    MMM-MirrorMirrorOnTheWall installation issue
    138 Posts 11 Posters 203.1k Views 10 Watching
    • O
      OceanK @richland007
      @richland007 hey mate!
      Well no progress here, I have reached out to the code maker without sucess:(
      I have tried everything from scratch but no luck. Everything is triggered but not send back to the mirror itself.
      I dunno where what to do next. Please report back when you have time even if it’s not successful.
      I guess we are kinda stuck here.
      richland007R 1 Reply Last reply
      • richland007R
        richland007 @OceanK
        @oceank No news…anything on your part ??? I tried to use another voice module for MM control but that ruins my Alexa installation and it does not work itself after that either so that was no-go.
        I think we should start reading again that long thread where people said they had gotten it to work and see what else we may find. I think it is only the return part form the Lampda to the mirror that is not working it cant be that complicated probably something simple but what do i know.
        D
        • richland007R
          richland007
          @OceanK Yesterday i tried all afternoon to play with this again … i tried to change the keys path on the MirorMirrorOnTheWallSKILL before uploading it to Lambda and nothing changed. Well it gave errors that it was not working so i reverted back to the old working zip file that i had where “everything” was last seem to be fine and another error surfaced but the skill works fine.
          The error is this
          2018-11-05T04:11:36.100Z	e2223a43-e0b0-11e8-a28e-557bbecf4c24	The applicationIds don't match: amzn1.ask.skill.[unique-value-here] and amzn1.ask.skill.eXXXXX-dXXX-48bd-9b1c-3d309a950fcf
          2018-11-05T04:11:36.122Z	e2223a43-e0b0-11e8-a28e-557bbecf4c24
              "errorMessage": "Invalid ApplicationId: amzn1.ask.skill.eXXXXXXX-XXX-48bd-9b1c-3d309a950fcf",
              "errorType": "Error",
              "stackTrace": [
                  "AlexaRequestEmitter.ValidateRequest (/var/task/node_modules/alexa-sdk/lib/alexa.js:157:27)",
                  "HandleLambdaEvent.i18n.use.init (/var/task/node_modules/alexa-sdk/lib/alexa.js:123:29)",
                  "/var/task/node_modules/i18next/dist/commonjs/i18next.js:190:9",
                  "done (/var/task/node_modules/i18next/dist/commonjs/i18next.js:281:21)",
                  "/var/task/node_modules/i18next/dist/commonjs/i18next.js:302:7",
                  "I18n.loadResources (/var/task/node_modules/i18next/dist/commonjs/i18next.js:238:7)",
                  "I18n.changeLanguage (/var/task/node_modules/i18next/dist/commonjs/i18next.js:301:10)",
                  "load (/var/task/node_modules/i18next/dist/commonjs/i18next.js:186:14)",
                  "I18n.init (/var/task/node_modules/i18next/dist/commonjs/i18next.js:195:7)",
                  "AlexaRequestEmitter.HandleLambdaEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:114:32)"
          the xxx are my changes to hide my id.
          I went and checked my appid and it has not changed and like i said the skill works when you go on the Alexa console and it responds with “Hello my queen…” however i do not see any video or photo requests coming though n the logs on the youtube api etc.
          Another thing that has changed and i do no know why is the IoT endpoint on IoT Core at the bottom under settings.
          Can you check yours ne more time please run an error test on lambda and see if you see any changes and check your IoT Core endpoint that we copy paste on index.js file
          Denis
          O 1 Reply Last reply
          • O
            OceanK @richland007
            @richland007 Hey!
            I will try later tonite! Im going to do this from scratch again. I will report back. I have been on vaccation for coupple of weeks in dubai. But now Im back!
            So lets try this again!
            • O
              OceanK
              hey!
              its not possible to build the alexa module with the intentmodel.json
              The intentmodel.json is depricated, and I cannot build the model =(
              what to do now?
              • O
                OceanK
                So im back again!
