    MM booting to black
    11 Posts 2 Posters 4.8k Views 2 Watching
      dwleo
      Still getting to know this device. I had it working exactly the way I wanted to (almost - PIR still isn’t working, but thats another story).
      My current problem is I have MMM-NFL in the middle screen and want to use Carousel to change it out to MMM-NHL every 5 minutes or so. Installed the Carousel module, rebooted and after the ‘road’ picture, instead of opening the usual screen, it goes to black and I cannot recover from it. I tried opening the config.js but the screen jumps to black after a few seconds. I just need to get access to find the error.
      Suggestions?
      • lavolp3L Offline
        lavolp3 Module Developer @dwleo
        @dwleo can you ssh into the mirror?
        If you access the mirror directly type in
        pm2 stop mm
        to stop the mirror.
        Lokk for a response that the mm fork has been stopped. If you got an error, look for the process name using
        pm2 status
        However I think it’s best to ssh into the mirror.
        As soon as you have control :-) go into the MagicMirror folder and type
        npm run config:check
        Look if there is an error message, go into the config.js and try to solve it.
        If you don’t know what to do, post your config withoit sensitive information
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          dwleo
          Thanks lavolp3,
          I am too new on this. What is ssh?
          • lavolp3L Offline
            @dwleo Oh boy, you’re really new to this :-)
            How can i describe?
            https://www.raspberrypi.org/documentation/remote-access/ssh/
            You’ve got a lot to learn young padawan
            D 2 Replies Last reply Reply Quote 1
              dwleo @lavolp3
              @lavolp3
              OK. I cannot ssh directly into the mirror. Once it goes through the bootup process, it goes black and I cannot get out of it. If I could, I could probably correct the error.
                dwleo @lavolp3
                @lavolp3
                Also while booting up, in the ‘road pic’ phase, I got to click at the menu bar for the cmd screen and typed in pm2 stop mm. Just before the screen went black I got an error msg stating ‘process mm not found’. Then it quickly went to black.
                • lavolp3L Offline
                  @dwleo You need to access the mirror from another device to “ssh into it”. Read the info from the link.
                  Will make things easier.
                  Regarding pm2, you can find out the name of the process entering
                  pm2 list
                  or just try killing the process using
                  pm2 stop all
                  Not sure if this works.
                    dwleo @lavolp3
                    @lavolp3 cannot get pm stop all to work. It gives ‘process stop all not found’.
                    As to ssh, all derivatives of this, either command line or remote, requires some additions to Raspberry and I cannot get that as I cannot get a command line.
                    All I need is to stop the boot up process just prior to MM booting up.
                      dwleo @dwleo
                      @dwleo OK. I got in and will try to edit the config.js file somehow.
                        dwleo @dwleo
                        @dwleo That was a convoluted effort but it did the trick.
                        Thanks lavolp3
