    MMM-MirrorMirrorOnTheWall installation issue
    138 Posts 11 Posters 203.1k Views 10 Watching
    • richland007R
      richland007
      Any progress on this at all i have not done anything i was out of town since last Wednesday.
      I don’t know which direction we should look towards … maybe the api keys and requests are the one messing up
      i went back on the google developer console and i see my YouTube api hit a few times and with zero errors i also see the CSE (custom search engine) api hit also but with 100% errors …why ??
      Since it is presenting the data by api numbers that means that the keys are working right but what is the error about??? where do you read more info about that???
      D
      • richland007R
        richland007
        Well here it is the 100% Error on CSE is this
        "400 badRequest
        Indicates that the query was invalid. E.g., parent ID was missing or the combination of dimensions or metrics requested was not valid.
        Do not retry without fixing the problem. You need to make changes to the API query in order for it to work."
        How do we fix this??
        • O
          OceanK
          Hey!
          well I havent tryed for a week or so with this project. Im out of ideas for now =(, I can see that the coder has done some minor changes at github but not likley to help us I guess.
          have you seen the new updates at github?
          • O
            OceanK
            I did check my CSE and I have actually 8 sucessful picture search…
            • O
              OceanK
              OK si I checked My CSE again after my test yesterday, I can see its hitting my gse everytime I ask for searching of pictures…but the mirror ansers there is a problem…but the statistics showing its working.
              so the bad link is between the mirror and the lamda funtions. Because the video and picture search are all fine. But all functions like ask to turn all modules off etc is not working at all.
              • richland007R
                richland007
                Ok so may be it is the Magic Mirrors configuration fault the keys copied to the magic mirror config etc?? maybe we need to redo that one more time
                have you tried reinstalling (delete completely, download again and reinstall) the MMM- MirrorMirrorOnTheWall part only?? than play around with the key paths and files again etc.
                Because there is zero communication back with the mirror… all we are doing so far is fine tuning a skill within Alexa…but what worries me the most is why isn’t Alexa showing any videos or images on my Echo Spot …although now that i think about it is that i have not tested it with the Echo Spot since I made the code changes.
                If you got the MMM module on github the readme file was updated 15 hours ago but i see no other changes since the 3 months ago for mirrormirror.js file
                anyhow all we got to do is keep trying
                O 1 Reply Last reply
                • O
                  OceanK @richland007
                  @richland007 Hey!
                  I will try to start all over again. See whats happening. I can see there are some new changes in the files from the github. but im not that optimistic.
                  what abt u? have u started from scratch?
                  • richland007R
                    richland007
                    @OceanK Any news my friend??? I am so upset that we are not progressing with this module…it is exactly what i need and we can not get it to work.
                    I am going to try to mess with it a bit next week and see whats up
                    D
                    • O
                      OceanK @richland007
                      @richland007 hey mate!
                      Well no progress here, I have reached out to the code maker without sucess:(
                      I have tried everything from scratch but no luck. Everything is triggered but not send back to the mirror itself.
                      I dunno where what to do next. Please report back when you have time even if it’s not successful.
                      I guess we are kinda stuck here.
                      richland007R 1 Reply Last reply
                      • richland007R
                        richland007 @OceanK
                        @oceank No news…anything on your part ??? I tried to use another voice module for MM control but that ruins my Alexa installation and it does not work itself after that either so that was no-go.
                        I think we should start reading again that long thread where people said they had gotten it to work and see what else we may find. I think it is only the return part form the Lampda to the mirror that is not working it cant be that complicated probably something simple but what do i know.
                        D
                        • richland007R
                          richland007
                          @OceanK Yesterday i tried all afternoon to play with this again … i tried to change the keys path on the MirorMirrorOnTheWallSKILL before uploading it to Lambda and nothing changed. Well it gave errors that it was not working so i reverted back to the old working zip file that i had where “everything” was last seem to be fine and another error surfaced but the skill works fine.
