    MMM-Timetable
    43 Posts 12 Posters 23.5k Views 13 Watching
      A Former User @Vauxdvihl
      @vauxdvihl
      Set timeFormat as “HH:mm”
      • V Offline
        Vauxdvihl
        @Sean
        Thanks it works
        But i see there comes something strange
        Setting these value to “HH:MM” the time datas from my conifg are not matching with the displayed datas.
        Can you reproduce this?
        Regards
          @vauxdvihl
          Not ‘HH:MM’, it’s ‘HH:mm’
          • V Offline
            Vauxdvihl @Guest
            @sean
            Thanks a lot
            • L Offline
              lovesicker
              @Sean
              How can I redefine the rows to equal altitude, regardless of time interval? I’d like to define equal altitude for each rows.
              Could you or anyone give me some suggestions? Thanks in advance.
                A Former User @lovesicker
                @lovesicker
                Not possible currently. Heights are dependent on duration.
                I’ll consider it on next update but You’d better to display static table your own with some iframe or html module.(My MMM-HTMLBox can show static html on MM)
                • L Offline
                  lovesicker @Guest
                  @Sean
                  OK, I got it. Thanks for your reply.Let me try your MMM-HTMLBox.
                  Hahahah, I found I already become one of your fans. After trying out a module several days,I found it is coded by you,ig.,MMM-GroveGesture,MMM-CalendarExt.
                  I’m looking forward to next version about MMM-Timetable.
                  Have a good day!
                  • L Offline
                    lovesicker @lovesicker
                    @Sean
                    Another problem: under the MMM-page or MMM-page-select module environment, when you start MagicMirror, sometimes you will see the following MMM-Timeable UI:
                    Until the modules refresh, the UI will be OK:
                    The issue only happened when Magic Mirror start. I know this is not a serious problem because you will not frequently restart Magic Mirror and switch to the MMM-Timeable page.
                    Do you have some suggestions about it?
                      @lovesicker
                      This module would detect it’s position and dimensions to draw itself. To calculate proper size it needs. On start and each refresh interval it will recalculate.
                      But some page modules prevent this detection by hiding module on start. And will show this module suddenly so module cannot have proper values. Of course after showing, on the next refeshing period, it could complete detection then will be no more problem.
                      To avoid this, put this module on first page or shorten refreshing time.
                        @lovesicker
                        In a few days, I’ll look inside my code and try to make its work better way. I think I can add recalculation logic on module’s resume.
                        Anyway, so many courses. :D. but it’s usual in Far east Asia like China and Korea. I’m from Korea, but living in Germany now… In my highschool days of Korea, My classes began at 7:00AM and finished at 10:00PM LITERALLY. Not so worst to me but… :)
                        L Cr4z33C 2 Replies Last reply Reply Quote 0
                        • 3 / 5
