Calendar showing 12h time format instead of 24h
In my calendar module, all entries in the range two days from now are shown with “tomorrow/day after tomorrow at XX:00”, but the time is shown with 12h time format, although in MagicMirror config timeFormat is set to 24.
I presume the reason is a function in calendar.js: in case the day of the event is < currentdate - 2 the event is derived from moment.calendar()
if (event.startDate - now < 2 * oneDay) { // This event is within the next 48 hours (2 days) if (event.startDate - now < this.config.getRelative * oneHour) { // If event is within 6 hour, display 'in xxx' time format or moment.fromNow() timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").fromNow()); } else { // Otherwise just say 'Today/Tomorrow at such-n-such time' timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").calendar()); }
E.g., first entry should be “Morgen um 16:30”The moment.calendar() function is used nowhere else in the module.
I haven’t noticed this behaviour before, so I’m not sure if I have triggered this somehow or if it has been there before.
Does anyone have a clue what the problem is?
Well I have found the problem.
But it seems to have been resolved with a recent code updateFor those interested:
getLocaleSpecification: function(timeFormat) { switch (timeFormat) { case 12: { return { longDateFormat: {LT: "h:mm A"} }; break; } case 24: { return { longDateFormat: {LT: "HH:mm"} }; break; } default: { return { longDateFormat: {LT: moment.localeData().longDateFormat("LT")} }; break; } } },For case 24 The longDateFormat: hh:mm was wrong. It needs to be HH:mm.
As said, was already changed.
Thanks @MichMich
