    MMM-AssistantMk2
    421 Posts 61 Posters 804.5k Views 57 Watching
      A Former User @sgopala
      @sgopala
      You can always checkout the older version from github (use 1.x.x-final-snap)
      And for the issues;
      • some delay is added intentionally to avoid possible collision. I’ll modify it could be customizable in next patch.
      • output size could be controllable with screenZoom field.
      Thanks.
      Cr4z33C 1 Reply Last reply
      • Cr4z33C
        Cr4z33 @Guest
        @sgopala Thanks for pointing this out. ;)
        @sean I keep getting either a black MM screen or the ‘config.js’ message.
        At this point I prefer to work with a config with MMM-AssistantMk2 only and no other modules until everything is working 100%.
        If you could help me by giving please a look at the below config? :)
        Please note that I am trying to use
        0:0
        as device Id.
        https://pastebin.com/ePfrtR75
        ? 1 Reply Last reply
          A Former User @Cr4z33
          @cr4z33
          Try this.
            module: "MMM-AssistantMk2",
              record: {
                recordProgram: "arecord",
                device: null        // or device: "hw:0,0"
              play: {
                playProgram: "mpg321",
          • citizendevpiC
            citizendevpi @Guest
            @sean sweet i added a bunch of outher modules and now get a memory error how do i update to the newer version so hopefully these errors sort themselvs out
            • citizendevpiC
              citizendevpi
              !!! { audioFormat: 1,
              endianness: ‘LE’,
              channels: 1,
              sampleRate: 16000,
              byteRate: 32000,
              blockAlign: 2,
              bitDepth: 16,
              signed: true }
              mmap() failed: Cannot allocate memory
              Failed to create permanent mapping for memfd region with ID = 3246537711
              Ignoring received block reference with non-registered memfd ID = 3246537711
              ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Protocol error
              […/deps/mpg123/src/output/alsa.c:165] error: cannot open device default
              Error: open() failed: -1
              at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
              at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
              at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
              at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
              at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
              at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
              at emitNone (events.js:111:20)
              at Reader.emit (events.js:208:7)
              at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
              at _combinedTickCallback (internal/process/next_tick.js:131:7)
              Some error happens. Try again.
              Whoops! There was an uncaught exception…
              TypeError: this.sendSocketNotification is not a function
              at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:296:20)
              at process._tickCallback (internal/process/next_tick.js:180:9)
              ya looks like speaker error
              • Cr4z33C
                Cr4z33 @Guest
                @Sean
                If I use null I get a black MMM screen.
                If I use hw:0,0 I get the config.js message.
                Finally if I use "hw:0,0" (with quotes) I get a black MM screen again.
                :smiling_face_with_open_mouth_cold_sweat:
                  @cr4z33
                  Ok… Are you using Telegram?
                  I can give more direct help on Telegram. My id is @eouia.
                  Here is not so good place to talk these things.
                  • Cr4z33C
                    Cr4z33 @Guest
                    @Sean
                    Yep adding you right now. :)
                    • citizendevpiC
                      citizendevpi
                      so i updated and did not change config (yet) no vidieo or pics are showing up
                        A Former User @citizendevpi
                        @citizendevpi
                        :) You can also talk on Telegram. I prefer that then talking here. :)
                        • Cr4z33C
                          Cr4z33 @Cr4z33
                          I want to thank @Sean publicly for having helped me privately into solving the issue! :clapping_hands_medium-light_skin_tone: :thumbs_up_medium-light_skin_tone:
                          • citizendevpiC
                            citizendevpi
                            i cannot get hotword to detect any sound ?
                              @citizendevpi
                              More details are needed for detail answer.
                              you can set record.verbose: true for checking your mic works properly. But before that, you should confirm there was any other error to issue. Check your error log.
                              citizendevpiC 1 Reply Last reply
                              • citizendevpiC
                                citizendevpi @Guest
                                @sean arecord: main:788: audio open error: Device or resource busy and where is my error log?
                                ? 2 Replies Last reply
                                  @citizendevpi
                                  Your system seems not properly configured to use audio device. that might be not the issue of module itself.
                                  And you can see the log with
                                  pm2 log mm #or your registered process name for MagicMirror
                                  or
                                  stop pm2 then npm start dev in your MM directory.
                                    @citizendevpi
                                    Anyway,
                                    You should confirm to check your audio device card and name, and your RPI should be able to run below commands (or similar)
                                    arecord -d 5 test.wav
                                    or
                                    arecord --device plughw:1,0 -d 5  test.wav
                                    (plughw:1,0 might be different. You should find your proper device card and number with arecord -l)
                                    • citizendevpiC
                                      citizendevpi
                                      @sean said in MMM-AssistantMk2 & MMM-GAction:
                                      ? citizendevpiC 2 Replies Last reply
                                        @citizendevpi said in MMM-AssistantMk2 & MMM-GAction:
                                        That works? If so, you can set your config record.device: "plughw:1,0",
                                        • citizendevpiC
                                          citizendevpi @citizendevpi
                                          @citizendevpi pi@raspberrypi:~ $ arecord -d 5 test.wav
                                          Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                                          pi@raspberrypi:~ $ arecord -l)
                                          bash: syntax error near unexpected token )' pi@raspberrypi:~ $ arecord -1 arecord: invalid option -- '1' Try arecord --help’ for more information.
                                          pi@raspberrypi:~ $ arecord --device plughw:1,0 -d 5 test.wav
                                          ALSA lib pcm_hw.c:1713:(_snd_pcm_hw_open) Invalid value for card
                                          arecord: main:788: audio open error: No such file or directory
                                            @citizendevpi
                                            Ok. forget my previous answer.
                                            arecord -l
                                            It’s l (small L), not 1 (one)
                                            • 10
                                            • 21
                                            • 22
                                            • 8 / 22
