MMM-AssistantMk2 Problem with Blackscreen
Hello, I would like to use the google assistant on my Magic Mirror. I installed the module, logged in to googel and updated the config file.
{ module: "MMM-AssistantMk2", position: "top_left", config: {} },if I restart now the magic mirror comes simply only a black screen without error message. If the code is removed from the config then the magic mirror works normally again.
I have the module: MMM-Hotword not installed can it be due? Do I have to install the module at all? I would be enough if I could activate the mirror with “Hello Google”.
If someone could help me with my problem I would be very happy.
Greeting Volker
@seppel1078 said in MMM-AssistantMk2 Problem with Blackscreen:
NODE_MODULE_VERSION 59. This version of Node.js requires
NODE_MODULE_VERSION 57. Please try re-compiling or re-installingThis is the reason.
See https://github.com/eouia/MMM-AssistantMk2#installation -
@seppel1078
First, For more details (error logs) are needed. Seenpm start devresult orpm2 show log
Second,MMM-AssistantMk2itself has no awakening method except a smiple mic-icon clicking. It should be activated by other trigger (e.g: hotword detection from MMM-Hotword, or some notification from other module)
And last, “Hello Google” or “Ok Google” hotword is not supported by SNOWBOY Hotword detection engine (MMM-Hotword) by itself.
You can contact me;
email : eouia0819@gmail.com
Telegram :@eouia
or github issue board : https://github.com/eouia/MMM-AssistantMk2/issues -
her is my log:
0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ] 2 info using npm@6.4.1 3 info using node@v9.11.2 4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig) 5 verbose stack Error: missing script: start 5 verbose stack at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19) 5 verbose stack at /usr/lib/node_modules/npm/lib/run-script.js:63:5 5 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5 5 verbose stack at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:418:5 5 verbose stack at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:373:45) 5 verbose stack at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:416:3) 5 verbose stack at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5) 5 verbose stack at ReadFileContext.<anonymous> (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:332:20) 5 verbose stack at ReadFileContext.callback (/usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:78:16) 5 verbose stack at FSReqWrap.readFileAfterOpen [as oncomplete] (fs.js:434:13) 6 verbose cwd /home/pi 7 verbose Linux 4.14.71-v7+ 8 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev" 9 verbose node v9.11.2 10 verbose npm v6.4.1 11 error missing script: start 12 verbose exit [ 1, true ] -
@seppel1078
npm start devshould be executed in root of ‘MagicMirror’ directory.cd ~/MagicMirror npm start dev(And if you were using
pm2previously,pm2 stop mmbefore execution) -
pi@raspberrypi3:~/MagicMirror $ npm start dev > magicmirror@2.5.0 start /home/pi/MagicMirror > sh run-start.sh "dev" Starting MagicMirror: v2.5.0 Loading config ... Loading module helpers ... No helper found for module: alert. WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/build/Release/binding.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 59. This version of Node.js requires NODE_MODULE_VERSION 57. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`). Loading module helpers ... No helper found for module: alert. App threw an error during load Error: The module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/build/Release/binding.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 59. This version of Node.js requires NODE_MODULE_VERSION 57. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`). at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:172:20) at Object.Module._extensions..node (module.js:671:18) at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:172:20) at Module.load (module.js:561:32) at tryModuleLoad (module.js:504:12) at Function.Module._load (module.js:496:3) at Module.require (module.js:586:17) at require (internal/module.js:11:18) at bindings (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/bindings/bindings.js:81:44) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:9:36) Whoops! There was an uncaught exception... Error: The module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/build/Release/binding.node' was compiled against a different Node.js version using NODE_MODULE_VERSION 59. This version of Node.js requires NODE_MODULE_VERSION 57. Please try re-compiling or re-installing the module (for instance, using `npm rebuild` or `npm install`). at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:172:20) at Object.Module._extensions..node (module.js:671:18) at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:172:20) at Module.load (module.js:561:32) at tryModuleLoad (module.js:504:12) at Function.Module._load (module.js:496:3) at Module.require (module.js:586:17) at require (internal/module.js:11:18) at bindings (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/bindings/bindings.js:81:44) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:9:36) MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues Launching application. -
I’ll try that out. Thanks for the quick help so far
now the magic mirror starts normally. Many thanks for the help
Can you please share the config file used for MMM-AssistantMk2. I am also getting same black screen issue with cursor. What step you took for solving this issue.
@sunilkvr
module: “MMM-AssistantMk2”,
position: “top_right”,
useWelcomeMessage: “brief today”
},this simple config should work just for testing and making sure the module loads.
I ended up fixing mine by rolling back to grpc 1.2 and gcc7 then rebuilding the binaries. Took about an hour on my pi 2, but its up and running now.
