how to set module div for fullscreen
I am trying to fix MMM-ImagePhotos and MMM-Slideshow to not truncate portrait images or zoom in some landscape images…
i have them almost completely fixed, except a small section of the screen at the bottom starting in the middle of the rss feed output and below…
https://www.dropbox.com/s/jnudtn8wpef4ba5/IMG_20180925_125325.jpg?dl=0https://www.dropbox.com/s/gt1nxxwxkymgyic/IMG_20180925_125340.jpg?dl=0
the updated code does// create the div for this module var wrapper = document.createElement("div"); // set its size to the full display area wrapper.style.width = document.body.clientWidth; wrapper.style.height = document.body.clientHeight; // set the div position wrapper.style.left = 0; wrapper.style.top = document.body.clientHeight; // make position relative wrapper.style.position = "relative"; // set a background color to improve the looks wrapper.style.backgroundColor = self.config.backgroundColor; // turn off any border wrapper.style.border = "none"; // use users opacity setting wrapper.style.opacity = self.config.opacity;if I use position=“absolute” for the div it looks like this
https://www.dropbox.com/s/k0i4hror1rx9tp5/IMG_20180925_125427.jpg?dl=0
how can I get rid of the bottom bar?
it looks worse on a different tv (both devices are TVs, not monitors)
https://www.dropbox.com/s/shly9zuo8hhb3bn/IMG_20180925_125243.jpg?dl=0why don’t my pics show when I use the Picture info wrapper?
so close…
client Height/Width is the screen, but the body has height/width reduced by margins…
how can I get the size of the margin in javascript to do the corrections programatically?
@sdetweil there are units called view width and view height, try those
100vwand100vh -
@strawberry-3-141 thanks… sadly this re-introduces the margins in both dimensions
here is another way.
window.getComputedStyle(document.body).getPropertyValue('margin-top');now… i forgot that I had a custom.css to eliminate the margins.
but the fullscreen style still has the -60 adjustments for the default border
Using the fullscreens.above class for the div makes this a lot easier. No modification of the std css is required
