    MMM-GooglePhotos
    294 Posts 56 Posters 391.6k Views 59 Watching
      bchabbert
      i have a problem when i paste my code error message:
      pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ cat toto.txt
      pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node auth_and_test.js
      Opening OAuth URL.(https://accounts.google.com/o/oauth2/v2/auth?access_type=offline&scope=https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fphotoslibrary.readonly&response_type=code&client_id=491102864701-4kg1b7lbb90bt2vsc0cuh5af5acefgje.apps.googleusercontent.com&redirect_uri=urn%3Aietf%3Awg%3Aoauth%3A2.0%3Aoob) Return here with your code.
      Paste your code: 4/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
      (node:3967) UnhandledPromiseRejectionWarning: Error: Error getting tokens:
      at oauthClient.getToken (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:93:24)
      at /home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/google-auth-library/build/src/auth/oauth2client.js:158:46
      at
      at process._tickCallback (internal/process/next_tick.js:182:7)
      (node:3967) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
      (node:3967) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      Can you help me please ?
      Bérenger.
        A Former User @bchabbert
        @bchabbert
        Hmmm… I think, your oAuth was failed. But I cannot figure out what was wrong at that moment. I suggest you to try again from scratch.
          bchabbert @Guest
          @sean
          Hi Sean,
          From scratch ? i delete module and reinstall it ?
          Bérenger.
          ? C 2 Replies Last reply Reply Quote 0
            @bchabbert
            I think it was not the fault of the module itself. You’d better remove all your current google project and create new one then try again.
              bchabbert @Guest
              @sean
              thank you for your help :)
              I have recreate a new google project and it works now :)
              Bérenger.
                CGaZ3 @bchabbert
                @bchabbert
                Did you figure this out?
                  bowlofred
                  I’m trying to use this module and am having trouble. Right now I don’t see any output from it. No problem with the authentication step. auth_and_test.js gave me the AlbumId. The config I’m using is:
                                          module: "MMM-GooglePhotos",
                                                  albumId: "A[removed for posting]dj4",
                                                  refreshInterval: 1000*60,
                                                  scanInterval: 1000*60*10,
                                                  sort: "random",
                                                  showWidth: "80%",
                                                  originalWidthPx: 800,
                                                  originalHeightPx: 600,
                                                  mode: "contain"
                  The album exists and has 2 sample images in it. I don’t see anything relevant in the log:
                  Loading config ...
                  Loading module helpers ...
                  No helper found for module: MMM-GooglePhotos.
                  All module helpers loaded.
                  Server started ...
                  Ready to go! Please point your browser to: http://localhost:8080
                  System is pi zero running in server_only mode. (I’ve also tried on Windows/server_only as well, same behavior). I didn’t see if there’s a way to make things more verbose to see what the module is doing. I’m sure I’ve got an error, but I can’t see what it is.
                    A Former User @bowlofred
                    @bowlofred
                    It’s weird. Because
                    means you have no node_helper.js in your module directory. Have you removed?
                      bowlofred @Guest
                      @sean Nope, just unfamiliar with installation. I thought the npm install took care of the location, and I didn’t have it in the modules directory. Once I put it there, I got log output and tried playing around to make it visible.
                      My configuration above is still blank, but if I change the position to “fullscreen_below”, it shows the image. It seems that if the position is the same as some other module, it is shown (but very small). if the position is not fullscreen, but different from any other, then it doesn’t appear.
                      My intent is to have the photos on one side (top to bottom) and have some other items beside it. If I leave it fullscreen and set showWidth to 60%, it almost works. It stays on the left, so I can put other items on the right. But the image isn’t centered vertically. There’s a black bar at the bottom that is never drawn. It seems to be centered vertically within the remaining space.
                        @bowlofred
                        I think you should adjust your custom.css.
                        add this to your css/custom.css
                        .fullscreen.below {
                          width:75%;
                        And you would set showWidth and showHeight as 100%, mode as cover.
                        Then, you can get like this;
                          bowlofred
                          Bingo! That works very, very well.
                          • W Offline
                            wumpst
                            I added new photos to my album but they are not displaying. Do I need to update the ScanInterval? What does the 1000 60 10 do exactly?
                            B ? 2 Replies Last reply Reply Quote 0
                              bowlofred @wumpst
                              @wumpst If you look at the logs, you should see the count of photos in the folder every time it scans. Do they show a scan and is the count of photos increasing (and correct)?
                                A Former User @wumpst
                                @wumpst it means scanning will repeat in every 1000x60x10 milliseconds (10minutes)
                                • W Offline
                                  wumpst @bowlofred
                                  @bowlofred where do I find the log?
                                    bowlofred @wumpst
                                    @wumpst Depends on how you start it. If you run node serveronly (what I usually do for debugging), you’ll see it on your commandline. If you start it with pm2, it’ll probably be in ~/.pm2/logs. See https://github.com/MichMich/MagicMirror/wiki/Module-Debugging.
                                    • K Offline
                                      krishnatnl
                                      @Module-Developers
                                      I started with magicMirror and need to understand the following:
                                      1. I want a picture to be displayed every minute (using it as photo frame). What should be the best Refresh and Scan Interval considering the API quota limit.
                                      2. Can I add different albums (example: Travel; Wedding; Food) and make it work random?
                                      3. Once the photos scan is done, the last photo scanned is displayed continuosly. Is there a repeat feature once the last photo is scanned?
                                      ? B 2 Replies Last reply Reply Quote 0
                                        A Former User @krishnatnl
                                        @krishnatnl
                                        Tomorrow I’ll research then I’ll leave my reply.
                                          bowlofred @krishnatnl
                                          @krishnatnl
                                          1. That’s what I do. I just used the default scan interval (10 minutes) and set the refresh to 1 minute.
        sort: "random",
                                          1. I’m not aware you can use multiple albums. I just add any photos I want to display on a separate “magicmirror” album. The photos are simultaneously in multiple albums. That gives me control over what’s displayed, but it does mean I have to manually add everything into all the albums I want.
                                          2. What sort method are you using?
                                            @bowlofred
                                            1. 10,000 requests per project per day is allowed. In my calculation, 10 minutes as scanInterval is enough. Not only too short interval but also longer interval could be also problem, because temp URL of photo doesn’t live long. I fix scanInterval over 10 minutes to 10 minutes.
                                            2. Not possible at this moment, but I’m considering that feature.
                                            3. For last photo repeat issue : No. I think it might be bug. But on my test it didn’t happen. I’ll look inside.
                                            4. sort algorithm is here; https://github.com/eouia/MMM-GooglePhotos/blob/master/node_helper.js#L112
                                            EDITED
                                            2-1. Suddenly I’ve remembered why I didn’t make that feature. It was related with API quota. Since multi-album searching is not supported by API, module should scan each album on every scan time. It can consume API quota very soon. So I thought it could be problem on real usage.
                                            • 14
                                            • 15
                                            • 3 / 15
