    MMM-MyCalendar: Showing wrong dates (days one day in the past)?
    10 Posts 5 Posters 5.2k Views 5 Watching
      Detto65 @Medo
      @medo showEnd:false should do the trick,
      i only used de dateformats to show the dates in a more readable format.
      • L Offline
        lazyboy0284
        I am having a similar but yet different issue.
        I noticed that one of my several calendars was showing activities one day early. I added new events for testing, and they show on the correct day, but the old events show a day off still.
        The green events come from the same calendar. The test events show on the right date in MM, but you can see that the Daycare event shows on the wrong date. I tried the no end “fix”, but that didn’t fix things. I checked my Pi and the calendar timezones and locations, and they all match (US, EN, Chicago). Are the events cached and can the cache be cleared? Any other debugging options that I can be helped with?
        Everything worked fine up until a day or two ago, and I’m not sure what changed.
        Thank you in advance for the help.
        • L Offline
          lazyboy0284 @lazyboy0284
          I think I fixed my issue. I decided to start over (saved my config.js, but wiped everything else), and noticed things seemed fine, except for one calendar. I changed the ordinal date as others have recommended to fix the issue with events earlier than 1970, and saw the issue come back. I changed the date back to 1970, and the issue went away. So ultimately I deleted all calendar items from before 1970 to fix my issue.
            DeToasty
            I have a similar problem. My calender seems to be broken. Holidays and my own appointments where displayed 2-3 days earlier. I dont know how to solve this problem.
            • MedoM Offline
              Medo @Medo
              @medo said in MMM-MyCalendar: Showing wrong dates (days one day in the past)?:
              @detto65 said in MMM-MyCalendar: Showing wrong dates (days one day in the past)?:
              had the same issue, it shows you the end of the event, usually because its an all day event.
              It seems like this has solved my problem. No wrong dates since weeks… Thanks a lot!
