    {HowTo} turn on/off your monitor (Time based, PIR/Button, App)
    171 Posts 39 Posters 355.3k Views 54 Watching
    • MarosM
      Maros
      i’ve removed line from rc.local and mirror is still working as should (turn on when there is movement and turn off after 30s as set up in MMM-PIR module)
        MadScientist
        Was the MMM-PIR sensor module active while you tried the script of 2.2? You will have to disable the module. Then you create and load the scripts and create the cronjob. If you don’t disable the MMM-PIR module then it will keep waking up the screen even if you disabled the pir.py script.
        Please excuse me if that’s what you did and I just got it wrong.
        • cruunnerrC
          cruunnerr
          Hey sorry, i thought u disabled the MMM-PIR for sure.
          U cannot use both (Module and the script) at the same time.
          Thats because i said u should disable the autostart in the rc.local to see if the MMM-PIR is active.
          So please disable the module and just use the script. Then the pkill command will work as u want :)
          • MarosM
            Maros
            everything is working after disabling module :)
            just one remark there is needed to add also to crontab to turn off monitor at f.e. 21:02 because if there will be movement in last seconds before pir.py will be killed monitor will stay on :)
            • T
              teitlebot
              @Module-Developers im trying to do something a bit different maybe you can help.
              I’d like to use PIR but I also want that on one particular day of the week PIR shouldn’t work and it should stay on no matter what.
              Is that possible?
              • cruunnerrC
                cruunnerr
                Read the last few posts ;)
                For example u want to use the pir from Sunday 22pm over the whole week until next Sunday 6am.
                So on every Sunday from 6am to 22pm the monitor should stay on.
                So you just need two cronjobs. On Sunday, 6am u need to kill the pir.py and on Sunday, 22pm you need to start it again :)
                Try it like this:
                1. nano killpir.sh
                2. Write this into file and save with CTRL+X and Yes
                #!/bin/bash
                sudo pkill $(ps aux | grep python pir.py | awk '{ print $2 }')
                vcgencmd display_power 1
                1. chmod +x killpir.sh
                2. sudo nano /etc/crontab
                3. Write this into file and save with CTRL+X and Yes:
                0 22 * * 7 /usr/bin/sh /home/pi/killpir.sh
                0 6 * * 7 /usr/bin/python /home/pi/pir.py
                So for example your crontab looks like this:
                # /etc/crontab: system-wide crontab
                # Unlike any other crontab you don't have to run the `crontab'
                # command to install the new version when you edit this file
                # and files in /etc/cron.d. These files also have username fields,
                # that none of the other crontabs do.
                SHELL=/bin/sh
                PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
                # m h dom mon dow user  command
                17 *    * * *   root    cd / && run-parts --report /etc/cron.hourly
                25 6    * * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )
                47 6    * * 7   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly )
                52 6    1 * *   root    test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.monthly )
                0 22    * * 7   root    /usr/bin/sh /home/pi/killpir.sh
                0 6     * * 7   root    /usr/bin/python /home/pi/pir.py
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @cruunnerr
                  @cruunnerr
                  You’re the king of cronjobs!
                  • K
                    komodoteler
                    @cruunnerr
                    I tried your script but unfortunately it doesn’t seems to work yet. Like @blebbens , my MM is on the floor and activated a little bit too easy.
                    Any other suggestion?
                    Regards,
                    • cruunnerrC
                      cruunnerr
                      Well, for my solution it is totally necessary to NOT use the PIR-Module. You must use just my external script solution!
                      Tests i made working fine… :)
                      Anyhow… You could try to use clear nail polish.
                      I used it to cover certain regions and it works :)
                      Just paint several layers of the polish over the area u want to cover.
                      Or play with the sensitivity
                      Bild Text
                      • K
                        komodoteler
                        @cruunnerr
                        I actually use option 2.2 - external script and already set both sensitivity and time delay to minimal (all the way to left).
                        would you mind to send me your pir.py?
