    MMM-AssistantMk2
    421 Posts 61 Posters 687.4k Views 57 Watching
    • Cr4z33C Offline
      Cr4z33 @Guest
      @sean
      Again I made a noob error… I ran both commands at once lol! :smiling_face_with_open_mouth_cold_sweat:
      Running them separately worked like a charm! :thumbs_up_medium-light_skin_tone:
      I am going now to retry with the module addition.
      • Cr4z33C Offline
        Cr4z33 @Guest
        @sean
        So after following the installation instructions I ran a test by using the ‘Very simple version but limited’ module.
        As a result all I get now from MM is a black empty screen (no config.js message and no trace of other modules can be seen).
          sgopala @Cr4z33
          @cr4z33 There is a small typo in the config file, please correct as under:
          Incorrect: [replace this]
          play: { // Full values are in FOR EXPERTS section.
          playProgram: “mpg321”, // recommended.
          Correct: [with this]
            A Former User @sgopala
            @sgopala Thank you!! I’ve fixed. I think I had assumed that was the last field of ESSENTIALS parts, so I might have missed the last comma.
              sgopala @Guest
              @sean Thanks a ton for your modules sir, you are a rockstar. But somehow I liked the previous version because of the following reasons:
              (i) there is a delay after the hotword detection in the new version
              (ii) the hotword detection hangs after 1st interaction with the assistant
              (iii) the output window (iframe) was better sized and placed, too small on this version
              Request to please see if these are feasible.
              Once again, thanks a lot for this lovely module.
                @sgopala
                You can always checkout the older version from github (use 1.x.x-final-snap)
                And for the issues;
                • some delay is added intentionally to avoid possible collision. I’ll modify it could be customizable in next patch.
                • output size could be controllable with screenZoom field.
                Thanks.
                • Cr4z33C Offline
                  Cr4z33 @Guest
                  @sgopala Thanks for pointing this out. ;)
                  @sean I keep getting either a black MM screen or the ‘config.js’ message.
                  At this point I prefer to work with a config with MMM-AssistantMk2 only and no other modules until everything is working 100%.
                  If you could help me by giving please a look at the below config? :)
                  Please note that I am trying to use
                  0:0
                  as device Id.
                  https://pastebin.com/ePfrtR75
                    A Former User @Cr4z33
                    @cr4z33
                    Try this.
                      module: "MMM-AssistantMk2",
                        record: {
                          recordProgram: "arecord",
                          device: null        // or device: "hw:0,0"
                        play: {
                          playProgram: "mpg321",
                    • citizendevpiC Offline
                      citizendevpi @Guest
                      @sean sweet i added a bunch of outher modules and now get a memory error how do i update to the newer version so hopefully these errors sort themselvs out
                        citizendevpi
                        !!! { audioFormat: 1,
                        endianness: ‘LE’,
                        channels: 1,
                        sampleRate: 16000,
                        byteRate: 32000,
                        blockAlign: 2,
                        bitDepth: 16,
                        signed: true }
                        mmap() failed: Cannot allocate memory
                        Failed to create permanent mapping for memfd region with ID = 3246537711
                        Ignoring received block reference with non-registered memfd ID = 3246537711
                        ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Protocol error
                        […/deps/mpg123/src/output/alsa.c:165] error: cannot open device default
                        Error: open() failed: -1
                        at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
                        at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
                        at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                        at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                        at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                        at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
                        at emitNone (events.js:111:20)
                        at Reader.emit (events.js:208:7)
                        at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
                        at _combinedTickCallback (internal/process/next_tick.js:131:7)
                        Some error happens. Try again.
                        Whoops! There was an uncaught exception…
                        TypeError: this.sendSocketNotification is not a function
                        at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:296:20)
                        at process._tickCallback (internal/process/next_tick.js:180:9)
                        ya looks like speaker error
                        • Cr4z33C Offline
                          Cr4z33 @Guest
                          @Sean
                          If I use null I get a black MMM screen.
                          If I use hw:0,0 I get the config.js message.
                          Finally if I use "hw:0,0" (with quotes) I get a black MM screen again.
                            @cr4z33
                            Ok… Are you using Telegram?
                            I can give more direct help on Telegram. My id is @eouia.
                            Here is not so good place to talk these things.
                            • Cr4z33C Offline
                              Cr4z33 @Guest
                              @Sean
                              Yep adding you right now. :)
                                citizendevpi
                                so i updated and did not change config (yet) no vidieo or pics are showing up
                                  A Former User @citizendevpi
                                  @citizendevpi
                                  :) You can also talk on Telegram. I prefer that then talking here. :)
                                  • Cr4z33C Offline
                                    Cr4z33 @Cr4z33
                                    I want to thank @Sean publicly for having helped me privately into solving the issue! :clapping_hands_medium-light_skin_tone: :thumbs_up_medium-light_skin_tone:
                                      citizendevpi
                                      i cannot get hotword to detect any sound ?
                                        @citizendevpi
                                        More details are needed for detail answer.
                                        you can set record.verbose: true for checking your mic works properly. But before that, you should confirm there was any other error to issue. Check your error log.
                                        citizendevpiC 1 Reply Last reply Reply Quote 0
                                          citizendevpi @Guest
                                          @sean arecord: main:788: audio open error: Device or resource busy and where is my error log?
                                            @citizendevpi
                                            Your system seems not properly configured to use audio device. that might be not the issue of module itself.
                                            And you can see the log with
                                            pm2 log mm #or your registered process name for MagicMirror
                                            or
                                            stop pm2 then npm start dev in your MM directory.
                                            • 10
                                            • 21
                                            • 22
                                            • 8 / 22
