    MMM-NOAA3 - No icon
    11 Posts 3 Posters 10.2k Views 3 Watching
      JRCelis
      My MMM-NOAA3 module is working partially, the four days forecast does not show up and the Icon at the top does not appear. How can I fix it? Thanks
      language: "en",
      timeFormat: 12,
      units: "metric",
      		module: "alert",
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		header: "US Holidays",
      				{symbol: "calendar-check-o ",
      		module: "compliments",
      		position: "lower_third"
      		disable: true,
      		module: "currentweather",
      			locationID: "60585xx",  //ID from http://www.openweathermap.org/help/city_list.txt
      			appid: "1622a28870ff593b300001xxxxxxxxxx"
      		disabled: true,
      		module: "weatherforecast",
      		header: "Weather Forecast",
      			locationID: "6058560",  //ID from http://www.openweathermap.org/help/city_list.txt
      		module: 'MMM-NOAA3',
      		position: 'top_right',
         			provider: "openweather", // From list above
         			apiKey: "1622a28870ff593b300001xxxxxxxxxx",        // From one of the providers listed above
         			airKey: "MdzfQP4dSXbMCyxxx",
         			css: "NOAA4"                   // THIS MUST CONTAIN A CSS STYLE NAME
      		module: "newsfeed",
      		position: "bottom_bar",
      			feeds: [
      					title: "New York Times",
      			showSourceTitle: true,
      			showPublishDate: true
      • cowboysdudeC Offline
        You can mark this as solved…it was ;) Make sure you have ALL the icon images in your directory :)
        • richland007R Offline
          richland007
          @cowboysdude How do we make sure of that???.. cause i have the same problem and the text its a little bit too large i think and not aligned properly with the rest of the modules …i have it positioned “top_right”
          Always Thankful for your buddy
          Denis
            richland007
            @cowboysdude How do i fix the formatting of this module please …have a look at the picture above it seems like its working but it is kinda jacked :)
            D
              richland007
              It does not give the name of the city but the weather background and the icon are visible… so the Name of the city and the 4 day forecast is missing also the alignment is messed up with large letters is not properly centered at all
              D
                Looks like something else is messing it up…what’s in your custom.css file?
                and/or do you have a css file defined in your config section in NOAA?
                richland007R 1 Reply Last reply Reply Quote 1
                  richland007 @cowboysdude
                  @cowboysdude On my MM custom.css file i added the following later on after taking @Sean advice to enhance the background and the contours of the modules
                   * Magic Mirror                                      *
                   * Custom CSS                                        *
                   * By Michael Teeuw http://michaelteeuw.nl           *
                   * MIT Licensed.                                     *
                   * Add any custom CSS below.                         *
                   * Changes to this files will be ignored by GIT. *
                   body {
                  .module {
                    background-color:rgba(0,0,0,0.5);
                    border-radius: 20px;
                    padding:10px;
                  on my config.js file under MMM-NOAA3 i have
                  css: "NOAA3",                   // THIS MUST CONTAIN A CSS STYLE NAME
                  I tried changing it to other NOAA styles such as 4 etc. and adding MMM-NOAA3 or MMM-NOAA3.css within the parenthesis but no change.
                  Should i uninstall it and installed again??
                  i have the version that works with the MMM-WeatherBackground from @Sean and the background does work correctly to whatever the weather says.
                  Thanks again for your help
                  Denis
                    cowboysdude Module Developer @richland007
                    @richland007 Totally delete that install something went VERY wrong there.
                    Delete the entire directory and go another ‘git clone’…
                    Go to MMM-NOAA3 and type ‘npm install’…
                    richland007R 1 Reply Last reply Reply Quote 0
                      @cowboysdude Re-did everything as you said but no change same result, same look, no forecast
                      I deleted the whole directory git clone again… no luck
                      Denis
                        What provider are you using?
                          @cowboysdude I still haven’t been able to resolve my above problem that my NOAA3 module comes up not formatted right.
                          Here is the error that is logging
                          “length” is undefined etc
                          Oh and i am using OpenWeather looking like this
                          Thank you for your help always appreciated and for this fantastic work
                          D