                        Regards,
                        • cruunnerrC
                          cruunnerr
                          Sure, my pir.py is the same as shown on point 2.2 but with other GPIO used
                          #!/usr/bin/env python
                          import sys
                          import time
                          import RPi.GPIO as io
                          import subprocess
                          import pigpio
                          io.setmode(io.BCM)
                          SHUTOFF_DELAY = 119 # seconds
                          PIR_PIN = 25       # 22 on the board
                          LED_PIN = 16
                          def main():
                              io.setup(PIR_PIN, io.IN)
                              io.setup(LED_PIN, io.OUT)
                              turned_off = False
                              last_motion_time = time.time()
                              while True:
                                  if io.input(PIR_PIN):
                                      io.output(LED_PIN, io.LOW)
                                      print ".",
                                      sys.stdout.flush()
                                      if turned_off:
                                          turned_off = False
                                          turn_on()
                                  else:
                                      if not turned_off and time.time() > (last_motion_time +
        SHUTOFF_DELAY):
                                          turned_off = True
                                          turn_off()
                                      if not turned_off and time.time() > (last_motion_time + 1):
                                          io.output(LED_PIN, io.HIGH)
                                  time.sleep(.1)
                          def turn_on():
                                  subprocess.call("sh /home/pi/lights_on.sh", shell=True)
                          def turn_off():
                                  subprocess.call("sh /home/pi/lights_off.sh", shell=True)
                          if __name__ == '__main__':
                              try:
                                  main()
                              except KeyboardInterrupt:
                                  io.cleanup()
                          Because i use some LED Stripes which turn on when the pir detects movement my “monitor_on.sh” is called “lights_on.sh”
                          lights_on.sh:
                          pigs p 17 1
                          pigs p 22 1
                          pigs p 24 1
                          sleep 0.06s
                          pigs p 17 2
                          pigs p 22 2
                          pigs p 24 2
                          sleep 0.06s
                          pigs p 17 3
                          pigs p 22 3
                          pigs p 24 3
                          sleep 0.06s
                          pigs p 17 4
                          pigs p 22 4
                          pigs p 24 4
                          sleep 0.06s
                          pigs p 17 5
                          pigs p 22 5
                          pigs p 24 5
                          sleep 0.06s
                          pigs p 17 6
                          pigs p 22 6
                          pigs p 24 5
                          sleep 0.06s
                          pigs p 17 7
                          pigs p 22 7
                          pigs p 24 6
                          sleep 0.06s
                          pigs p 17 8
                          pigs p 22 8
                          pigs p 24 7
                          sleep 0.06s
                          pigs p 17 9
                          pigs p 22 9
                          pigs p 24 8
                          sleep 0.06s
                          pigs p 17 10
                          pigs p 22 10
                          pigs p 24 9
                          sleep 0.06s
                          pigs p 17 11
                          pigs p 22 11
                          pigs p 24 10
                          sleep 0.06s
                          pigs p 17 12
                          pigs p 22 12
                          pigs p 24 11
                          lights_off.sh:
                          pigs p 17 12
                          pigs p 22 12
                          pigs p 24 11
                          sleep 0.06s
                          pigs p 17 11
                          pigs p 22 11
                          pigs p 24 10
                          sleep 0.06s
                          pigs p 17 10
                          pigs p 22 10
                          pigs p 24 9
                          sleep 0.06s
                          pigs p 17 9
                          pigs p 22 9
                          pigs p 24 8
                          sleep 0.06s
                          pigs p 17 8
                          pigs p 22 8
                          pigs p 24 7
                          sleep 0.06s
                          pigs p 17 7
                          pigs p 22 7
                          pigs p 24 6
                          sleep 0.06s
                          pigs p 17 6
                          pigs p 22 6
                          pigs p 24 5
                          sleep 0.06s
                          pigs p 17 5
                          pigs p 22 5
                          pigs p 24 5
                          sleep 0.06s
                          pigs p 17 4
                          pigs p 22 4
                          pigs p 24 4
                          sleep 0.06s
                          pigs p 17 4
                          pigs p 22 4
                          pigs p 24 4
                          sleep 0.06s
                          pigs p 17 3
                          pigs p 22 3
                          pigs p 24 3
                          sleep 0.06s
                          pigs p 17 2
                          pigs p 22 2
                          pigs p 24 2
                          vcgencmd display_power 0
                          sleep 0.06s
                          pigs p 17 1
                          pigs p 22 1
                          pigs p 24 1
                          sleep 0.06s
                          pigs p 17 0
                          pigs p 22 0
                          pigs p 24 0
                          But what exactly doesn’t work with my script? Maybe i can help :)
                          • K
                            komodoteler
                            Thanks @cruunnerr.
