    MMM-AssistantMk2 Problem with Blackscreen
    10 Posts 4 Posters 4.1k Views 4 Watching
      seppel1078
      pi@raspberrypi3:~/MagicMirror $ npm start dev
      > magicmirror@2.5.0 start /home/pi/MagicMirror
      > sh run-start.sh "dev"
      Starting MagicMirror: v2.5.0
      Loading config ...
      Loading module helpers ...
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/build/Release/binding.node'
      was compiled against a different Node.js version using
      NODE_MODULE_VERSION 59. This version of Node.js requires
      NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
      the module (for instance, using `npm rebuild` or `npm install`).
      App threw an error during load
          at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:172:20)
          at Object.Module._extensions..node (module.js:671:18)
          at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:172:20)
          at Module.load (module.js:561:32)
          at tryModuleLoad (module.js:504:12)
          at Function.Module._load (module.js:496:3)
          at Module.require (module.js:586:17)
          at require (internal/module.js:11:18)
          at bindings (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/bindings/bindings.js:81:44)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:9:36)
      Launching application.
        A Former User @seppel1078
        @seppel1078 said in MMM-AssistantMk2 Problem with Blackscreen:
        This is the reason.
        See https://github.com/eouia/MMM-AssistantMk2#installation
          seppel1078
          I’ll try that out. Thanks for the quick help so far
            seppel1078
            now the magic mirror starts normally. Many thanks for the help
              sunilkvr @seppel1078
              @seppel1078
              Can you please share the config file used for MMM-AssistantMk2. I am also getting same black screen issue with cursor. What step you took for solving this issue.
                Doghaus96 @sunilkvr
                @sunilkvr
                module: “MMM-AssistantMk2”,
                position: “top_right”,
                useWelcomeMessage: “brief today”
                this simple config should work just for testing and making sure the module loads.
                I ended up fixing mine by rolling back to grpc 1.2 and gcc7 then rebuilding the binaries. Took about an hour on my pi 2, but its up and running now.
