    help converting code for module...
    21 Posts 4 Posters 13.0k Views 4 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @justjim1220
      @justjim1220 if the variable doesn’t even exist, the rest of the code cannot work at all. first you should make sure that you have your data in the variable and then the second step is displaying it.
      It seems like you’re trying to do the ui before you have the data.
      justjim1220J 1 Reply Last reply
      • justjim1220J
        justjim1220 Module Developer @strawberry 3.141
        @strawberry-3-141
        I defined Temps. then got this in console…
        MMM-PC-Stats.js:104 Uncaught (in promise) TypeError: Cannot read property '
        ootwmi:MSAcpi_ThermalZoneTemperature' of undefined
            at Class.getDom (MMM-PC-Stats.js:104)
            at main.js:110
            at new Promise (<anonymous>)
            at updateDom (main.js:109)
            at Object.updateDom (main.js:514)
            at Class.updateDom (module.js:358)
            at Class.socketNotificationReceived (MMM-PC-Stats.js:213)
            at module.js:246
            at r.<anonymous> (socketclient.js:25)
            at r.emit (index.js:133)
        Jim Hallock - 1995
        • justjim1220J
          @strawberry-3-141
          I had a syntax error in the declaration of Temps.
          I’m totally thinking this isn’t going to work.
          I will probably need to find a different way,
          figured if I could pull it from the SIMBIOS using a simple script, that maybe it could be pulled using a module for MM.
          there are some open source apps for Windows that work to get the data, I will just have to study them and see what I can come up with.
          Thanks for trying to help.
          Jim Hallock - 1995
          • strawberry 3.141S
            @justjim1220 if you don’t even have the data in js, you can also execute it in the node helper and parse the response https://nodejs.org/api/child_process.html#child_process_child_process_exec_command_options_callback
            • justjim1220J
              @strawberry-3-141
              What are the chances of being able to do what I had been attempting with this?
              https://github.com/moxystudio/node-cross-spawn
              And would it be possible to add to a current node_helper being used for linux, or would a separate node_helper or script need made?
              Jim Hallock - 1995
              ? 1 Reply Last reply
                A Former User @justjim1220
                @justjim1220
                exec(“YOUR-SHELL-COMMAND”, (error, stdout, stderr)=>{
                  console.log(stdout)
                  // do your job with `stdout`
                I think you can get the result of any execution of shell script.
                • justjim1220J
                  justjim1220 Module Developer @Guest
                  @sean
                  Not sure I follow …
                  what would be my ‘shell command’?
                  Jim Hallock - 1995
                    @justjim1220
                    PS C:\WINDOWS\system32> get-temperature
                    I don’t know anything about your intention, but ‘get-temperature’ could be executable in your shell or terminal, it could be the one.
                    • justjim1220J
                      @sean
                      Yes, that is the command to get the temps from the PC using powershell or command prompt…
                      BUT, where to use the command in node_helper.js?
                      OR, where to use the command in the module.js file?
                      Jim Hallock - 1995
                      S ? 2 Replies Last reply
                        sdetweil @justjim1220
                        @justjim1220 let’s look at the design of your module.
                        How often do u need to get the temps?
                        Is it on a timer, or some other mechanism?
                        Anyhow, on that cycle, you would issue the ‘run’ of the powershell app in the node_helper.js, and capture it’s output.
                        Then process the output, remove all the useless data. Then send the raw data to the module.js, who will then format the HTML in the get_dom() function for display
                          @justjim1220
                          const exec = require('child_process').exec
                          var NodeHelper = require("node_helper")
                            socketNotificationReceived: function(noti, payload) {
                              if (noti == "GIVE_ME_RESULT") {
                                setTimeout(()=>{
                                  exec("C:\WINDOWS\system32\get-temperature", //I don't know WINDOWS system at all. Is it right?
                                    (err, sto, ste) => {
                                      if (!err) {
                                        this.sendSocketNotification("HERE_IS_RESULT", sto)
                                      } else {
                                        console.log("Error", err)
                                }, 1000)
                          It isn’t tested. But you can catch the idea.
