    MMM-AssistantMk2
    421 Posts 61 Posters 741.7k Views 57 Watching
      [[global:former-user]] @Cr4z33
      @cr4z33
      Oops ! my mistake!
      arecord -d 5 -D hw:0,0 test.wav
      • Cr4z33C Offline
        Cr4z33 @Guest
        @sean said in MMM-AssistantMk2 & MMM-GAction:
        @cr4z33
        cat ~/.asoundrc
        Tell me the result.
        How you can setup previously? (I think you purchased that device for Google AIY project. Was there any instructions?)
        pi@raspberrypi:~ $ cat ~/.asoundrc
        cat: /home/pi/.asoundrc: File or directory does not exist
        It’s the so- called Google Voice Kit AIY (https://aiyprojects.withgoogle.com/voice-v1/).
        I used a ready meal Raspbian image made by Google.
        Apart from creating the JSON file everything else consists of ready scripts (i.e assistant_library_demo.py is a script to runs and uses Google Assistant):
        https://github.com/google/aiyprojects-raspbian/tree/voicekit
          @cr4z33
          Hmmm… As I know,
          arecord -d 5 test.wav
          aplay test.wav
          This should work because there is no other suspicious things. your card and device no is 0,0 and that is the default.
          Cr4z33C 2 Replies Last reply Reply Quote 0
          • Cr4z33C Offline
            Cr4z33 @Guest
            @sean
            Again I made a noob error… I ran both commands at once lol! :smiling_face_with_open_mouth_cold_sweat:
            Running them separately worked like a charm! :thumbs_up_medium-light_skin_tone:
            I am going now to retry with the module addition.
            • Cr4z33C Offline
              Cr4z33 @Guest
              @sean
              So after following the installation instructions I ran a test by using the ‘Very simple version but limited’ module.
              As a result all I get now from MM is a black empty screen (no config.js message and no trace of other modules can be seen).
                sgopala @Cr4z33
                @cr4z33 There is a small typo in the config file, please correct as under:
                Incorrect: [replace this]
                play: { // Full values are in FOR EXPERTS section.
                playProgram: “mpg321”, // recommended.
                Correct: [with this]
                  [[global:former-user]] @sgopala
                  @sgopala Thank you!! I’ve fixed. I think I had assumed that was the last field of ESSENTIALS parts, so I might have missed the last comma.
                    sgopala @Guest
                    @sean Thanks a ton for your modules sir, you are a rockstar. But somehow I liked the previous version because of the following reasons:
                    (i) there is a delay after the hotword detection in the new version
                    (ii) the hotword detection hangs after 1st interaction with the assistant
                    (iii) the output window (iframe) was better sized and placed, too small on this version
                    Request to please see if these are feasible.
                    Once again, thanks a lot for this lovely module.
                      @sgopala
                      You can always checkout the older version from github (use 1.x.x-final-snap)
                      And for the issues;
                      • some delay is added intentionally to avoid possible collision. I’ll modify it could be customizable in next patch.
                      • output size could be controllable with screenZoom field.
                      Thanks.
                      • Cr4z33C Offline
                        Cr4z33 @Guest
                        @sgopala Thanks for pointing this out. ;)
                        @sean I keep getting either a black MM screen or the ‘config.js’ message.
                        At this point I prefer to work with a config with MMM-AssistantMk2 only and no other modules until everything is working 100%.
                        If you could help me by giving please a look at the below config? :)
                        Please note that I am trying to use
                        0:0
                        as device Id.
                        https://pastebin.com/ePfrtR75
                          @cr4z33
                          Try this.
                            module: "MMM-AssistantMk2",
                              record: {
                                recordProgram: "arecord",
                                device: null        // or device: "hw:0,0"
                              play: {
                                playProgram: "mpg321",
                          • citizendevpiC Offline
                            citizendevpi @Guest
                            @sean sweet i added a bunch of outher modules and now get a memory error how do i update to the newer version so hopefully these errors sort themselvs out
                              citizendevpi
                              !!! { audioFormat: 1,
                              endianness: ‘LE’,
                              channels: 1,
                              sampleRate: 16000,
                              byteRate: 32000,
                              blockAlign: 2,
                              bitDepth: 16,
                              signed: true }
                              mmap() failed: Cannot allocate memory
                              Failed to create permanent mapping for memfd region with ID = 3246537711
                              Ignoring received block reference with non-registered memfd ID = 3246537711
                              ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Protocol error
                              […/deps/mpg123/src/output/alsa.c:165] error: cannot open device default
                              Error: open() failed: -1
                              at Speaker._open (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:106:13)
                              at Speaker._write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/speaker/index.js:183:23)
                              at doWrite (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:428:64)
                              at writeOrBuffer (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:417:5)
                              at Speaker.Writable.write (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/readable-stream/lib/_stream_writable.js:334:11)
                              at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:287:17)
                              at emitNone (events.js:111:20)
                              at Reader.emit (events.js:208:7)
                              at /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/wav/node_modules/readable-stream/lib/_stream_readable.js:934:16
                              at _combinedTickCallback (internal/process/next_tick.js:131:7)
                              Some error happens. Try again.
                              Whoops! There was an uncaught exception…
                              TypeError: this.sendSocketNotification is not a function
                              at Reader. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:296:20)
                              at process._tickCallback (internal/process/next_tick.js:180:9)
                              ya looks like speaker error
                              • Cr4z33C Offline
                                Cr4z33 @Guest
                                @Sean
                                If I use null I get a black MMM screen.
                                If I use hw:0,0 I get the config.js message.
                                Finally if I use "hw:0,0" (with quotes) I get a black MM screen again.
                                  @cr4z33
                                  Ok… Are you using Telegram?
                                  I can give more direct help on Telegram. My id is @eouia.
                                  Here is not so good place to talk these things.
                                  • Cr4z33C Offline
                                    Cr4z33 @Guest
                                    @Sean
                                    Yep adding you right now. :)
                                      citizendevpi
                                      so i updated and did not change config (yet) no vidieo or pics are showing up
                                        [[global:former-user]] @citizendevpi
                                        @citizendevpi
                                        :) You can also talk on Telegram. I prefer that then talking here. :)
                                        • Cr4z33C Offline
                                          Cr4z33 @Cr4z33
                                          I want to thank @Sean publicly for having helped me privately into solving the issue! :clapping_hands_medium-light_skin_tone: :thumbs_up_medium-light_skin_tone:
                                            citizendevpi
                                            i cannot get hotword to detect any sound ?
                                            • 10
                                            • 21
                                            • 22
                                            • 8 / 22
