    MMM-AssistantMk2 Problem with Blackscreen
    10 Posts 4 Posters 4.1k Views 4 Watching
      seppel1078
      her is my log:
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ]
      2 info using npm@6.4.1
      3 info using node@v9.11.2
      4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
      5 verbose stack Error: missing script: start
      5 verbose stack     at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19)
      5 verbose stack     at /usr/lib/node_modules/npm/lib/run-script.js:63:5
      5 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
      5 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:418:5
      5 verbose stack     at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:373:45)
      5 verbose stack     at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:416:3)
      5 verbose stack     at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
      5 verbose stack     at ReadFileContext.<anonymous> (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:332:20)
      5 verbose stack     at ReadFileContext.callback (/usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:78:16)
      5 verbose stack     at FSReqWrap.readFileAfterOpen [as oncomplete] (fs.js:434:13)
      6 verbose cwd /home/pi
      7 verbose Linux 4.14.71-v7+
      8 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
      9 verbose node v9.11.2
      10 verbose npm  v6.4.1
      11 error missing script: start
      12 verbose exit [ 1, true ]
        A Former User @seppel1078
        @seppel1078
        npm start dev should be executed in root of ‘MagicMirror’ directory.
        npm start dev
        (And if you were using pm2 previously, pm2 stop mm before execution)
          seppel1078
          pi@raspberrypi3:~/MagicMirror $ npm start dev
          > magicmirror@2.5.0 start /home/pi/MagicMirror
          > sh run-start.sh "dev"
          Starting MagicMirror: v2.5.0
          Loading config ...
          Loading module helpers ...
          WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/build/Release/binding.node'
          was compiled against a different Node.js version using
          NODE_MODULE_VERSION 59. This version of Node.js requires
          NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
          the module (for instance, using `npm rebuild` or `npm install`).
          App threw an error during load
              at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:172:20)
              at Object.Module._extensions..node (module.js:671:18)
              at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:172:20)
              at Module.load (module.js:561:32)
              at tryModuleLoad (module.js:504:12)
              at Function.Module._load (module.js:496:3)
              at Module.require (module.js:586:17)
              at require (internal/module.js:11:18)
              at bindings (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/bindings/bindings.js:81:44)
              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:9:36)
          Launching application.
            @seppel1078 said in MMM-AssistantMk2 Problem with Blackscreen:
            This is the reason.
            See https://github.com/eouia/MMM-AssistantMk2#installation
              seppel1078
              I’ll try that out. Thanks for the quick help so far
                seppel1078
                now the magic mirror starts normally. Many thanks for the help
                  sunilkvr @seppel1078
                  @seppel1078
                  Can you please share the config file used for MMM-AssistantMk2. I am also getting same black screen issue with cursor. What step you took for solving this issue.
                    Doghaus96 @sunilkvr
                    @sunilkvr
                    module: “MMM-AssistantMk2”,
                    position: “top_right”,
                    useWelcomeMessage: “brief today”
                    this simple config should work just for testing and making sure the module loads.
                    I ended up fixing mine by rolling back to grpc 1.2 and gcc7 then rebuilding the binaries. Took about an hour on my pi 2, but its up and running now.
