    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 359.1k Views 54 Watching
    • cruunnerrC
      cruunnerr
      cron will start the pir.py in background. The scenario will be like:
      Boot up magic mirror = starts pir.py via rc.local
      at 21pm = stops pir.py via cron
      at 7am = starts pir.py via cron
      from this on the circle is closed and cron will repeat this every day (in background)
      well… i think so… maybe i am wrong :/
      When u reboot the mirror between 21pm and 7am the pir.py will be active for sure until the next 21pm will be reached … ;)
      edit:
      it would also be possible to implement a while-loop in the pir.py script to check if it is between 21pm and 7am.
      But i never worked with that yet -.-
      maybe u can get what u want here or here or here
      • MarosM
        Maros
        ok i’ve checked and it’s not working fully.
        problem is with /usr/bin/sh /home/pi/killpir.sh
        there is no /usr/bin/sh only rsh
        edit.
        ok i’ve changed path to /bin/sh and now i get error :
        grep: pir.py: No such file or directory
        pkill: no matching criteria specified
        Try `pkill --help’ for more information.
        even if pir.py is running (i can see it in ps -ef |grep pir)
        edit ok i was able to fix it i’ve edited killpir.sh to
        sudo kill $(ps aux | grep python | grep pir.py | awk ‘{ print $2 }’)
        now it will kill process pir.py
        but problem is that even if this script (pir.py) is not running the mirror still turns on when there is movement and turns off after 30s no movement … strange
        • cruunnerrC
          cruunnerr
          When the pir.py isn’t running, then it isn’t this script which turns on your monitor.
          Do you have the MM-PIR module active?
          Please try to edit your rc.local and delete the autostart of the pir.py to see, if the monitor still turns on/off when there is movement.
          if not, then the pkill command isn’t working, which would confuse me, because i just tried it by myself on my mirror.
          via ssh i just entered the sudo pkill $(ps aux | grep python pir.py | awk '{ print $2 }')" command and my pir wasn’t working.
          and to your first problem, which u solved by yourself…
          u could also try to edit the killpir.py to this:
          #!/bin/bash
          then u should be able to just let your cronjob look like:
          0 21 * * * root /home/pi/killpir.sh
          • MarosM
            Maros
            Yes i’ve active mmm-pir module.
            I’ll try your solution and let you know
            Thank you ;)
            • MarosM
              Maros
              i’ve removed line from rc.local and mirror is still working as should (turn on when there is movement and turn off after 30s as set up in MMM-PIR module)
                MadScientist
                Was the MMM-PIR sensor module active while you tried the script of 2.2? You will have to disable the module. Then you create and load the scripts and create the cronjob. If you don’t disable the MMM-PIR module then it will keep waking up the screen even if you disabled the pir.py script.
                Please excuse me if that’s what you did and I just got it wrong.
                • cruunnerrC
                  cruunnerr
                  Hey sorry, i thought u disabled the MMM-PIR for sure.
                  U cannot use both (Module and the script) at the same time.
                  Thats because i said u should disable the autostart in the rc.local to see if the MMM-PIR is active.
                  So please disable the module and just use the script. Then the pkill command will work as u want :)
                  • MarosM
                    Maros
                    everything is working after disabling module :)
                    just one remark there is needed to add also to crontab to turn off monitor at f.e. 21:02 because if there will be movement in last seconds before pir.py will be killed monitor will stay on :)
                    • T
                      teitlebot
                      @Module-Developers im trying to do something a bit different maybe you can help.
                      I’d like to use PIR but I also want that on one particular day of the week PIR shouldn’t work and it should stay on no matter what.
                      Is that possible?
                      • cruunnerrC
                        cruunnerr
                        Read the last few posts ;)
                        For example u want to use the pir from Sunday 22pm over the whole week until next Sunday 6am.
                        So on every Sunday from 6am to 22pm the monitor should stay on.
                        So you just need two cronjobs. On Sunday, 6am u need to kill the pir.py and on Sunday, 22pm you need to start it again :)
                        Try it like this:
                        1. nano killpir.sh
                        2. Write this into file and save with CTRL+X and Yes
                        #!/bin/bash
                        vcgencmd display_power 1
                        1. chmod +x killpir.sh
                        2. sudo nano /etc/crontab
                        3. Write this into file and save with CTRL+X and Yes:
                        0 22 * * 7 /usr/bin/sh /home/pi/killpir.sh
                        0 6 * * 7 /usr/bin/python /home/pi/pir.py
                        So for example your crontab looks like this:
                        # /etc/crontab: system-wide crontab
                        # Unlike any other crontab you don't have to run the `crontab'
                        # command to install the new version when you edit this file
                        # and files in /etc/cron.d. These files also have username fields,
                        # that none of the other crontabs do.
                        SHELL=/bin/sh
                        PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
                        # m h dom mon dow user  command
                        17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
                        25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
                        47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
                        52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
                        0 22    * * 7   root    /usr/bin/sh /home/pi/killpir.sh
                        0 6     * * 7   root    /usr/bin/python /home/pi/pir.py
                        Mykle1M 1 Reply Last reply
                        Reply Quote 2
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @cruunnerr
                          @cruunnerr
                          You’re the king of cronjobs!
