    how to pull new element added to an array?
    57 Posts 4 Posters 29.6k Views 4 Watching
      @justjim1220 said in how to pull new element added to an array?:
      var image = item.image || item.logo || item.img || item.svg || “”;
      that looks good, except as you note, these are optional in the response (item) data.
      do you want to use the configured url for the feed if not present?
      var image = item.image || item.logo || item.img || item.svg || xxxx.yyy.icon || "";
      the feed definition is passed into the fetcher function. except that routine could have ended seconds ago, when the parser.on(item) method is called (by the callback)…
      so, what should xxxx.yyy be? can’t use the parm feed directly, as the routine could have exited already…
      so, javascript gives you the ability to bind (connect) a variable with a routine when it is called asyncronously…
      when u bind the variable, it will be accessible in the context of the function, context = this,
      so, on the close brace of the function defined on the .on(), add the .bind() clause.
      inside the bind clause, you specify the name of the variable INSIDE the function, and connect it to the variable at the time the .on() definition is called… (ie ‘feed’)…
      so,
      }.bind({feed_var_in_function:feed})
      then when the function is called, you can get access to the variable using ‘this’…
      this.feed_var_in_function.icon, would be the icon defined for THIS feed
      therefore the stmt above would be
      var image = item.image || item.logo || item.img || item.svg || this.feed_var_in_function.icon || "";
      this says, use any of the optional images in the feed item, if present,
      else use the user defined feed icon,
      else nothing if not defined…
      justjim1220J 1 Reply Last reply
      • justjim1220J
        justjim1220 Module Developer @sdetweil
        ok, so do I need to add it like this:
        parser.on("image", function(image){})
        			var title = image.title;
        			var image = image.image || image.logo || image.img || image.svg || this.feed_var_in_function.icon || "";
        			var url = image.url || image.link || "";
        Or, like this:
        Jim Hallock - 1995
        • cowboysdudeC
          Why are making this so hard?
          • justjim1220J
            justjim1220 Module Developer @cowboysdude
            @cowboysdude
            GOD, I WISH I KNEW!!!
            Jim Hallock - 1995
            • justjim1220J
              @sdetweil, @cowboysdude, @Sean
              I created a repository, hopefully it will make it easier for you to help.
              https://github.com/justjim1220/MMM-NewsFeedTicker
              ALL help is MUCH APPRECIATED!!!
              I gotta learn this stuff one way or another!
              :smiling_face_with_sunglasses:
              Jim Hallock - 1995
                sdetweil @justjim1220
                @justjim1220 I am trying to test my changes, but the module getDom() method is never called…
                changed the module name in module.js to match the file name and config module name.
                loads with no errors, shows loading the module js and registering the module…
                • justjim1220J
                  What is the possibility of using and array of sorts?
                  place the logos in a pics folder, call them according to the newsItem[activeItem].title, Ive seen some examples, and tried it a few different ways, but not sure if I am missing something as I can’t get it to work.
                  recent example tried:
                  feeds…
                                  title: "New York Times: ",
                                  title: "Wall St. Journal: ",
                                  url: "http://www.wsj.com/xml/rss/3_7085.xml"
                                  title: "USA Today: ",
                                  url: "http://rssfeeds.usatoday.com/UsatodaycomNation-TopStories"
                                  title: "BBC World News: ",
                                  url: "http://feeds.bbci.co.uk/news/world/rss.xml#"
                  Array…
                  iconArray: {
                              "USAToday": "USA Today: ",
                              "NewYorkTimes": "New York Times: ",
                              "WallStJournal": "Wall St. Journal: ",
                              "BBCWorldNews": "BBC World News: "
                  Added this to start function…
                   this.logo = {};
                  sample code…
                  var logo = this.logo;
                              if (this.config.showDescription) {
                                  var description = document.createElement("div");
                                  //description.setAttribute("style", "padding-top: 25px");
                                  description.className = "bright xlarge bold" + (!this.config.wrapDescription ? " no-wrap" : "");
                                  var txtDesc = this.newsItems[this.activeItem].description;
                                  description.innerHTML = "<img class = image src=./modules/default/newsfeed/pics/" + logo.icon + ".png height=150px valign=middle>" + "<marquee scrollamount=20 scrolldelay=0 left=500px>" + "<font color=yellow>" + moment(new Date(this.newsItems[this.activeItem].pubdate)).fromNow() + "&nbsp; : &nbsp;" + "</font>" + this.newsItems[this.activeItem].title + "&nbsp; || &nbsp;" + txtDesc + "</marquee>";
                                  wrapper.appendChild(description);
                  Any chance this could work easier if I had it coded correctly?
                  Seems Like I should be declaring the
                  to equal the icon/logo in some fashion…
                  Jim Hallock - 1995
                    @justjim1220 no, not really…
                    • justjim1220J
                      ok, just a thought, seen it with a few other modules. Thanks!
                      Jim Hallock - 1995
                        @justjim1220 any idea why the newsticker doesn’t work at all?
                        u don’t have a package.json, so the install instructions for npm install is not needed…
                        justjim1220J 2 Replies Last reply
                        • justjim1220J
                          No, no idea, one of the reasons I uploaded it as a repository, to let you and whoever else wants to gander at it and see what the issues are or could be.
                          Not sure when you downloaded it, but I made some minor changes to it a few hours ago. just some syntax errors and such.
                          Nonetheless, still can’t get it to work.
                          Jim Hallock - 1995
                            @justjim1220 yeh, I just want to get default behavior working… I have added my code, it should work, just want to test…
                            • justjim1220J
                              kind of an example of what I am looking to accomplish…
                              Only, instead of the title on the left side, I am wanting to show the logo associated with the newsfeed.
                              Like this:
                              Jim Hallock - 1995
                                @justjim1220 understood…
                                i just can’t get the module to do ANYTHING…
                                it loads, and registers, and that is it… no functions are called…
                                • justjim1220J
                                  I’m not understanding it myself, I’ll keep plugging away at it.
                                  Feel free to collaborate on it any time you feel like it.
                                  Thanks for all your help thus far! :winking_face:
                                  Jim Hallock - 1995
                                    @justjim1220 I added all the defined functions and none are called…
                                    • justjim1220J
                                      What I meant was that I added you as a collaborator
                                      Maybe this way you can show what you did and I could look at it as well
                                      Jim Hallock - 1995
                                      ? 1 Reply Last reply
                                        A Former User @justjim1220
                                        @justjim1220 @sdetweil
                                        First, in line 18 of MMM-NewsFeedTicker.js
                                        Module.register("MMM-NewsFeedTicker", {
                                          A Former User
                                          I don’t know what @justjim1220 expect(So, I don’t request PR), but anyway, it’s executable now.
                                          https://github.com/eouia/MMM-NewsFeedTicker
                                          https://github.com/justjim1220/MMM-NewsFeedTicker/commit/64f5aae290682725ce2b8a1a64dd2771dfbd83c3
                                          Just executable. I think there might be many things to improve or fix.
                                            A Former User
                                            I think this is similar with what you really want to get.
                                            https://www.dropbox.com/s/9u4bjaimhlrnzfj/MMM-NewsFeedTickerX.zip?dl=0
                                            At first, I tried with your repository, but it seems so many things to modify. So I worked with original newsfeed. I wish you good luck.
                                            S justjim1220J 2 Replies Last reply
                                            • 2 / 3
