    help converting code for module...
    21 Posts 4 Posters 12.7k Views 4 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @justjim1220
      @justjim1220 this is not JavaScript, there are errors on all lines. Not sure why you didn’t see errors, are you sure you called that function?
      • justjim1220J
        justjim1220 Module Developer @strawberry 3.141
        @strawberry-3-141
        yeah, sorry, I see some of the errors, but not all of them.
        Want to hint me a little?
        Jim Hallock - 1995
        • justjim1220J
          I need to know how to reconfigure the second line for this work in an MM module…
          getTemperature: function() {
          	var t = getWmiObject = MSAcpi_ThermalZoneTemperature(Namespace = "root/wmi" | where (Property = instancename) && (EQ = "ACPI\ThermalZone\TZ01_0"));
          	currentTempKelvin = t.CurrentTemperature / 10;
          	currentTempCelsius = currentTempKelvin - 273.15;
          	currentTempFahrenheit = (9/5) * currentTempCelsius + 32;
          	return currentTempCelsius + " C " + currentTempFahrenheit + " F : " + currentTempKelvin + "K";
          I’m pretty sure rest of the function is ok. But, I could be wrong! :disappointed_face:
          Jim Hallock - 1995
          • justjim1220J
            latest attempt with this code…
            var checkSensorTemps = Temps["\root\wmi:MSAcpi_ThermalZoneTemperature"]["ACPI\ThermalZone"]["THRM_0"];
            if (typeof checkSensorTemps !== "undefined") {
            	// Core Temps
            	var core0Temp = document.createElement("div");
            	core0Temp.classList.add("large", "bright", "core0Temp");
            	core0Temp.innerHTML = Stats.cpu.threads[i].name + " &nbsp  @  &nbsp "
            		+ ((Temps["\root\wmi:MSAcpi_ThermalZoneTemperature"]["ACPI\ThermalZone"]["THRM_0"].value / 10) -273.15) + " °C "
            		+ ((((Temps["\root\wmi:MSAcpi_ThermalZoneTemperature"]["ACPI\ThermalZone"]["THRM_0"].value / 10) -273.15) * 9/5) + 32) + " °F "
            		+ (Temps["\root\wmi:MSAcpi_ThermalZoneTemperature"]["ACPI\ThermalZone"]["THRM_0"].value  / 10) + "°K";
            	wrapper.appendChild(core0Temp);
            HELP! LMAO! :face_with_stuck-out_tongue_winking_eye:
            Jim Hallock - 1995
            • strawberry 3.141S
              @justjim1220 do you have a log of the structure of Temps
              justjim1220J 2 Replies Last reply Reply Quote 0
              • justjim1220J
                @strawberry-3-141
                PS C:\WINDOWS\system32> powershell.exe Get-WmiObject MSAcpi_ThermalZoneTemperature -Namespace "root/wmi"
                __GENUS              : 2
                __CLASS              : MSAcpi_ThermalZoneTemperature
                __SUPERCLASS         : MSAcpi
                __DYNASTY            : MSAcpi
                __RELPATH            : MSAcpi_ThermalZoneTemperature.InstanceName="ACPI\\ThermalZone\\THRM_0"
                __PROPERTY_COUNT     : 12
                __DERIVATION         : {MSAcpi}
                __SERVER             : DESKTOP-BEUARKC
                __NAMESPACE          : root\wmi
                __PATH               : \\DESKTOP-BEUARKC\root\wmi:MSAcpi_ThermalZoneTemperature.InstanceName="ACPI\\ThermalZone\\THRM_0
                Active               : True
                ActiveTripPoint      : {0, 0, 0, 0...}
                ActiveTripPointCount : 0
                CriticalTripPoint    : 3762
                CurrentTemperature   : 3172
                InstanceName         : ACPI\ThermalZone\THRM_0
                PassiveTripPoint     : 3882
                Reserved             : 0
                SamplingPeriod       : 100
                ThermalConstant1     : 2
                ThermalConstant2     : 10
                ThermalStamp         : 25
                PSComputerName       : DESKTOP-BEUARKC
                Jim Hallock - 1995
                • justjim1220J
                  @strawberry-3-141
                  this script ran in powershell …
                  function Get-Temperature {
                      $t = Get-WmiObject MSAcpi_ThermalZoneTemperature -Namespace "root/wmi"
                      $returntemp = @()
                      foreach ($temp in $t.CurrentTemperature)
                          $currentTempKelvin = $temp / 10
                          $currentTempCelsius = $currentTempKelvin - 273.15
                          $currentTempFahrenheit = (9/5) * $currentTempCelsius + 32
                          $returntemp += $currentTempCelsius.ToString() + " C : " + $currentTempFahrenheit.ToString() + " F : " + $currentTempKelvin + "K"
                      return $returntemp
                  gives the following output for a single core …
                  PS C:\WINDOWS\system32> get-temperature
                  44.05 C : 111.29 F : 317.2K
                  I’m really only interested in a C and F result, no need for K that I can think of.
