    how to pull new element added to an array?
    57 Posts 4 Posters 28.7k Views 4 Watching
      sdetweil @justjim1220
      @justjim1220 no, not really…
      • justjim1220J
        justjim1220 Module Developer @sdetweil
        ok, just a thought, seen it with a few other modules. Thanks!
        Jim Hallock - 1995
          @justjim1220 any idea why the newsticker doesn’t work at all?
          u don’t have a package.json, so the install instructions for npm install is not needed…
          justjim1220J 2 Replies Last reply Reply Quote 0
          • justjim1220J
            No, no idea, one of the reasons I uploaded it as a repository, to let you and whoever else wants to gander at it and see what the issues are or could be.
            Not sure when you downloaded it, but I made some minor changes to it a few hours ago. just some syntax errors and such.
            Nonetheless, still can’t get it to work.
            Jim Hallock - 1995
              @justjim1220 yeh, I just want to get default behavior working… I have added my code, it should work, just want to test…
              • justjim1220J
                kind of an example of what I am looking to accomplish…
                Only, instead of the title on the left side, I am wanting to show the logo associated with the newsfeed.
                Like this:
                Jim Hallock - 1995
                  @justjim1220 understood…
                  i just can’t get the module to do ANYTHING…
                  it loads, and registers, and that is it… no functions are called…
                  • justjim1220J
                    I’m not understanding it myself, I’ll keep plugging away at it.
                    Feel free to collaborate on it any time you feel like it.
                    Thanks for all your help thus far! :winking_face:
                    Jim Hallock - 1995
                      @justjim1220 I added all the defined functions and none are called…
                      • justjim1220J
                        What I meant was that I added you as a collaborator
                        Maybe this way you can show what you did and I could look at it as well
                        Jim Hallock - 1995
                          A Former User @justjim1220
                          @justjim1220 @sdetweil
                          First, in line 18 of MMM-NewsFeedTicker.js
                          Module.register("MMM-NewsFeedTicker", {
                            A Former User
                            I don’t know what @justjim1220 expect(So, I don’t request PR), but anyway, it’s executable now.
                            https://github.com/eouia/MMM-NewsFeedTicker
                            https://github.com/justjim1220/MMM-NewsFeedTicker/commit/64f5aae290682725ce2b8a1a64dd2771dfbd83c3
                            Just executable. I think there might be many things to improve or fix.
                              A Former User
                              I think this is similar with what you really want to get.
                              https://www.dropbox.com/s/9u4bjaimhlrnzfj/MMM-NewsFeedTickerX.zip?dl=0
                              At first, I tried with your repository, but it seems so many things to modify. So I worked with original newsfeed. I wish you good luck.
                              S justjim1220J 2 Replies Last reply Reply Quote 0
                                sdetweil @Guest
                                @justjim1220 thanks. Woke in the middle of the night thinking that needed to match module name…
                                Haven’t tried it yet!
                                  i have posted my almost working code to your github project in a new branch.
                                  the image url is extracted, saved and added to each rss feed response item.
                                  that url is used in the image.src attribute for the getDom function…
                                  BUT… the url is the FULL url, and I think the web engine under MM only allows src= from LOCAL files…
                                  when u look at the debug data items, the web server base is
                                  http://0.0.0.0:configured_port
                                  meaning adding a full url on to the end of that will fail…
                                  i posted info in an issue on github on what it might take to solve that…
                                  |edit: I see that Sean has used a different ui widget (Ticker) that seems to solve this problem
                                    sdetweil @Guest
                                    @sean nicely done…
                                    • justjim1220J
                                      LOL, I woke up early this morning thinking I could get something like this to work…
                                      But, of course, I probably had something wrong somewhere, because it didn’t!!!
                                      Jim Hallock - 1995
                                      • justjim1220J
                                        justjim1220 Module Developer @Guest
                                        @sean
                                        Not sure why, but this didn’t work for me, I will try it again in a little while, probably something I’m doing wrong!
                                        Thank You!!!
                                        Jim Hallock - 1995
                                        • justjim1220J
                                          @sean
                                          This is ABSOLUTELY WONDERFUL!!!
                                          THANK YOU, THANK YOU, THANK YOU!!! :smiling_face: :smiling_face: :smiling_face:
                                          (still gonna try to get the first one going you sent link for in previous post!) :winking_face:
                                          Jim Hallock - 1995
                                            @sean and I have the same solution to GET the image url, the use of the tickertape widget which supports image is the key trick
                                            • 2 / 3
