    MMM-Timetable
    43 Posts 12 Posters 27.6k Views 13 Watching
    • V
      Vauxdvihl
      @Sean
      Thanks a lot for this module
      For testing i have simply copied your example to my config.
      But i am not able to get it running
      The screen stays black
      Any idea
      Do i have to use the lastest version of the magic mirror sw?
      Thanks a lot
      Greetz
      0|mm       | Shutting down server...
      0|mm       | > magicmirror@2.4.1 start /home/pi/MagicMirror
      0|mm       | > sh run-start.sh
      0|mm       | Starting MagicMirror: v2.4.1
      0|mm       | Loading config ...
      0|mm       | Loading module helpers ...
      0|mm       | No helper found for module: clock.
      0|mm       | No helper found for module: alert.
      0|mm       | No helper found for module: MMM-Timetable.
      0|mm       | All module helpers loaded.
      0|mm       | Starting server on port 8080 ...
      0|mm       | Server started ...
      0|mm       | Sockets connected & modules started ...
      0|mm       | Launching application.
        //disabled:true,
        module: "MMM-Timetable",
          timeFormat: "hh:mm A",
          height: "800px",
          width: "150px",
          mode: "5days", // "today", "5days", "7days"
          refreshInterval: 1000*60,
          displayEndTime:true, //whether display endTime on timeline or not.
          schedules: [ //array of schedules
              title: "Slytherin 2nd Year",
              file: null, // or "test.csv" - comma separated text file. (see `test.csv`)
              schedule: [
                // [weekday, starttime(24h), endtime(24h), title, subtitle, backgroundColor(optional)]
                // weekday : 1 for Monday, 2 for Tuesday, ... 7 for Sunday
                [1, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                [2, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                [3, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                [4, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                [5, "0730", "0900", "Breakfast", "", "rgba(0,255,0, 0.5)"],
                [1, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                [2, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                [3, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                [4, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                [5, "1200", "1300", "Lunch", "", "rgba(0,255,0, 0.5)"],
                [1, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                [2, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                [3, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                [4, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                [5, "1800", "1900", "Dinner", "", "rgba(0,255,0, 0.5)"],
                [1, "1100", "1145", "Transfiguration", "w/Ravenclaw"],
                [1, "1315", "1400", "Charms", "w/Hufflepuff"],
                [2, "0915", "1045", "Transfiguration", "w/Ravenclaw"],
                [2, "1500", "1630", "Herbology", "w/Ravenclaw"],
                [3, "0915", "1045", "Defense Against The Dark Art", "w/Gryffindor", "rgba(255,0,0,0.5)"],
                [3, "1100", "1145", "Charms", "w/Hufflepuff"],
                [3, "1315", "1445", "History of Magic", "w/Hufflepuff"],
                [3, "1500", "1630", "Potions", "w/Gryffindor"],
                [4, "1100", "1145", "Defense Against The Dark Art", "w/Gryffindor"],
                [5, "1315", "1400", "Potions", "w/Gryffindor"],
              title: "Slytherin 2nd Year (only classes)",
              schedule: [
      ? 1 Reply Last reply
        A Former User @Vauxdvihl
        @vauxdvihl
        I have no problem…
        Try this;
              //disabled:true,
                file:"test.csv"
        Or just
        V 1 Reply Last reply
        • V
          Vauxdvihl
          @sean said in MMM-Timetable:
          module: “MMM-Timetable”,
          position: “top_right”,
          This is strange
          No error message and nothing shown on the screen
          I have generated a test config file (contains only the timeline)
          Hmm i need to check it
          • V
            Vauxdvihl
            • V
              Vauxdvihl @Guest
              @sean
              I have done it
              • V
                Vauxdvihl @Vauxdvihl
                @Sean
                Can i change the timeformat to European one?
                like 22:30?
                  @vauxdvihl
                  Set timeFormat as “HH:mm”
                  • V
                    Vauxdvihl
                    @Sean
                    Thanks it works
                    But i see there comes something strange
                    Setting these value to “HH:MM” the time datas from my conifg are not matching with the displayed datas.
                    Can you reproduce this?
                    Regards
                      @vauxdvihl
                      Not ‘HH:MM’, it’s ‘HH:mm’
                      • V
                        Vauxdvihl @Guest
                        @sean
                        Thanks a lot
                        • L
                          lovesicker
                          @Sean
                          How can I redefine the rows to equal altitude, regardless of time interval? I’d like to define equal altitude for each rows.
                          Could you or anyone give me some suggestions? Thanks in advance.
                            A Former User @lovesicker
                            @lovesicker
                            Not possible currently. Heights are dependent on duration.
                            I’ll consider it on next update but You’d better to display static table your own with some iframe or html module.(My MMM-HTMLBox can show static html on MM)
                            L 1 Reply Last reply
                            • L
                              lovesicker @Guest
                              @Sean
                              OK, I got it. Thanks for your reply.Let me try your MMM-HTMLBox.
                              Hahahah, I found I already become one of your fans. After trying out a module several days,I found it is coded by you,ig.,MMM-GroveGesture,MMM-CalendarExt.
                              I’m looking forward to next version about MMM-Timetable.
                              Have a good day!
                              • L
                                lovesicker @lovesicker
                                @Sean
                                Another problem: under the MMM-page or MMM-page-select module environment, when you start MagicMirror, sometimes you will see the following MMM-Timeable UI:
                                Until the modules refresh, the UI will be OK:
                                The issue only happened when Magic Mirror start. I know this is not a serious problem because you will not frequently restart Magic Mirror and switch to the MMM-Timeable page.
                                Do you have some suggestions about it?
                                ? 2 Replies Last reply
                                  @lovesicker
                                  This module would detect it’s position and dimensions to draw itself. To calculate proper size it needs. On start and each refresh interval it will recalculate.
                                  But some page modules prevent this detection by hiding module on start. And will show this module suddenly so module cannot have proper values. Of course after showing, on the next refeshing period, it could complete detection then will be no more problem.
                                  To avoid this, put this module on first page or shorten refreshing time.
                                    @lovesicker
                                    In a few days, I’ll look inside my code and try to make its work better way. I think I can add recalculation logic on module’s resume.
                                    Anyway, so many courses. :D. but it’s usual in Far east Asia like China and Korea. I’m from Korea, but living in Germany now… In my highschool days of Korea, My classes began at 7:00AM and finished at 10:00PM LITERALLY. Not so worst to me but… :)
                                    L Cr4z33C 2 Replies Last reply
                                    • L
                                      lovesicker @Guest
                                      @Sean
                                      Hahaha, it’s my son’s school timetable. He is only ten years old. He like this timetable very much. I told him a foreign uncle coded this timetable for him. He is very pride for it…
                                      Thank you so much for bringing much happiness to our family.
                                      • Cr4z33C
                                        Cr4z33 @Guest
                                        @Sean said in MMM-Timetable:
                                        :face_screaming_in_fear: :dizzy_face:
                                          A Former User @Cr4z33
                                          @Cr4z33
                                          30 years ago, that was usual for who wanted to enter Univ. in S.Korea. :D
                                          Nowadays, Highschool itself doesn’t go that way, but Students are studying very hard personally at Home or private institutes or with private teachers to take better score.
                                          Cr4z33C 1 Reply Last reply
                                          • Cr4z33C
                                            Cr4z33 @Guest
                                            @Sean alright that makes sense then. :grinning_face_with_smiling_eyes:
                                            • 2 / 3