                            In my case, no LED involved hence should be simpler :)
                            I run PIR.PY externally (via PM2) to call monitor on/off shell script and everything seems to work fine i.e.: turn screen blank and back on does work. No error reported. Its just the adding your script does not seems to make any difference, the turn on still instant.
                            Here is my PIR.py file
                            import sys
                            import time
                            import subprocess
                            io.setmode(io.BCM)
                            SHUTOFF_DELAY = 15  # seconds delay to turn off
                            PIR_PIN = 17        # Pin 11 on the board
                            TURNON_DELAY = 10   # seconds delay to turn on
                            def main():
                                turned_off = False
                                while True:
                                        sys.stdout.flush()
                                        if turned_off and time.time() > TURNON_DELAY:
                                            turned_off = False
                                            turn_on()
                                    else:
                                        if not turned_off and time.time() > (last_motion_time + SHUTOFF_DELAY):
                                            turned_off = True
                                            turn_off()
                                    time.sleep(.1)
                            def turn_on():
                                subprocess.call("sh monitor_on.sh", shell=True)
                            def turn_off():
                                subprocess.call("sh monitor_off.sh", shell=True)
                                try:
                                    main()
                                    io.cleanup()
                            Here is the monitor_off.sh
                            #! /bin/bash
                            export DISPLAY=:0
                            xset dpms force off
                            And Monitor_on.sh
                            export DISPLAY=:0
                            xset dpms force on
                            • cruunnerrC
                              cruunnerr
                              Hey mate,
                              you are using this script.
                              As i wrote in my post, it was just brainstorming. I never tested this script. :(
                              But i can imagine that this will not work… For a Turn_on delay u probably need a loop-function.
                              But when i read your posts i can’t find, that u need this :D
                              So just try the script from the original 1# post :)
                                blebbens
                                I‘m using the PIR python-script-method.
                                It is working fine… but, my mirror is installed in a floor, where people are crossing the mirror several times a day without looking at it.
                                It would be a helpful solution, if the script switches on the monitor if a person is standing in front of the mirror for 6 seconds.
                                Is there a possibility for modifying the script ?
                                • cruunnerrC
                                  cruunnerr
                                  This will not work with a simple motion detector. Because “standing” is not “motion”. ;)
                                  Then u would need a light barrier or something like that.
                                  Or u need to shake your body for 6 seconds in front of the mirror XD
                                    MadScientist
                                    I wouldn’t know how to program it but you could try playing around with a photo resistor like this or this. But I think that will only work if you have constant light conditions. Maybe an IR light barrier with a reflector on the other side would work better.
                                    No idea if what you want is possible but that would be an awesome project.
                                    • cruunnerrC
                                      cruunnerr
                                      Or use an ultrasonic sensor. You could let it measure the distance and if its under a specific value for a specific time it could turn on the monitor
                                        Rec3ptor
                                        Would you mind sharing how you wired your LED to pin16 in step 2.2 Using PIR-Script for LED_PIN = 16?
                                        are you using resistors or mosfets etc? im a noob and dont want to break anything.
                                        • cruunnerrC
                                          cruunnerr
                                          In my Case I am using a RGB 5050 Stripe. I am using three pins with mosfets and for the software part PIGPIOD.
