC
                        cruunnerr
                        When the pir.py isn’t running, then it isn’t this script which turns on your monitor.
                        Do you have the MM-PIR module active?
                        Please try to edit your rc.local and delete the autostart of the pir.py to see, if the monitor still turns on/off when there is movement.
                        if not, then the pkill command isn’t working, which would confuse me, because i just tried it by myself on my mirror.
                        via ssh i just entered the sudo pkill $(ps aux | grep python pir.py | awk '{ print $2 }')" command and my pir wasn’t working.
                        and to your first problem, which u solved by yourself…
                        u could also try to edit the killpir.py to this:
                        #!/bin/bash
                        then u should be able to just let your cronjob look like:
                        0 21 * * * root /home/pi/killpir.sh
                        • MarosM
                          Maros
                          Yes i’ve active mmm-pir module.
                          I’ll try your solution and let you know
                          Thank you ;)
                          • MarosM
                            Maros
                            i’ve removed line from rc.local and mirror is still working as should (turn on when there is movement and turn off after 30s as set up in MMM-PIR module)
                              MadScientist
                              Was the MMM-PIR sensor module active while you tried the script of 2.2? You will have to disable the module. Then you create and load the scripts and create the cronjob. If you don’t disable the MMM-PIR module then it will keep waking up the screen even if you disabled the pir.py script.
                              Please excuse me if that’s what you did and I just got it wrong.
                              • cruunnerrC
                                cruunnerr
                                Hey sorry, i thought u disabled the MMM-PIR for sure.
                                U cannot use both (Module and the script) at the same time.
                                Thats because i said u should disable the autostart in the rc.local to see if the MMM-PIR is active.
                                So please disable the module and just use the script. Then the pkill command will work as u want :)
                                • MarosM
                                  Maros
                                  everything is working after disabling module :)
                                  just one remark there is needed to add also to crontab to turn off monitor at f.e. 21:02 because if there will be movement in last seconds before pir.py will be killed monitor will stay on :)
                                  • T
                                    teitlebot
                                    @Module-Developers im trying to do something a bit different maybe you can help.
                                    I’d like to use PIR but I also want that on one particular day of the week PIR shouldn’t work and it should stay on no matter what.
                                    Is that possible?
                                    • cruunnerrC
                                      cruunnerr
                                      Read the last few posts ;)
                                      For example u want to use the pir from Sunday 22pm over the whole week until next Sunday 6am.
                                      So on every Sunday from 6am to 22pm the monitor should stay on.
                                      So you just need two cronjobs. On Sunday, 6am u need to kill the pir.py and on Sunday, 22pm you need to start it again :)
                                      Try it like this:
                                      1. nano killpir.sh
                                      #!/bin/bash
                                      vcgencmd display_power 1
                                      0 22 * * 7 /usr/bin/sh /home/pi/killpir.sh
                                      0 6 * * 7 /usr/bin/python /home/pi/pir.py
                                      SHELL=/bin/sh
                                      0 22    * * 7   root    /usr/bin/sh /home/pi/killpir.sh
                                      0 6     * * 7   root    /usr/bin/python /home/pi/pir.py
                                      Mykle1M 1 Reply Last reply
                                      Reply Quote 2
                                      • Mykle1M
                                        Mykle1 Project Sponsor Module Developer @cruunnerr
                                        @cruunnerr
                                        You’re the king of cronjobs!
                                        • K
                                          komodoteler
                                          @cruunnerr
                                          I tried your script but unfortunately it doesn’t seems to work yet. Like @blebbens , my MM is on the floor and activated a little bit too easy.
                                          Any other suggestion?
                                          Regards,
                                          • cruunnerrC
                                            cruunnerr
                                            Well, for my solution it is totally necessary to NOT use the PIR-Module. You must use just my external script solution!
                                            Tests i made working fine… :)
                                            Anyhow… You could try to use clear nail polish.
                                            I used it to cover certain regions and it works :)
                                            Just paint several layers of the polish over the area u want to cover.
                                            Or play with the sensitivity
                                            Bild Text
                                            • 5 / 9
