    MMM-GoogleShoppingList
    16 Posts 6 Posters 8.8k Views 7 Watching
      PILuke
      Hi, nice module, for my wife :-)
      Has someone tested it?
      I see the module “Loading” but I don’t see the shopping list.
      In console I receive this message:
      [GSL] Landed on the target page. Trying to get list
      [GSL] Tried. (when even failed) : 8
      Some suggest?
      Many thanks
        A Former User @PILuke
        @piluke
        I think there are 8 items in your shopping list, right? If so, there could be front-end error (even caused by my module or others).
        Can you try npm start dev instead pm2? (stop pm2 stop mm then execute npm start dev in your MagicMirror directory) Then you can see the dev panel on MM screen. And if there be any suspicious front-end error, the red text will be shown there.
        dev-panel looks like this (the right side);
          PILuke @Guest
          @sean
          I didn’t know this working mode of MM, thanks for your answer.
          It’s right my list has 8 items.
          I disable all module except clock and start “dev” mode.
          There is only one red error but it’s from this module:
          MMM-GoogleShoppingList.js:70 Uncaught TypeError: Cannot read property '1' of null
              at items.forEach.item (MMM-GoogleShoppingList.js:70)
              at Array.forEach (<anonymous>)
              at Class.drawItems (MMM-GoogleShoppingList.js:54)
              at Class.socketNotificationReceived (MMM-GoogleShoppingList.js:46)
              at module.js:246
              at r.<anonymous> (socketclient.js:25)
              at r.emit (index.js:133)
              at r.onevent (socket.js:270)
              at r.MMSocket.self.socket.onevent (socketclient.js:19)
              at r.onpacket (socket.js:228)
          After few minutes the same error came again…
            Thanks for reply. Would you send me a mail address? Mine is eouia0819@gmail.com. I’ll send a test file to catch what is wrong. (But here is late night, so I’ll send you 10 hours later)
              Sebi76
              I become this Error…
              [GSL] Trying to login
              (node:17281) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): Error: Evaluation failed:
              TypeError: Cannot read property ‘click’ of null
              at puppeteer_evaluation_script:2:44
              (node:17281) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated.
              In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                A Former User @Sebi76
                @sebi76
                Google hasn’t released its official API for ShoppingList yet. My approach is screen scrapping with Puppeteer. Most of case it works well. My module would login your ShoppingList homepage and surf for getting information in hidden browser.
                But by some unknown reason, Someone might see DIFFERENT PAGE with others with same URL. Only Google knows why and what. In that case, my module doesn’t know WHAT IS LOGIN BUTTON and other things. I’ve already known that issue but there is no way to solve it.
                Maybe waiting official API release is a better solution.
                • V Offline
                  valid8r
                  Does this module work today?
                    A Former User @valid8r
                    @valid8r
                    For lucky someone it works and not for unlucky someone. At least for me it works. Sorry.
                    • V Offline
                      valid8r @Guest
                      @Sean Ok, thanks, I’ll give it a try to see.
                      • E Offline
                        Egnos
                        Hi @Sean is there any news for this module?
                        Does it work now?
                        Thank you very much.
                          A Former User @Egnos
                          @Egnos
                          No, sorry. It is out of my work.
