    MMM-AssistantMk2
    421 Posts 61 Posters 804.3k Views 57 Watching
      A Former User @Cr4z33
      @cr4z33
      Try this.
        module: "MMM-AssistantMk2",
          record: {
            recordProgram: "arecord",
            device: null        // or device: "hw:0,0"
          play: {
            playProgram: "mpg321",
      Cr4z33C 1 Reply Last reply
      • citizendevpiC
        citizendevpi @Guest
        @sean sweet i added a bunch of outher modules and now get a memory error how do i update to the newer version so hopefully these errors sort themselvs out
        • citizendevpiC
          citizendevpi
          !!! { audioFormat: 1,
          endianness: ‘LE’,
          channels: 1,
          sampleRate: 16000,
          byteRate: 32000,
          blockAlign: 2,
          bitDepth: 16,
          signed: true }
          mmap() failed: Cannot allocate memory
          Failed to create permanent mapping for memfd region with ID = 3246537711
          Ignoring received block reference with non-registered memfd ID = 3246537711
          ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Protocol error
          […/deps/mpg123/src/output/alsa.c:165] error: cannot open device default
          Error: open() failed: -1
          at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
          at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
          at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
          at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
          at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
          at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
          at emitNone (events.js:111:20)
          at Reader.emit (events.js:208:7)
          at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
          at _combinedTickCallback (internal/process/next_tick.js:131:7)
          Some error happens. Try again.
          Whoops! There was an uncaught exception…
          TypeError: this.sendSocketNotification is not a function
          at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:296:20)
          at process._tickCallback (internal/process/next_tick.js:180:9)
          ya looks like speaker error
          • Cr4z33C
            Cr4z33 @Guest
            @Sean
            If I use null I get a black MMM screen.
            If I use hw:0,0 I get the config.js message.
            Finally if I use "hw:0,0" (with quotes) I get a black MM screen again.
            :smiling_face_with_open_mouth_cold_sweat:
            ? 1 Reply Last reply
              @cr4z33
              Ok… Are you using Telegram?
              I can give more direct help on Telegram. My id is @eouia.
              Here is not so good place to talk these things.
              • Cr4z33C
                Cr4z33 @Guest
                @Sean
                Yep adding you right now. :)
                • citizendevpiC
                  citizendevpi
                  so i updated and did not change config (yet) no vidieo or pics are showing up
                    A Former User @citizendevpi
                    @citizendevpi
                    :) You can also talk on Telegram. I prefer that then talking here. :)
                    • Cr4z33C
                      Cr4z33 @Cr4z33
                      I want to thank @Sean publicly for having helped me privately into solving the issue! :clapping_hands_medium-light_skin_tone: :thumbs_up_medium-light_skin_tone:
                      • citizendevpiC
                        citizendevpi
                        i cannot get hotword to detect any sound ?
                          @citizendevpi
                          More details are needed for detail answer.
                          you can set record.verbose: true for checking your mic works properly. But before that, you should confirm there was any other error to issue. Check your error log.
                          citizendevpiC 1 Reply Last reply
                          • citizendevpiC
                            citizendevpi @Guest
                            @sean arecord: main:788: audio open error: Device or resource busy and where is my error log?
                            ? 2 Replies Last reply
                              @citizendevpi
                              Your system seems not properly configured to use audio device. that might be not the issue of module itself.
                              And you can see the log with
                              pm2 log mm #or your registered process name for MagicMirror
                              or
                              stop pm2 then npm start dev in your MM directory.
                                @citizendevpi
                                Anyway,
                                You should confirm to check your audio device card and name, and your RPI should be able to run below commands (or similar)
                                arecord -d 5 test.wav
                                or
                                arecord --device plughw:1,0 -d 5  test.wav
                                (plughw:1,0 might be different. You should find your proper device card and number with arecord -l)
                                • citizendevpiC
                                  citizendevpi
                                  @sean said in MMM-AssistantMk2 & MMM-GAction:
                                  ? citizendevpiC 2 Replies Last reply
                                    @citizendevpi said in MMM-AssistantMk2 & MMM-GAction:
                                    That works? If so, you can set your config record.device: "plughw:1,0",
                                    • citizendevpiC
                                      citizendevpi @citizendevpi
                                      @citizendevpi pi@raspberrypi:~ $ arecord -d 5 test.wav
                                      Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                                      pi@raspberrypi:~ $ arecord -l)
                                      bash: syntax error near unexpected token )' pi@raspberrypi:~ $ arecord -1 arecord: invalid option -- '1' Try arecord --help’ for more information.
                                      pi@raspberrypi:~ $ arecord --device plughw:1,0 -d 5 test.wav
                                      ALSA lib pcm_hw.c:1713:(_snd_pcm_hw_open) Invalid value for card
                                      arecord: main:788: audio open error: No such file or directory
                                        @citizendevpi
                                        Ok. forget my previous answer.
                                        arecord -l
                                        It’s l (small L), not 1 (one)
                                        • citizendevpiC
                                          citizendevpi @Guest
                                          @sean **** List of CAPTURE Hardware Devices ****
                                          card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-hifi-0 []
                                          Subdevices: 0/1
                                          Subdevice #0: subdevice #0
                                            @citizendevpi
                                            Your recording device is plughw:0,0. or default. Remember it.
                                            Then try this.
                                            arecord -d 10 test.wav
                                            Say something. It will be record your voice to test.wav on 10 secs.
                                            Works?
                                            If so, then,
                                            aplay test.wav
                                            It should play previous recording from arecord. Can you hear anything?
                                            • 10
                                            • 21
                                            • 22
                                            • 8 / 22
