    MMM-AssistantMk2
    421 Posts 61 Posters 714.0k Views 57 Watching
      sgopala @Cr4z33
      @cr4z33 There is a small typo in the config file, please correct as under:
      Incorrect: [replace this]
      play: { // Full values are in FOR EXPERTS section.
      playProgram: “mpg321”, // recommended.
      Correct: [with this]
        [[global:former-user]] @sgopala
        @sgopala Thank you!! I’ve fixed. I think I had assumed that was the last field of ESSENTIALS parts, so I might have missed the last comma.
          sgopala @Guest
          @sean Thanks a ton for your modules sir, you are a rockstar. But somehow I liked the previous version because of the following reasons:
          (i) there is a delay after the hotword detection in the new version
          (ii) the hotword detection hangs after 1st interaction with the assistant
          (iii) the output window (iframe) was better sized and placed, too small on this version
          Request to please see if these are feasible.
          Once again, thanks a lot for this lovely module.
            @sgopala
            You can always checkout the older version from github (use 1.x.x-final-snap)
            And for the issues;
            • some delay is added intentionally to avoid possible collision. I’ll modify it could be customizable in next patch.
            • output size could be controllable with screenZoom field.
            Thanks.
            • Cr4z33C Offline
              Cr4z33 @Guest
              @sgopala Thanks for pointing this out. ;)
              @sean I keep getting either a black MM screen or the ‘config.js’ message.
              At this point I prefer to work with a config with MMM-AssistantMk2 only and no other modules until everything is working 100%.
              If you could help me by giving please a look at the below config? :)
              Please note that I am trying to use
              0:0
              as device Id.
              https://pastebin.com/ePfrtR75
                [[global:former-user]] @Cr4z33
                @cr4z33
                Try this.
                  module: "MMM-AssistantMk2",
                    record: {
                      recordProgram: "arecord",
                      device: null        // or device: "hw:0,0"
                    play: {
                      playProgram: "mpg321",
                • citizendevpiC Offline
                  citizendevpi @Guest
                  @sean sweet i added a bunch of outher modules and now get a memory error how do i update to the newer version so hopefully these errors sort themselvs out
                    citizendevpi
                    !!! { audioFormat: 1,
                    endianness: ‘LE’,
                    channels: 1,
                    sampleRate: 16000,
                    byteRate: 32000,
                    blockAlign: 2,
                    bitDepth: 16,
                    signed: true }
                    mmap() failed: Cannot allocate memory
                    Failed to create permanent mapping for memfd region with ID = 3246537711
                    Ignoring received block reference with non-registered memfd ID = 3246537711
                    ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Protocol error
                    […/deps/mpg123/src/output/alsa.c:165] error: cannot open device default
                    Error: open() failed: -1
                    at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
                    at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
                    at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                    at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                    at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                    at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
                    at emitNone (events.js:111:20)
                    at Reader.emit (events.js:208:7)
                    at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
                    at _combinedTickCallback (internal/process/next_tick.js:131:7)
                    Some error happens. Try again.
                    Whoops! There was an uncaught exception…
                    TypeError: this.sendSocketNotification is not a function
                    at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:296:20)
                    at process._tickCallback (internal/process/next_tick.js:180:9)
                    ya looks like speaker error
                    • Cr4z33C Offline
                      Cr4z33 @Guest
                      @Sean
                      If I use null I get a black MMM screen.
                      If I use hw:0,0 I get the config.js message.
                      Finally if I use "hw:0,0" (with quotes) I get a black MM screen again.
                      :smiling_face_with_open_mouth_cold_sweat:
                        @cr4z33
                        Ok… Are you using Telegram?
                        I can give more direct help on Telegram. My id is @eouia.
                        Here is not so good place to talk these things.
                        • Cr4z33C Offline
                          Cr4z33 @Guest
                          @Sean
                          Yep adding you right now. :)
                            citizendevpi
                            so i updated and did not change config (yet) no vidieo or pics are showing up
                              [[global:former-user]] @citizendevpi
                              @citizendevpi
                              :) You can also talk on Telegram. I prefer that then talking here. :)
                              • Cr4z33C Offline
                                Cr4z33 @Cr4z33
                                I want to thank @Sean publicly for having helped me privately into solving the issue! :clapping_hands_medium-light_skin_tone: :thumbs_up_medium-light_skin_tone:
                                  citizendevpi
                                  i cannot get hotword to detect any sound ?
                                    @citizendevpi
                                    More details are needed for detail answer.
                                    you can set record.verbose: true for checking your mic works properly. But before that, you should confirm there was any other error to issue. Check your error log.
                                    citizendevpiC 1 Reply Last reply Reply Quote 0
                                      citizendevpi @Guest
                                      @sean arecord: main:788: audio open error: Device or resource busy and where is my error log?
                                        @citizendevpi
                                        Your system seems not properly configured to use audio device. that might be not the issue of module itself.
                                        And you can see the log with
                                        pm2 log mm #or your registered process name for MagicMirror
                                        or
                                        stop pm2 then npm start dev in your MM directory.
                                          @citizendevpi
                                          Anyway,
                                          You should confirm to check your audio device card and name, and your RPI should be able to run below commands (or similar)
                                          arecord -d 5 test.wav
                                          or
                                          arecord --device plughw:1,0 -d 5  test.wav
                                          (plughw:1,0 might be different. You should find your proper device card and number with arecord -l)
                                            citizendevpi
                                            @sean said in MMM-AssistantMk2 & MMM-GAction:
                                            ? citizendevpiC 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 21
                                            • 22
                                            • 8 / 22
