    MMM-AssistantMk2
    421 Posts 61 Posters 804.8k Views 57 Watching
    • citizendevpiC
      citizendevpi @Guest
      @sean sweet i added a bunch of outher modules and now get a memory error how do i update to the newer version so hopefully these errors sort themselvs out
      • citizendevpiC
        citizendevpi
        !!! { audioFormat: 1,
        endianness: ‘LE’,
        channels: 1,
        sampleRate: 16000,
        byteRate: 32000,
        blockAlign: 2,
        bitDepth: 16,
        signed: true }
        mmap() failed: Cannot allocate memory
        Failed to create permanent mapping for memfd region with ID = 3246537711
        Ignoring received block reference with non-registered memfd ID = 3246537711
        ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Protocol error
        […/deps/mpg123/src/output/alsa.c:165] error: cannot open device default
        Error: open() failed: -1
        at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
        at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
        at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
        at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
        at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
        at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
        at emitNone (events.js:111:20)
        at Reader.emit (events.js:208:7)
        at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
        at _combinedTickCallback (internal/process/next_tick.js:131:7)
        Some error happens. Try again.
        Whoops! There was an uncaught exception…
        TypeError: this.sendSocketNotification is not a function
        at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:296:20)
        at process._tickCallback (internal/process/next_tick.js:180:9)
        ya looks like speaker error
        • Cr4z33C
          Cr4z33 @Guest
          @Sean
          If I use null I get a black MMM screen.
          If I use hw:0,0 I get the config.js message.
          Finally if I use "hw:0,0" (with quotes) I get a black MM screen again.
          :smiling_face_with_open_mouth_cold_sweat:
          ? 1 Reply Last reply
            A Former User @Cr4z33
            @cr4z33
            Ok… Are you using Telegram?
            I can give more direct help on Telegram. My id is @eouia.
            Here is not so good place to talk these things.
            Cr4z33C 1 Reply Last reply
            • Cr4z33C
              Cr4z33 @Guest
              @Sean
              Yep adding you right now. :)
              • citizendevpiC
                citizendevpi
                so i updated and did not change config (yet) no vidieo or pics are showing up
                  A Former User @citizendevpi
                  @citizendevpi
                  :) You can also talk on Telegram. I prefer that then talking here. :)
                  • Cr4z33C
                    Cr4z33 @Cr4z33
                    I want to thank @Sean publicly for having helped me privately into solving the issue! :clapping_hands_medium-light_skin_tone: :thumbs_up_medium-light_skin_tone:
                    • citizendevpiC
                      citizendevpi
                      i cannot get hotword to detect any sound ?
                        @citizendevpi
                        More details are needed for detail answer.
                        you can set record.verbose: true for checking your mic works properly. But before that, you should confirm there was any other error to issue. Check your error log.
                        citizendevpiC 1 Reply Last reply
                        • citizendevpiC
                          citizendevpi @Guest
                          @sean arecord: main:788: audio open error: Device or resource busy and where is my error log?
                          ? 2 Replies Last reply
                            @citizendevpi
                            Your system seems not properly configured to use audio device. that might be not the issue of module itself.
                            And you can see the log with
                            pm2 log mm #or your registered process name for MagicMirror
                            or
                            stop pm2 then npm start dev in your MM directory.
                              @citizendevpi
                              Anyway,
                              You should confirm to check your audio device card and name, and your RPI should be able to run below commands (or similar)
                              arecord -d 5 test.wav
                              or
                              arecord --device plughw:1,0 -d 5  test.wav
                              (plughw:1,0 might be different. You should find your proper device card and number with arecord -l)
                              • citizendevpiC
                                citizendevpi
                                @sean said in MMM-AssistantMk2 & MMM-GAction:
                                ? citizendevpiC 2 Replies Last reply
                                  @citizendevpi said in MMM-AssistantMk2 & MMM-GAction:
                                  That works? If so, you can set your config record.device: "plughw:1,0",
                                  • citizendevpiC
                                    citizendevpi @citizendevpi
                                    @citizendevpi pi@raspberrypi:~ $ arecord -d 5 test.wav
                                    Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                                    pi@raspberrypi:~ $ arecord -l)
                                    bash: syntax error near unexpected token )' pi@raspberrypi:~ $ arecord -1 arecord: invalid option -- '1' Try arecord --help’ for more information.
                                    pi@raspberrypi:~ $ arecord --device plughw:1,0 -d 5 test.wav
                                    ALSA lib pcm_hw.c:1713:(_snd_pcm_hw_open) Invalid value for card
                                    arecord: main:788: audio open error: No such file or directory
                                      @citizendevpi
                                      Ok. forget my previous answer.
                                      arecord -l
                                      It’s l (small L), not 1 (one)
                                      • citizendevpiC
                                        citizendevpi @Guest
                                        @sean **** List of CAPTURE Hardware Devices ****
                                        card 0: sndrpigooglevoi [snd_rpi_googlevoicehat_soundcar], device 0: Google voiceHAT SoundCard HiFi voicehat-hifi-0 []
                                        Subdevices: 0/1
                                        Subdevice #0: subdevice #0
                                          @citizendevpi
                                          Your recording device is plughw:0,0. or default. Remember it.
                                          Then try this.
                                          arecord -d 10 test.wav
                                          Say something. It will be record your voice to test.wav on 10 secs.
                                          Works?
                                          If so, then,
                                          aplay test.wav
                                          It should play previous recording from arecord. Can you hear anything?
                                          • citizendevpiC
                                            citizendevpi @Guest
                                            @sean yes barley
                                            but yes
                                            • 10
                                            • 11
                                            • 21
                                            • 22
                                            • 9 / 22