                I started it all from scratch!
                still getting this:
                “errorMessage”: “In state: . No handler function was defined for event SessionEndedRequest and no ‘Unhandled’ function was defined.”,
                “errorType”: “Error”,
                “stackTrace”: [
                “AlexaRequestEmitter.EmitEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:212:15)”,
                “AlexaRequestEmitter.ValidateRequest (/var/task/node_modules/alexa-sdk/lib/alexa.js:181:23)”,
                “HandleLambdaEvent.i18n.use.init (/var/task/node_modules/alexa-sdk/lib/alexa.js:123:29)”,
                “/var/task/node_modules/i18next/dist/commonjs/i18next.js:190:9”,
                “done (/var/task/node_modules/i18next/dist/commonjs/i18next.js:281:21)”,
                “/var/task/node_modules/i18next/dist/commonjs/i18next.js:302:7”,
                “I18n.loadResources (/var/task/node_modules/i18next/dist/commonjs/i18next.js:238:7)”,
                “I18n.changeLanguage (/var/task/node_modules/i18next/dist/commonjs/i18next.js:301:10)”,
                “load (/var/task/node_modules/i18next/dist/commonjs/i18next.js:186:14)”,
                “I18n.init (/var/task/node_modules/i18next/dist/commonjs/i18next.js:195:7)”
                • O
                  OceanK
                  Something is not right with the lamda function.
                  • O
                    OceanK
                    Nothing from your side @richland007 ?
                    • richland007R
                      richland007
                      nothing at all my friend
                      • richland007R
                        richland007 @OceanK
                        @oceank this looks very interesting to control themirror with alexa installed already likemy case is https://forum.magicmirror.builders/topic/9211/mmm-alexaonoff-simple-mirror-control-from-external-home-assistant-alexa-google-home-hass-io
                        D
                        • O
                          OceanK
                          Hey!@richland007
                          thats i pretty cool! well I already can by voice show and hide every module individually actually and I do that offline. So I dont need any online module like an echo and so on to do this.
                          • richland007R
                            richland007 @OceanK
                            @oceank how do you hide and show all modules what do you use to do that via voice?? ??/ thats why i wanted mirror mirror for ?? doy you yse MMM-voices?? i can not use that cause it messes my Alexa Pi up
                            • O
                              OceanK
                              Hey @richland007 !
                              I use this module: Helo Lucy: https://github.com/mykle1/Hello-Lucy
                              So im running aintel nuc with ubuntu to run the magicmirror with lucy. So I have one hidden microphone behind the mirror for that.
                              Then I have a raspberry pi with hidden microphone and speakers, running both Alexa and google assistant =)
                              https://github.com/shivasiddharth/Assistants-Pi
                              So now its running like I want it =)
                                blackpanda
                                @OceanK @richland007
                                Just a heads up –
                                I was running into the same issues as you both. After hours of research I eventually discovered that the AWS IoT security policy for your certificates must be properly configured…otherwise you’ll be hit with authorization issues when clients attempt to connect to the IoT thing for subscribing, publishing, connections, etc. Once i corrected this, I had no further issues with the installation.
                                The change I made to my policy in ‘AWS IoT>Secure>Policies’ is below:
                                  "Version": "2012-10-17",
                                  "Statement": [
                                      "Effect": "Allow",
                                      "Action": [
                                        "iot:Publish",
                                        "iot:Receive"
                                      "Resource": [
                                        "arn:aws:iot:us-east-1:543211234567:topic/sdk/test/java",
                                        "arn:aws:iot:us-east-1:543211234567:topic/sdk/test/Python",
                                        "arn:aws:iot:us-east-1:543211234567:topic/topic_1",
                                        "arn:aws:iot:us-east-1:543211234567:topic/topic_2",
                                        "arn:aws:iot:us-east-1:543211234567:topic/MagicMirror:new-text",
                                        "arn:aws:iot:us-east-1:543211234567:topic/MagicMirror:new-images",
                                        "arn:aws:iot:us-east-1:543211234567:topic/MagicMirror:change-module",
                                        "arn:aws:iot:us-east-1:543211234567:topic/MagicMirror:new-video"
                                      "Effect": "Allow",
                                      "Action": [
                                        "iot:Subscribe"
                                      "Resource": [
                                        "arn:aws:iot:us-east-1:543211234567:topicfilter/sdk/test/java",
                                        "arn:aws:iot:us-east-1:543211234567:topicfilter/sdk/test/Python",
                                        "arn:aws:iot:us-east-1:543211234567:topicfilter/topic_1",
                                        "arn:aws:iot:us-east-1:543211234567:topicfilter/topic_2",
                                        "arn:aws:iot:us-east-1:543211234567:topicfilter/MagicMirror:new-text",
                                        "arn:aws:iot:us-east-1:543211234567:topicfilter/MagicMirror:new-images",
                                        "arn:aws:iot:us-east-1:543211234567:topicfilter/MagicMirror:change-module",
                                        "arn:aws:iot:us-east-1:543211234567:topicfilter/MagicMirror:new-video"
                                      "Effect": "Allow",
                                      "Action": [
                                        "iot:Connect"
                                      "Resource": [
                                        "arn:aws:iot:us-east-1:543211234567:client/sdk-java",
                                        "arn:aws:iot:us-east-1:543211234567:client/basicPubSub",
                                        "arn:aws:iot:us-east-1:543211234567:client/sdk-nodejs-*",
                                        "arn:aws:iot:us-east-1:543211234567:client/MagicMirror*"
                                Make sure your client id defined in MirrorMirror.js matches the wildcard (“MagicMirror” in this case) that was added to iot:Connect action of the policy. This needs to be modified locally in the module and also in the uploaded lambda function!
