    how to set module div for fullscreen
    6 Posts 2 Posters 3.4k Views 2 Watching
      I am trying to fix MMM-ImagePhotos and MMM-Slideshow to not truncate portrait images or zoom in some landscape images…
      i have them almost completely fixed, except a small section of the screen at the bottom starting in the middle of the rss feed output and below…
      https://www.dropbox.com/s/jnudtn8wpef4ba5/IMG_20180925_125325.jpg?dl=0
      https://www.dropbox.com/s/gt1nxxwxkymgyic/IMG_20180925_125340.jpg?dl=0
      the updated code does
                      // create the div for this module
                             // set its size to the full display area
      			wrapper.style.width  = document.body.clientWidth;
      			wrapper.style.height = document.body.clientHeight;
                              // set the div position
      			wrapper.style.left = 0;
      		        wrapper.style.top = document.body.clientHeight;
                              // make position relative
      			wrapper.style.position = "relative";
                             // set a background color to improve the looks
      			wrapper.style.backgroundColor = self.config.backgroundColor;
      			// turn off any border
      			wrapper.style.border = "none";
                              // use users opacity setting
      			wrapper.style.opacity = self.config.opacity;
      if I use position=“absolute” for the div it looks like this
      https://www.dropbox.com/s/k0i4hror1rx9tp5/IMG_20180925_125427.jpg?dl=0
      how can I get rid of the bottom bar?
      it looks worse on a different tv (both devices are TVs, not monitors)
      https://www.dropbox.com/s/shly9zuo8hhb3bn/IMG_20180925_125243.jpg?dl=0
      why don’t my pics show when I use the Picture info wrapper?
        so close…
        client Height/Width is the screen, but the body has height/width reduced by margins…
        how can I get the size of the margin in javascript to do the corrections programatically?
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @sdetweil
          @sdetweil there are units called view width and view height, try those
          100vw and 100vh
            sdetweil @strawberry 3.141
            @strawberry-3-141 thanks… sadly this re-introduces the margins in both dimensions
              here is another way.
              window.getComputedStyle(document.body).getPropertyValue('margin-top');
              now… i forgot that I had a custom.css to eliminate the margins.
              but the fullscreen style still has the -60 adjustments for the default border
                Using the fullscreens.above class for the div makes this a lot easier. No modification of the std css is required
