    MMM-AssistantMk2 Problem with Blackscreen
    10 Posts 4 Posters 4.3k Views 4 Watching
      seppel1078
      Hello, I would like to use the google assistant on my Magic Mirror. I installed the module, logged in to googel and updated the config file.
        module: "MMM-AssistantMk2",
        config: {}
      if I restart now the magic mirror comes simply only a black screen without error message. If the code is removed from the config then the magic mirror works normally again.
      I have the module: MMM-Hotword not installed can it be due? Do I have to install the module at all? I would be enough if I could activate the mirror with “Hello Google”.
      If someone could help me with my problem I would be very happy.
      Greeting Volker
        A Former User @seppel1078
        @seppel1078 said in MMM-AssistantMk2 Problem with Blackscreen:
        NODE_MODULE_VERSION 59. This version of Node.js requires
        NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
        This is the reason.
        See https://github.com/eouia/MMM-AssistantMk2#installation
          @seppel1078
          First, For more details (error logs) are needed. See npm start dev result or pm2 show log
          Second, MMM-AssistantMk2 itself has no awakening method except a smiple mic-icon clicking. It should be activated by other trigger (e.g: hotword detection from MMM-Hotword, or some notification from other module)
          And last, “Hello Google” or “Ok Google” hotword is not supported by SNOWBOY Hotword detection engine (MMM-Hotword) by itself.
          You can contact me;
          email : eouia0819@gmail.com
          Telegram : @eouia
          or github issue board : https://github.com/eouia/MMM-AssistantMk2/issues
            seppel1078
            her is my log:
            1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ]
            2 info using npm@6.4.1
            3 info using node@v9.11.2
            4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
            5 verbose stack Error: missing script: start
            5 verbose stack     at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19)
            5 verbose stack     at /usr/lib/node_modules/npm/lib/run-script.js:63:5
            5 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
            5 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:418:5
            5 verbose stack     at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:373:45)
            5 verbose stack     at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:416:3)
            5 verbose stack     at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
            5 verbose stack     at ReadFileContext.<anonymous> (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:332:20)
            5 verbose stack     at ReadFileContext.callback (/usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:78:16)
            5 verbose stack     at FSReqWrap.readFileAfterOpen [as oncomplete] (fs.js:434:13)
            6 verbose cwd /home/pi
            7 verbose Linux 4.14.71-v7+
            8 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
            9 verbose node v9.11.2
            10 verbose npm  v6.4.1
            11 error missing script: start
            12 verbose exit [ 1, true ]
              @seppel1078
              npm start dev should be executed in root of ‘MagicMirror’ directory.
              npm start dev
              (And if you were using pm2 previously, pm2 stop mm before execution)
                seppel1078
                pi@raspberrypi3:~/MagicMirror $ npm start dev
                > magicmirror@2.5.0 start /home/pi/MagicMirror
                > sh run-start.sh "dev"
                Starting MagicMirror: v2.5.0
                Loading config ...
                Loading module helpers ...
                WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/build/Release/binding.node'
                was compiled against a different Node.js version using
                the module (for instance, using `npm rebuild` or `npm install`).
                App threw an error during load
                    at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:172:20)
                    at Object.Module._extensions..node (module.js:671:18)
                    at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:172:20)
                    at Module.load (module.js:561:32)
                    at tryModuleLoad (module.js:504:12)
                    at Function.Module._load (module.js:496:3)
                    at Module.require (module.js:586:17)
                    at require (internal/module.js:11:18)
                    at bindings (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/bindings/bindings.js:81:44)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:9:36)
                Launching application.
                  This is the reason.
                    seppel1078
                    I’ll try that out. Thanks for the quick help so far
                      seppel1078
                      now the magic mirror starts normally. Many thanks for the help
                        sunilkvr @seppel1078
                        @seppel1078
                        Can you please share the config file used for MMM-AssistantMk2. I am also getting same black screen issue with cursor. What step you took for solving this issue.
                          Doghaus96 @sunilkvr
                          @sunilkvr
                          module: “MMM-AssistantMk2”,
                          position: “top_right”,
                          useWelcomeMessage: “brief today”
                          this simple config should work just for testing and making sure the module loads.
                          I ended up fixing mine by rolling back to grpc 1.2 and gcc7 then rebuilding the binaries. Took about an hour on my pi 2, but its up and running now.