                                          Just like that: https://dordnung.de/raspberrypi-ledstrip/
                                          Here are my scripts:
                                          monitor on:
                                          pigs p 17 1
                                          pigs p 22 1
                                          pigs p 24 1
                                          sleep 0.06s
                                          pigs p 17 2
                                          pigs p 22 2
                                          pigs p 24 2
                                          sleep 0.06s
                                          pigs p 17 3
                                          pigs p 22 3
                                          pigs p 24 3
                                          sleep 0.06s
                                          pigs p 17 4
                                          pigs p 22 4
                                          pigs p 24 4
                                          sleep 0.06s
                                          pigs p 17 5
                                          pigs p 22 5
                                          pigs p 24 5
                                          sleep 0.06s
                                          pigs p 17 6
                                          pigs p 22 6
                                          pigs p 24 5
                                          sleep 0.06s
                                          pigs p 17 7
                                          pigs p 22 7
                                          pigs p 24 6
                                          sleep 0.06s
                                          pigs p 17 8
                                          pigs p 22 8
                                          pigs p 24 7
                                          sleep 0.06s
                                          pigs p 17 9
                                          pigs p 22 9
                                          pigs p 24 8
                                          sleep 0.06s
                                          pigs p 17 10
                                          pigs p 22 10
                                          pigs p 24 9
                                          sleep 0.06s
                                          pigs p 17 11
                                          pigs p 22 11
                                          pigs p 24 10
                                          sleep 0.06s
                                          pigs p 17 12
                                          pigs p 22 12
                                          pigs p 24 11
                                          Monitor off:
                                          pigs p 17 12
                                          pigs p 22 12
                                          pigs p 24 11
                                          sleep 0.06s
                                          pigs p 17 11
                                          pigs p 22 11
                                          pigs p 24 10
                                          sleep 0.06s
                                          pigs p 17 10
                                          pigs p 22 10
                                          pigs p 24 9
                                          sleep 0.06s
                                          pigs p 17 9
                                          pigs p 22 9
                                          pigs p 24 8
                                          sleep 0.06s
                                          pigs p 17 8
                                          pigs p 22 8
                                          pigs p 24 7
                                          sleep 0.06s
                                          pigs p 17 7
                                          pigs p 22 7
                                          pigs p 24 6
                                          sleep 0.06s
                                          pigs p 17 6
                                          pigs p 22 6
                                          pigs p 24 5
                                          sleep 0.06s
                                          pigs p 17 5
                                          pigs p 22 5
                                          pigs p 24 5
                                          sleep 0.06s
                                          pigs p 17 4
                                          pigs p 22 4
                                          pigs p 24 4
                                          sleep 0.06s
                                          pigs p 17 4
                                          pigs p 22 4
                                          pigs p 24 4
                                          sleep 0.06s
                                          pigs p 17 3
                                          pigs p 22 3
                                          pigs p 24 3
                                          sleep 0.06s
                                          pigs p 17 2
                                          pigs p 22 2
                                          pigs p 24 2
                                          sleep 0.06s
                                          pigs p 17 1
                                          pigs p 22 1
                                          pigs p 24 1
                                          sleep 0.06s
                                          pigs p 17 0
                                          pigs p 22 0
                                          pigs p 24 0
                                          • richland007R
                                            richland007
                                            @cruunnerr Hey there great tutorial,
                                            I want to use the cronjob to turn on and off the mirror at certain times of the day.
                                            My monitor is a DVI monitor so it is connected digitally with a cable that on one end is HDMI that sticks in the Rpi and the other end is a DVI connector that goes in the monitor.
                                            When i try the commands you have mentioned;
                                            sudo tvservice -o to turn off
                                            sudo tvservice -p to turn on
                                            vcgencmd display_power 0 to turn off
                                            vcgencmd display_power 1 to turn on
                                            Both commands for OFF turn off the display however none of the ON commands work right …it does not come on fully!!!
                                            Meaning that it is On just no picture… it says DVI = Active VGA - No Signal and the Rpi is working there is just no picture …and no there is no Power Saving feature, i don’t think, because the back light of the LCD i can see is on after the ON command.
                                            I send the On and Off commands through Putty ssh but i am also logged in with VNC and the moment you click reboot from VNC (there is nothing on the screen just dark with On LCD back light) the picture comes immediately back on and reboot carries on as usual and the picture is back on!!
                                            So i think the Rpi HDMI signal is at fault and not the monitor feature but i may be wrong …what do you think may man??
                                            Thank you in advance
                                            Denis
                                            p.s I read all 11 pages of this thread form the begging to the end with the hopes of finding a solution before bothering you LOL :)
                                            • 5 / 9
