MMM-GoogleShoppingList
16 Posts 6 Posters 7.2k Views 7 Watching
    A Former User
    MagicMirror module for displaying Google Shoppinglist
    Screenshot
    screenshot
    Details
    [card:eouia/MMM-GoogleShoppingList]
    • T Offline
      tismepaulo
      Hi, great work on this, looking forward to seeing how it progresses. I can’t seem to get it working as it cannot bypass the Google sign in. I know it is attempting to sign in as I get a text message with a Google access code. Where do I put this code to make things work?
      ? 1 Reply Last reply Sep 7, 2018, 4:11 PM Reply Quote 0
        A Former User @tismepaulo
        @tismepaulo
        Sorry, This module is not completed. I’ve found a big issue on this module, I tried to patch but not get a success. sorry again.
        T 1 Reply Last reply Sep 7, 2018, 4:29 PM Reply Quote 0
        • T Offline
          tismepaulo @Guest
          @sean OK, no worries. I’ll keep an eye out for updates
            A Former User
            @tismepaulo
            I think I’ve fixed issues. Could you test it for me? (Re-install required. See the github)
              PILuke
              Hi, nice module, for my wife :-)
              Has someone tested it?
              I see the module “Loading” but I don’t see the shopping list.
              In console I receive this message:
              [GSL] Landed on the target page. Trying to get list
              [GSL] Tried. (when even failed) : 8
              Some suggest?
              Many thanks
              ? 1 Reply Last reply Oct 29, 2018, 6:41 PM Reply Quote 0
                A Former User @PILuke
                @piluke
                I think there are 8 items in your shopping list, right? If so, there could be front-end error (even caused by my module or others).
                Can you try npm start dev instead pm2? (stop pm2 stop mm then execute npm start dev in your MagicMirror directory) Then you can see the dev panel on MM screen. And if there be any suspicious front-end error, the red text will be shown there.
                dev-panel looks like this (the right side);
                P 1 Reply Last reply Oct 29, 2018, 8:17 PM Reply Quote 0
                  PILuke @Guest
                  @sean
                  I didn’t know this working mode of MM, thanks for your answer.
                  It’s right my list has 8 items.
                  I disable all module except clock and start “dev” mode.
                  There is only one red error but it’s from this module:
                  MMM-GoogleShoppingList.js:70 Uncaught TypeError: Cannot read property '1' of null
                      at items.forEach.item (MMM-GoogleShoppingList.js:70)
                      at Array.forEach (<anonymous>)
                      at Class.drawItems (MMM-GoogleShoppingList.js:54)
                      at Class.socketNotificationReceived (MMM-GoogleShoppingList.js:46)
                      at module.js:246
                      at r.<anonymous> (socketclient.js:25)
                      at r.emit (index.js:133)
                      at r.onevent (socket.js:270)
                      at r.MMSocket.self.socket.onevent (socketclient.js:19)
                      at r.onpacket (socket.js:228)
                  After few minutes the same error came again…
                  ? 1 Reply Last reply Oct 29, 2018, 9:17 PM Reply Quote 0
                    Thanks for reply. Would you send me a mail address? Mine is eouia0819@gmail.com. I’ll send a test file to catch what is wrong. (But here is late night, so I’ll send you 10 hours later)
                      Sebi76
                      I become this Error…
                      [GSL] Trying to login
                      (node:17281) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): Error: Evaluation failed:
                      TypeError: Cannot read property ‘click’ of null
                      at puppeteer_evaluation_script:2:44
                      (node:17281) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated.
                      In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                      ? 1 Reply Last reply Dec 23, 2018, 6:57 PM Reply Quote 0
