    IR Touch Frame calibration
    17 Posts 8 Posters 13.0k Views 9 Watching
      cyberphox
      Just wondering if anyone out there is using an IR Touch Frame?
      How do you have it calibrated if you have the screen rotated?
        cantthink
        Could you not change the rotation of the display to be portrait to match the monitor and calibrate as normal?
          cyberphox
          The IR touch frame works without software with the Pi by just plugging it in…but it thinks it’s always in landscape mode. Wondering if there is a piece of calibration software as there is for windows to calibrate it for portrait
          • cowboysdudeC Offline
            I haven’t used or needed any calibration software for mine… it just works :)
              A Former User @cowboysdude
              @cowboysdude But somebody might have bigger mirror and frame than real screen size, and his touch-solution should be upon the mirrorglass. In that case he need calibration to adjust.
                cyberphox
                actually for some reason it is now working!
                peemoellerP 1 Reply Last reply Reply Quote 0
                • peemoellerP Offline
                  peemoeller @cyberphox
                  @cyberphox I just purchased the IR Touch Frame for my MagicMirror but can’t change it from Landscape to Portrait. How did you manage to calibrate yours? I have a 40" frame. Any help appreciated!
                    cyberphox
                    Xinput calibrator should help
                      @cyberphox thanks! Are you able to point me on how to make the adjustments? I have xinput installed but not sure where to go from here.
                      Thanks for your help!
                        cyberphox
                        run the calibration from the menu…touch the points and that’s it!
