    MMM-Timetable
    43 Posts 12 Posters 26.5k Views 13 Watching
    • V Offline
      Vauxdvihl
      • V Offline
        Vauxdvihl @Guest
        @sean
        I have done it
        • V Offline
          Vauxdvihl @Vauxdvihl
          @Sean
          Can i change the timeformat to European one?
          like 22:30?
            A Former User @Vauxdvihl
            @vauxdvihl
            Set timeFormat as “HH:mm”
            • V Offline
              Vauxdvihl
              @Sean
              Thanks it works
              But i see there comes something strange
              Setting these value to “HH:MM” the time datas from my conifg are not matching with the displayed datas.
              Can you reproduce this?
              Regards
                @vauxdvihl
                Not ‘HH:MM’, it’s ‘HH:mm’
                • V Offline
                  Vauxdvihl @Guest
                  @sean
                  Thanks a lot
                  • L Offline
                    lovesicker
                    @Sean
                    How can I redefine the rows to equal altitude, regardless of time interval? I’d like to define equal altitude for each rows.
                    Could you or anyone give me some suggestions? Thanks in advance.
                      A Former User @lovesicker
                      @lovesicker
                      Not possible currently. Heights are dependent on duration.
                      I’ll consider it on next update but You’d better to display static table your own with some iframe or html module.(My MMM-HTMLBox can show static html on MM)
                      • L Offline
                        lovesicker @Guest
                        @Sean
                        OK, I got it. Thanks for your reply.Let me try your MMM-HTMLBox.
                        Hahahah, I found I already become one of your fans. After trying out a module several days,I found it is coded by you,ig.,MMM-GroveGesture,MMM-CalendarExt.
                        I’m looking forward to next version about MMM-Timetable.
                        Have a good day!
                        • L Offline
                          lovesicker @lovesicker
                          @Sean
                          Another problem: under the MMM-page or MMM-page-select module environment, when you start MagicMirror, sometimes you will see the following MMM-Timeable UI:
                          Until the modules refresh, the UI will be OK:
                          The issue only happened when Magic Mirror start. I know this is not a serious problem because you will not frequently restart Magic Mirror and switch to the MMM-Timeable page.
                          Do you have some suggestions about it?
                            @lovesicker
                            This module would detect it’s position and dimensions to draw itself. To calculate proper size it needs. On start and each refresh interval it will recalculate.
                            But some page modules prevent this detection by hiding module on start. And will show this module suddenly so module cannot have proper values. Of course after showing, on the next refeshing period, it could complete detection then will be no more problem.
                            To avoid this, put this module on first page or shorten refreshing time.
                              @lovesicker
                              In a few days, I’ll look inside my code and try to make its work better way. I think I can add recalculation logic on module’s resume.
                              Anyway, so many courses. :D. but it’s usual in Far east Asia like China and Korea. I’m from Korea, but living in Germany now… In my highschool days of Korea, My classes began at 7:00AM and finished at 10:00PM LITERALLY. Not so worst to me but… :)
                              L Cr4z33C 2 Replies Last reply Reply Quote 0
                              • L Offline
                                lovesicker @Guest
                                @Sean
                                Hahaha, it’s my son’s school timetable. He is only ten years old. He like this timetable very much. I told him a foreign uncle coded this timetable for him. He is very pride for it…
                                Thank you so much for bringing much happiness to our family.
                                • Cr4z33C Offline
                                  Cr4z33 @Guest
                                  @Sean said in MMM-Timetable:
                                  :face_screaming_in_fear: :dizzy_face:
                                    A Former User @Cr4z33
                                    @Cr4z33
                                    30 years ago, that was usual for who wanted to enter Univ. in S.Korea. :D
                                    Nowadays, Highschool itself doesn’t go that way, but Students are studying very hard personally at Home or private institutes or with private teachers to take better score.
                                    • Cr4z33C Offline
                                      Cr4z33 @Guest
                                      @Sean alright that makes sense then. :grinning_face_with_smiling_eyes:
                                      • F Offline
                                        FlorianSchwemin
                                        @Sean Thanks for the great module. Is it possible, to use it to display more than one Timetable on the same screen? Loading the module twice doesn’t seem to work. Tried renaming it (and the files) to MMM-Timetable2 but this does only draw the Lines but does not fill it from the csv-File. Do you have any tips, where to tweak?
                                        Thanks!
                                        • F Offline
                                          FlorianSchwemin @FlorianSchwemin
                                          @FlorianSchwemin Nevermind, already got it. Renamed all TTABLE in the .js and .css in my new modules/MMM-Timetable2 folder to TTABLE2 and it runs just as I wanted it to. Thanks nonetheless
                                            matze86
                                            Hey,
                                            this module is really awesome!
                                            I want to change the style of title. In your example " title: “Slytherin 2nd Year”,", but i don’t know where to find it in the css.
                                            #TTABLE .header changes the weekdays
                                            #TTABLE .title changes the name of the lessons
                                            thx in advance
                                            • 2 / 3