                          • K
                            komodoteler
                            @cruunnerr
                            I tried your script but unfortunately it doesn’t seems to work yet. Like @blebbens , my MM is on the floor and activated a little bit too easy.
                            Any other suggestion?
                            Regards,
                            • cruunnerrC
                              cruunnerr
                              Well, for my solution it is totally necessary to NOT use the PIR-Module. You must use just my external script solution!
                              Tests i made working fine… :)
                              Anyhow… You could try to use clear nail polish.
                              I used it to cover certain regions and it works :)
                              Just paint several layers of the polish over the area u want to cover.
                              Or play with the sensitivity
                              Bild Text
                              • K
                                komodoteler
                                @cruunnerr
                                I actually use option 2.2 - external script and already set both sensitivity and time delay to minimal (all the way to left).
                                would you mind to send me your pir.py?
                                Regards,
                                • cruunnerrC
                                  cruunnerr
                                  Sure, my pir.py is the same as shown on point 2.2 but with other GPIO used
                                  #!/usr/bin/env python
                                  import sys
                                  import time
                                  import RPi.GPIO as io
                                  import subprocess
                                  import pigpio
                                  io.setmode(io.BCM)
                                  SHUTOFF_DELAY = 119 # seconds
                                  PIR_PIN = 25       # 22 on the board
                                  LED_PIN = 16
                                  def main():
                                      io.setup(PIR_PIN, io.IN)
                                      io.setup(LED_PIN, io.OUT)
                                      turned_off = False
                                      last_motion_time = time.time()
                                      while True:
                                          if io.input(PIR_PIN):
                                              io.output(LED_PIN, io.LOW)
                                              print ".",
                                              sys.stdout.flush()
                                              if turned_off:
                                                  turned_off = False
                                                  turn_on()
                                          else:
                                              if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                                  turned_off = True
                                                  turn_off()
                                              if not turned_off and time.time() > (last_motion_time + 1):
                                                  io.output(LED_PIN, io.HIGH)
                                          time.sleep(.1)
                                  def turn_on():
                                          subprocess.call("sh /home/pi/lights_on.sh", shell=True)
                                  def turn_off():
                                          subprocess.call("sh /home/pi/lights_off.sh", shell=True)
                                  if __name__ == '__main__':
                                      try:
                                          main()
                                      except KeyboardInterrupt:
                                          io.cleanup()
                                  Because i use some LED Stripes which turn on when the pir detects movement my “monitor_on.sh” is called “lights_on.sh”
                                  lights_on.sh:
                                  pigs p 17 1
                                  pigs p 22 1
                                  pigs p 24 1
                                  sleep 0.06s
                                  pigs p 17 2
                                  pigs p 22 2
                                  pigs p 24 2
                                  sleep 0.06s
                                  pigs p 17 3
                                  pigs p 22 3
                                  pigs p 24 3
                                  sleep 0.06s
                                  pigs p 17 4
                                  pigs p 22 4
                                  pigs p 24 4
                                  sleep 0.06s
                                  pigs p 17 5
                                  pigs p 22 5
                                  pigs p 24 5
                                  sleep 0.06s
                                  pigs p 17 6
                                  pigs p 22 6
                                  pigs p 24 5
                                  sleep 0.06s
                                  pigs p 17 7
                                  pigs p 22 7
                                  pigs p 24 6
                                  sleep 0.06s
                                  pigs p 17 8
                                  pigs p 22 8
                                  pigs p 24 7
                                  sleep 0.06s
                                  pigs p 17 9
                                  pigs p 22 9
                                  pigs p 24 8
                                  sleep 0.06s
                                  pigs p 17 10
                                  pigs p 22 10
                                  pigs p 24 9
                                  sleep 0.06s
                                  pigs p 17 11
                                  pigs p 22 11
                                  pigs p 24 10
                                  sleep 0.06s
                                  pigs p 17 12
                                  pigs p 22 12
                                  pigs p 24 11
                                  lights_off.sh:
                                  pigs p 17 12
                                  pigs p 22 12
                                  pigs p 24 11
                                  sleep 0.06s
                                  pigs p 17 11
                                  pigs p 22 11
                                  pigs p 24 10
                                  sleep 0.06s
                                  pigs p 17 10
                                  pigs p 22 10
                                  pigs p 24 9
                                  sleep 0.06s
                                  pigs p 17 9