                  Jim Hallock - 1995
                  • strawberry 3.141S
                    @justjim1220 I can’t work with your powershell logs. You’re trying to access the variable Temps in js like your first line. var checkSensorTemps = Temps["\root\wmi:MSAcpi_ThermalZoneTemperature"]["ACPI\ThermalZone"]["THRM_0"];
                    can you do console.log(Temps) so I can see the structure?
                    justjim1220J 3 Replies Last reply Reply Quote 0
                    • justjim1220J
                      @strawberry-3-141
                      it throws this error…
                      Uncaught (in promise) ReferenceError: Temps is not defined
                          at Class.getDom (MMM-PC-Stats.js:103)
                          at main.js:110
                          at new Promise (<anonymous>)
                          at updateDom (main.js:109)
                          at Object.updateDom (main.js:514)
                          at Class.updateDom (module.js:358)
                          at Class.socketNotificationReceived (MMM-PC-Stats.js:218)
                          at module.js:246
                          at r.<anonymous> (socketclient.js:25)
                          at r.emit (index.js:133)
                      Jim Hallock - 1995
                      • strawberry 3.141S
                        @justjim1220 if the variable doesn’t even exist, the rest of the code cannot work at all. first you should make sure that you have your data in the variable and then the second step is displaying it.
                        It seems like you’re trying to do the ui before you have the data.
                        • justjim1220J
                          @strawberry-3-141
                          I defined Temps. then got this in console…
                          MMM-PC-Stats.js:104 Uncaught (in promise) TypeError: Cannot read property '
                          ootwmi:MSAcpi_ThermalZoneTemperature' of undefined
                              at Class.getDom (MMM-PC-Stats.js:104)
                              at main.js:110
                              at Class.socketNotificationReceived (MMM-PC-Stats.js:213)
                              at module.js:246
                          Jim Hallock - 1995
                          • justjim1220J
                            @strawberry-3-141
                            I had a syntax error in the declaration of Temps.
                            I’m totally thinking this isn’t going to work.
                            I will probably need to find a different way,
                            figured if I could pull it from the SIMBIOS using a simple script, that maybe it could be pulled using a module for MM.
                            there are some open source apps for Windows that work to get the data, I will just have to study them and see what I can come up with.
                            Thanks for trying to help.
                            Jim Hallock - 1995
                            • strawberry 3.141S
                              @justjim1220 if you don’t even have the data in js, you can also execute it in the node helper and parse the response https://nodejs.org/api/child_process.html#child_process_child_process_exec_command_options_callback
                              • justjim1220J
                                @strawberry-3-141
                                What are the chances of being able to do what I had been attempting with this?
                                https://github.com/moxystudio/node-cross-spawn
                                And would it be possible to add to a current node_helper being used for linux, or would a separate node_helper or script need made?
                                Jim Hallock - 1995
                                  A Former User @justjim1220
                                  @justjim1220
                                  exec(“YOUR-SHELL-COMMAND”, (error, stdout, stderr)=>{
                                    console.log(stdout)
                                    // do your job with `stdout`
                                  I think you can get the result of any execution of shell script.
                                  justjim1220J 1 Reply Last reply Reply Quote 1
                                  • justjim1220J
                                    justjim1220 Module Developer @Guest
                                    @sean
                                    Not sure I follow …
                                    what would be my ‘shell command’?
                                    Jim Hallock - 1995
                                      @justjim1220
                                      I don’t know anything about your intention, but ‘get-temperature’ could be executable in your shell or terminal, it could be the one.
                                      • justjim1220J
                                        @sean
                                        Yes, that is the command to get the temps from the PC using powershell or command prompt…
                                        BUT, where to use the command in node_helper.js?
                                        OR, where to use the command in the module.js file?
                                        Jim Hallock - 1995
                                        S ? 2 Replies Last reply Reply Quote 0
                                          sdetweil @justjim1220
                                          @justjim1220 let’s look at the design of your module.
                                          How often do u need to get the temps?
                                          Is it on a timer, or some other mechanism?
                                          Anyhow, on that cycle, you would issue the ‘run’ of the powershell app in the node_helper.js, and capture it’s output.
                                          Then process the output, remove all the useless data. Then send the raw data to the module.js, who will then format the HTML in the get_dom() function for display
                                            @justjim1220
                                            const exec = require('child_process').exec
                                            var NodeHelper = require("node_helper")
                                              socketNotificationReceived: function(noti, payload) {
                                                if (noti == "GIVE_ME_RESULT") {
                                                  setTimeout(()=>{
                                                    exec("C:\WINDOWS\system32\get-temperature", //I don't know WINDOWS system at all. Is it right?
                                                      (err, sto, ste) => {
                                                        if (!err) {
                                                          this.sendSocketNotification("HERE_IS_RESULT", sto)
                                                        } else {
                                                          console.log("Error", err)
                                                  }, 1000)
                                            It isn’t tested. But you can catch the idea.
