Updating problem: "commit your changes or stash them before you can merge" ???
6 Posts 4 Posters 8.4k Views 5 Watching
    amanzimdwini
    SHOULD have been easy (and yes, I am patched / updated / upgraded / have node v10 etc)
    pi@bathMM2:~/MagicMirror $ sudo git pull && npm install
    error: Your local changes to the following files would be overwritten by merge:
            .gitignore
            CHANGELOG.md
            Gruntfile.js
            README.md
            js/main.js
            js/module.js
            modules/default/alert/alert.js
            modules/default/calendar/README.md
            modules/default/calendar/calendar.js
            modules/default/calendar/calendarfetcher.js
            modules/default/compliments/README.md
            modules/default/compliments/compliments.js
            modules/default/currentweather/currentweather.js
            modules/default/newsfeed/README.md
            modules/default/newsfeed/fetcher.js
            modules/default/newsfeed/newsfeed.js
            modules/default/newsfeed/node_helper.js
            modules/default/weatherforecast/README.md
            modules/default/weatherforecast/weatherforecast.js
            package-lock.json
            package.json
            translations/de.json
            translations/en.json
            translations/it.json
            translations/nl.json
            translations/translations.js
            vendor/package-lock.json
    Please, commit your changes or stash them before you can merge.
    error: The following untracked working tree files would be overwritten by merge:
            translations/pt-br.json
            translations/zh-cn.json
            translations/zh-tw.json
    Please move or remove them before you can merge.
    Aborting
    Interesting - but (a) what does it mean and (b) how do I proceed?
    Thanks,
    Karl
    • E Offline
      eniac
      Same Problem here, but only css/main.css is effected.
      What can we do ?
      J 1 Reply Last reply Oct 9, 2018, 10:02 PM Reply Quote 0
        justjim1220 Module Developer @eniac
        @amanzimdwini @eniac
        rename or delete them and try again
        rename to save the changes you made
        You can also rename the folder by adding _bak
        or you can move those files out of their directories, like create a separate directory that has a different name than any other folder in MagicMirror.
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
        • Y Offline
          yep_DD
          git stash //stash your changes and save them
          git pull //update to current version
          git stash pop //merge your stash back
          J 1 Reply Last reply Oct 10, 2018, 1:04 AM Reply Quote 4
            justjim1220 Module Developer @yep_DD
            @yep_dd
            Thanks! Wish I knew this before. Seems a lot easier than what I’ve been doing!!! :smirking_face:
            Jim Hallock - 1995
            • E Offline
              eniac
              Thanks … Work for me :-)
