    MMM-GooglePhotos
    294 Posts 56 Posters 337.0k Views 59 Watching
      A Former User @bowlofred
      @bowlofred
      It’s weird. Because
      No helper found for module: MMM-GooglePhotos.
      means you have no node_helper.js in your module directory. Have you removed?
        bowlofred @Guest
        @sean Nope, just unfamiliar with installation. I thought the npm install took care of the location, and I didn’t have it in the modules directory. Once I put it there, I got log output and tried playing around to make it visible.
        My configuration above is still blank, but if I change the position to “fullscreen_below”, it shows the image. It seems that if the position is the same as some other module, it is shown (but very small). if the position is not fullscreen, but different from any other, then it doesn’t appear.
        My intent is to have the photos on one side (top to bottom) and have some other items beside it. If I leave it fullscreen and set showWidth to 60%, it almost works. It stays on the left, so I can put other items on the right. But the image isn’t centered vertically. There’s a black bar at the bottom that is never drawn. It seems to be centered vertically within the remaining space.
          @bowlofred
          I think you should adjust your custom.css.
          add this to your css/custom.css
          .fullscreen.below {
            width:75%;
          And you would set showWidth and showHeight as 100%, mode as cover.
          Then, you can get like this;
            bowlofred
            Bingo! That works very, very well.
            • W Offline
              wumpst
              I added new photos to my album but they are not displaying. Do I need to update the ScanInterval? What does the 1000 60 10 do exactly?
              B ? 2 Replies Last reply Reply Quote 0
                bowlofred @wumpst
                @wumpst If you look at the logs, you should see the count of photos in the folder every time it scans. Do they show a scan and is the count of photos increasing (and correct)?
                  A Former User @wumpst
                  @wumpst it means scanning will repeat in every 1000x60x10 milliseconds (10minutes)
                  • W Offline
                    wumpst @bowlofred
                    @bowlofred where do I find the log?
                      bowlofred @wumpst
                      @wumpst Depends on how you start it. If you run node serveronly (what I usually do for debugging), you’ll see it on your commandline. If you start it with pm2, it’ll probably be in ~/.pm2/logs. See https://github.com/MichMich/MagicMirror/wiki/Module-Debugging.
                      • K Offline
                        krishnatnl
                        @Module-Developers
                        I started with magicMirror and need to understand the following:
                        1. I want a picture to be displayed every minute (using it as photo frame). What should be the best Refresh and Scan Interval considering the API quota limit.
                        2. Can I add different albums (example: Travel; Wedding; Food) and make it work random?
                        3. Once the photos scan is done, the last photo scanned is displayed continuosly. Is there a repeat feature once the last photo is scanned?
                        ? B 2 Replies Last reply Reply Quote 0
                        • 29
                        • 30
                        • 5 / 30