                          The error is this
                          2018-11-05T04:11:36.100Z	e2223a43-e0b0-11e8-a28e-557bbecf4c24	The applicationIds don't match: amzn1.ask.skill.[unique-value-here] and amzn1.ask.skill.eXXXXX-dXXX-48bd-9b1c-3d309a950fcf
                          2018-11-05T04:11:36.122Z	e2223a43-e0b0-11e8-a28e-557bbecf4c24
                              "errorMessage": "Invalid ApplicationId: amzn1.ask.skill.eXXXXXXX-XXX-48bd-9b1c-3d309a950fcf",
                              "errorType": "Error",
                              "stackTrace": [
                                  "AlexaRequestEmitter.ValidateRequest (/var/task/node_modules/alexa-sdk/lib/alexa.js:157:27)",
                                  "HandleLambdaEvent.i18n.use.init (/var/task/node_modules/alexa-sdk/lib/alexa.js:123:29)",
                                  "/var/task/node_modules/i18next/dist/commonjs/i18next.js:190:9",
                                  "done (/var/task/node_modules/i18next/dist/commonjs/i18next.js:281:21)",
                                  "/var/task/node_modules/i18next/dist/commonjs/i18next.js:302:7",
                                  "I18n.loadResources (/var/task/node_modules/i18next/dist/commonjs/i18next.js:238:7)",
                                  "I18n.changeLanguage (/var/task/node_modules/i18next/dist/commonjs/i18next.js:301:10)",
                                  "load (/var/task/node_modules/i18next/dist/commonjs/i18next.js:186:14)",
                                  "I18n.init (/var/task/node_modules/i18next/dist/commonjs/i18next.js:195:7)",
                                  "AlexaRequestEmitter.HandleLambdaEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:114:32)"
                          the xxx are my changes to hide my id.
                          I went and checked my appid and it has not changed and like i said the skill works when you go on the Alexa console and it responds with “Hello my queen…” however i do not see any video or photo requests coming though n the logs on the youtube api etc.
                          Another thing that has changed and i do no know why is the IoT endpoint on IoT Core at the bottom under settings.
                          Can you check yours ne more time please run an error test on lambda and see if you see any changes and check your IoT Core endpoint that we copy paste on index.js file
                          Denis
                          • O
                            OceanK @richland007
                            @richland007 Hey!
                            I will try later tonite! Im going to do this from scratch again. I will report back. I have been on vaccation for coupple of weeks in dubai. But now Im back!
                            So lets try this again!
                            • O
                              OceanK
                              hey!
                              its not possible to build the alexa module with the intentmodel.json
                              The intentmodel.json is depricated, and I cannot build the model =(
                              what to do now?
                              • O
                                OceanK
                                So im back again!
                                I started it all from scratch!
                                still getting this:
                                “errorMessage”: “In state: . No handler function was defined for event SessionEndedRequest and no ‘Unhandled’ function was defined.”,
                                “errorType”: “Error”,
                                “stackTrace”: [
                                “AlexaRequestEmitter.EmitEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:212:15)”,
                                “AlexaRequestEmitter.ValidateRequest (/var/task/node_modules/alexa-sdk/lib/alexa.js:181:23)”,
                                “HandleLambdaEvent.i18n.use.init (/var/task/node_modules/alexa-sdk/lib/alexa.js:123:29)”,
                                “/var/task/node_modules/i18next/dist/commonjs/i18next.js:190:9”,
                                “done (/var/task/node_modules/i18next/dist/commonjs/i18next.js:281:21)”,
                                “/var/task/node_modules/i18next/dist/commonjs/i18next.js:302:7”,
                                “I18n.loadResources (/var/task/node_modules/i18next/dist/commonjs/i18next.js:238:7)”,
                                “I18n.changeLanguage (/var/task/node_modules/i18next/dist/commonjs/i18next.js:301:10)”,
                                “load (/var/task/node_modules/i18next/dist/commonjs/i18next.js:186:14)”,
                                “I18n.init (/var/task/node_modules/i18next/dist/commonjs/i18next.js:195:7)”
                                • O
                                  OceanK
                                  Something is not right with the lamda function.
                                  • O
                                    OceanK
                                    Nothing from your side @richland007 ?
                                    • richland007R
                                      richland007
                                      nothing at all my friend
                                      • richland007R
                                        richland007 @OceanK
                                        @oceank this looks very interesting to control themirror with alexa installed already likemy case is https://forum.magicmirror.builders/topic/9211/mmm-alexaonoff-simple-mirror-control-from-external-home-assistant-alexa-google-home-hass-io
                                        D
                                        • O
                                          OceanK
                                          Hey!@richland007
                                          thats i pretty cool! well I already can by voice show and hide every module individually actually and I do that offline. So I dont need any online module like an echo and so on to do this.
                                          • richland007R
                                            richland007 @OceanK
                                            @oceank how do you hide and show all modules what do you use to do that via voice?? ??/ thats why i wanted mirror mirror for ?? doy you yse MMM-voices?? i can not use that cause it messes my Alexa Pi up
                                            • 4 / 7
