    MMM-SoccerLiveScore
    187 Posts 37 Posters 334.7k Views 35 Watching
      master117
      I created a new version of this module:
      https://github.com/master117/MagicMirror-FootballLeagues
      Most of the errors mentioned above, should be fixed. It works with only one league selected for example. The old module also polls its undocumented datasource too often and eventually gets banned, which is why the scores stop refreshing. It does not yet have support for logos.
      Greetings,
      master117
      • F
        fabbr
        @master117 I just tried and got two errors on the installation:
        npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
        npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/node_modules/node_helper/package.json’
        npm WARN modules No description
        npm WARN modules No repository field.
        npm WARN modules No README data
        npm WARN modules No license field.
        When I add the module to the config.js nothing shows up. I tried several different configurations and problem persist. any idea on what I am doing wrong?
        • G
          gashion
          @fabbr Did you ever get this working? I get the same errors;
          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
          npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/node_modules/node_helper/package.json'
          @master117 Anything?
            master117
            @gashion @fabbr
            Those are not errors (ERR) just regular warnings (WARN). They are unrelated to whatever issue you are having, they are even unrelated to the module itself, request (the thing being installed) is a semi standard nodejs library and not made by me.
            I would guess either your config is wrong or there is not enough space on the mirror. If you list your steps and config I may be able to help.
            • G
              gashion
              @master117
              Here is my config:
              			module: 'MagicMirror-FootballLeagues',
              			position: 'bottom_center',
              			header: 'Live-Scores',
              				leagues: [445, 455, 464, 456, 450],
                      		showNames: true,
                      		displayTime: 60 * 1000,
                      		showTables: true,
              				showLogos: true,
              				apiKey: 'MyApiKey'
              • F
                fabbr @gashion
                I don’t think the API is working anymore. :(
                • N
                  nem1
                  Is it possible to integrate the World Cup 2018 into this module?
                    baschke
                    Is there a way to diasable tables for specific leagues? e.g. I don’t want to show tables for the Champions Leagues, cause it will only show the table of group A.
                    • G
                      gashion @baschke
                      @baschke
                      When adding leagues in your config, dont add “464”. Thats for Champions League.
                      • N
                        nem1
                        I used this module in the past and I was really satisfied. After a complete reset of my mirror, I had to reinstall all modules. Unfortounatly the MMM-SoccerLiveScore is not working correctly anymore :(
                                                module: "MMM-SoccerLiveScore",
                                                header: "Live-Scores",
                                                        leagues: [35,9,1,0],
                                                        displayTime: 30 * 1000
                        Whats wrong? On the mirror its shown just the header, no error-message.
                        Thanks a lot.
                        nem1
                          Ramez @nem1
                          @nem1 where did you get the 0 in leagues config? there is no leagues assigned to zero, remove it and try…
                          • N
                            nem1 @Ramez
                            @ramez
                            0 is the ID for the german nationalteam.
                            But for now, the module is working. But I dont know why :D
                              Ramez @nem1
                              @nem1 glad it’s working :) … same happened to me Here that’s because source server sometimes down
                                Joeysface
                                I have been messing around with this module and it is working really well. I love the way its laid out but I do have a few questions.
                                • Is there anyway to not display the table for certain leagues? Someone asked already but the Champions League table only seems to be showing Group A.
                                • Is there a way to change the display date format? I would like to change the format to something like MM-DD instead of DD.MM.
                                • Is there maybe a way to highlight certain teams on the table and schedule? For example, If I follow a few PL teams and want their games to pop out more so that the text is bolded or highlighted for the team name.
                                Thanks again for any help
                                • Alex2020A
                                  Alex2020
                                  Ma per creare un “tavolo” per la classifica di serie “A” Italiana cè un modo ?Grazie.
                                  • lavolp3L
                                    lavolp3 Module Developer
                                    Hi @LukeCodewalker I’d like to use and probably contribute to the module a bit.
                                    Do you think it’s possible to show the goals and scorers of a current running game?
                                    Is there an endpoint in the api for that?
                                    How to troubleshoot modules
                                    MMM-soccer v2, MMM-AVStock
                                    • G
                                      Galaras7
                                      Hi guys please I need your help …
                                      ID Number Greece soccer please.
                                      For My magicmirror livescore modul…
                                        master117 @Galaras7
                                        @Galaras7
                                        if you are using my module, you can check ids here:
                                        http://api.football-data.org/v2/competitions/
                                        Greece ID: 2093
                                        Greece sadly is not covered in the APIs free tier. So you would have to pay for it.
                                        https://www.football-data.org/coverage
                                        • F
                                          frankturban
                                          I am viewing the results of the 2nd Bundesliga. Unfortunately I don’t get any icons here. Is this a bug? It works for other leagues … Thank you very much …
                                          • StoffbeuteluweS
                                            Stoffbeuteluwe Project Sponsor @frankturban
                                            @frankturban same problem after MM new start or refresh browser?
                                            • 10
                                            • 4 / 10