                                // Setup our AWS IoT device and receive messages
                                app.setup = function() {
                                  app.device = awsIot.device({
                                    keyPath: __dirname + "/certs/MagicMirror.private.key",
                                    certPath: __dirname + "/certs/MagicMirror.cert.pem",
                                    caPath: __dirname + "/certs/root-CA.crt",
                                    clientId: "MagicMirror" + (new Date().getTime()),
                                    region: "us-east-1",
                                    host: "YOURID.iot.us-east-1.amazonaws.com",
                                Best of luck and happy new year!
                                richland007R O 3 Replies Last reply
                                Reply Quote 3
                                • richland007R
                                  richland007 @blackpanda
                                  @blackpanda Hey thank you for reviving the topic and happy new year.
                                  Quick question were do i find the ‘AWS IoT>Secure>Policies’
                                  so i can make the necessary changes at??
                                  Is it over on the MirrorMirrorOnTheWallSkill i have a aws-iot-device-sdk folder under src/node_modules but there is no Secure sub folder in it!!!
                                  D
                                  B 1 Reply Last reply
                                    bhepler Module Developer @richland007
                                    @richland007 said in MMM-MirrorMirrorOnTheWall installation issue:
                                    Policies are modified via the Amazon Web Services (AWS) management console.
                                    You can update the policy by submitting JSON through the API. Or you can use the management console and just duplicate the settings posted above.
                                    • O
                                      OceanK @blackpanda
                                      @blackpanda thanx bro! I will try this later today, I will report back. @richland007 did it work for you?
                                      • O
                                        OceanK @blackpanda
                                        @blackpanda SO you got this to work? I still have problem =( When building the model could you paste your interactionmodel? the one that goes into the json editor…
                                        • richland007R
                                          richland007 @OceanK
                                          @oceank I haven’t gotten the chance to give it another try but i will soon :)
                                          Did you do the changes that @blackpanda suggested ?? whats it telling you now??
                                          @blackpanda It took me a while to realize that it says MagicMirror but on our MirrorMirror.js file the ClienId is MirrorMirror so i changed that and i uploaded on Lambda and i made the appropriate policy changes on the IoT to reflect my arn:aws and my number nut just copy paste yours
                                          but when i test Lambda now i get this error: The applicationIds don’t match: amzn1.ask.skill.[unique-value-here] and amzn1.ask.skill.e0223a06-d061-48bd-9b1c-3XXXXa950fcf
                                          And the app ID has not changed?? And also when i go to test the skill now on the Alexa developer side now i dont even get"Hello My queen…" i used to get it just goes straight to there was a problem with the requested skills response.
                                          What else do i need to change cause i doubt there is anything major …has the syntax changed again appID or aplicationId etc???
                                          Thank you any help is greatly appreciated
                                          D
                                            blackpanda @richland007
                                            @richland007 so you changed the clientId in the lambda function and uploaded it. Did you change the client id in the module as well? Can you post your security policy? You should also define your queues (modules) there.
                                            The app id is defined in index.js of the skill. APP_ID is defined in a variable near the top of the file.
                                            Looks like this currently:
                                            alexa.appId = APP_ID
                                            Also, you can verify what your skill id is by checking in the amazon developer console then selecting ‘endpoint’ (it’s an option on the left pane under interaction model and interfaces).
                                            • 4 / 7
