    MM Update - GIT error
    17 Posts 4 Posters 7.8k Views 3 Watching
      Pakmann
      Hey guys,
      i want to update my MM system from version 2.1.3 -> 2.4.x.
      It looks like i am to stupid for it -.-
      I am in the MagicMirror folder an try to make an GIT pull. I received an error immediatly.
      May you have an idea for this issue ?
      sudo git pull && npm install
      error: object file .git/objects/5d/fba0b834306cc81693307ab0d1bf24e798a46a is empty
      fatal: loose object 5dfba0b834306cc81693307ab0d1bf24e798a46a (stored in .git/objects/5d/fba0b834306cc81693307ab0d1bf24e798a46a) is co                    rrupt
      fatal: The remote end hung up unexpectedly
        AxLed Module Developer
        @Pakmann
        2 ideas:
        • in which folder are you trying to run the pull? It should be /MagicMirror/
        • do it without sudo rights
        AxLED
          Pakmann
          @AxLed
          strange behaviour… i am in my root folder for MagicMirror: /home/pi/MagicMirror/
          without sudo command same result
          • justjim1220J Offline
            justjim1220 Module Developer @Pakmann
            @pakmann
            delete the file giving he error…
            "Life's Too Short To Dance With Ugly People"
            Jim Hallock - 1995
              Pakmann
              @justjim1220
              thanks a lot! This works, but now the next issue -.-
              error: refs/remotes/origin/develop does not point to a valid object!
              remote: Enumerating objects: 507, done.
              remote: Counting objects: 100% (507/507), done.
              error: object file .git/objects/36/766f9a0089766d4a0e164f3f0b198dadcf60c4 is empty
              fatal: SHA1 KOLLISION MIT 36766f9a0089766d4a0e164f3f0b198dadcf60c4 GEFUNDEN !
              fatal: index-pack fehlgeschlagen
                @pakmann
                try…
                npm rebuild
                from the MagicMirror directory
                then reboot your system
                Jim Hallock - 1995
                  Pakmann @justjim1220
                  @justjim1220 said in MM Update - GIT error:
                  @pakmann
                  try…
                  npm rebuild
                  rebuild was sucessfull, but not working. Problem still alive
                    @pakmann
                    delete the file causing new error…
                    Then rebuild again…
                    npm rebuild
                    then reboot again
                    if this doesn’t work, you may need to do the git pull && npm install again
                    Jim Hallock - 1995
                      • detele file: check
                      • npm rebuild: check
                      • reboot: check
                      • new request for git pull && npm install: same behaviour…
                      remote: Total 1591 (delta 507), reused 507 (delta 507), pack-reused 1084
                      Empfange Objekte: 100% (1591/1591), 691.80 KiB | 463.00 KiB/s, Fertig.
                      error: object file .git/objects/df/fc042df5d96cc8f7a956c12a2e002004d4cf7d is empty
                      fatal: SHA1 KOLLISION MIT dffc042df5d96cc8f7a956c12a2e002004d4cf7d GEFUNDEN !
                      justjim1220J 2 Replies Last reply Reply Quote 0
                        @pakmann
                        Well, I am not sure what is happening…
                        My best guess is to delete the .git folder then redo the git pull && npm install
                        Jim Hallock - 1995