                                  pigs p 22 9
                                  pigs p 24 8
                                  sleep 0.06s
                                  pigs p 17 8
                                  pigs p 22 8
                                  pigs p 24 7
                                  sleep 0.06s
                                  pigs p 17 7
                                  pigs p 22 7
                                  pigs p 24 6
                                  sleep 0.06s
                                  pigs p 17 6
                                  pigs p 22 6
                                  pigs p 24 5
                                  sleep 0.06s
                                  pigs p 17 5
                                  pigs p 22 5
                                  pigs p 24 5
                                  sleep 0.06s
                                  pigs p 17 4
                                  pigs p 22 4
                                  pigs p 24 4
                                  sleep 0.06s
                                  pigs p 17 4
                                  pigs p 22 4
                                  pigs p 24 4
                                  sleep 0.06s
                                  pigs p 17 3
                                  pigs p 22 3
                                  pigs p 24 3
                                  sleep 0.06s
                                  pigs p 17 2
                                  pigs p 22 2
                                  pigs p 24 2
                                  vcgencmd display_power 0
                                  sleep 0.06s
                                  pigs p 17 1
                                  pigs p 22 1
                                  pigs p 24 1
                                  sleep 0.06s
                                  pigs p 17 0
                                  pigs p 22 0
                                  pigs p 24 0
                                  But what exactly doesn’t work with my script? Maybe i can help :)
                                  C 1 Reply Last reply
                                  • K
                                    komodoteler
                                    Thanks @cruunnerr.
                                    In my case, no LED involved hence should be simpler :)
                                    I run PIR.PY externally (via PM2) to call monitor on/off shell script and everything seems to work fine i.e.: turn screen blank and back on does work. No error reported. Its just the adding your script does not seems to make any difference, the turn on still instant.
                                    Here is my PIR.py file
                                    import sys
                                    import time
                                    import subprocess
                                    io.setmode(io.BCM)
                                    SHUTOFF_DELAY = 15  # seconds delay to turn off
                                    PIR_PIN = 17        # Pin 11 on the board
                                    TURNON_DELAY = 10   # seconds delay to turn on
                                    def main():
                                        turned_off = False
                                        while True:
                                                sys.stdout.flush()
                                                if turned_off and time.time() > TURNON_DELAY:
                                                    turned_off = False
                                                    turn_on()
                                            else:
                                                if not turned_off and time.time() > (last_motion_time + SHUTOFF_DELAY):
                                                    turned_off = True
                                                    turn_off()
                                            time.sleep(.1)
                                    def turn_on():
                                        subprocess.call("sh monitor_on.sh", shell=True)
                                    def turn_off():
                                        subprocess.call("sh monitor_off.sh", shell=True)
                                        try:
                                            main()
                                            io.cleanup()
                                    Here is the monitor_off.sh
                                    #! /bin/bash
                                    export DISPLAY=:0
                                    xset dpms force off
                                    And Monitor_on.sh
                                    export DISPLAY=:0
                                    xset dpms force on
                                    • cruunnerrC
                                      cruunnerr
                                      Hey mate,
                                      you are using this script.
                                      As i wrote in my post, it was just brainstorming. I never tested this script. :(
                                      But i can imagine that this will not work… For a Turn_on delay u probably need a loop-function.
                                      But when i read your posts i can’t find, that u need this :D
                                      So just try the script from the original 1# post :)
                                        blebbens
                                        I‘m using the PIR python-script-method.
                                        It is working fine… but, my mirror is installed in a floor, where people are crossing the mirror several times a day without looking at it.
                                        It would be a helpful solution, if the script switches on the monitor if a person is standing in front of the mirror for 6 seconds.
                                        Is there a possibility for modifying the script ?
                                        • cruunnerrC
                                          cruunnerr
                                          This will not work with a simple motion detector. Because “standing” is not “motion”. ;)
                                          Then u would need a light barrier or something like that.
                                          Or u need to shake your body for 6 seconds in front of the mirror XD
                                            MadScientist
                                            I wouldn’t know how to program it but you could try playing around with a photo resistor like this or this. But I think that will only work if you have constant light conditions. Maybe an IR light barrier with a reflector on the other side would work better.
                                            No idea if what you want is possible but that would be an awesome project.
                                            • 5 / 9
