    MMM-CalendarExt
    198 Posts 45 Posters 271.8k Views 45 Watching
      Doudy @Doudy
      @doudy
        A Former User @Doudy
        @doudy said in MMM-CalendarExt:
        How can I delete the text 'in 15 hours’
        add this in your ~/MagicMirror/css/custom.css
        .CALEXT .current .eventTime {
          display:none;
        Or does this indicate the end of the event?
        Sorry, That’s not available.
          Doudy
          That is OK.
            cptkex
            hi! still loving your module but im having some issues :/
            i´ve been trying to add the code you have linked previously to make the calender bigger but i cant seem to stretch it to the screen sides?
            also, why is tuesday bigger then the rest?
            how do i remove the corners for each entry text?
            it doesnt seem to recognize my oneLineEvent: 1; ?
            any help is greatly appriciated
              A Former User @cptkex
              @cptkex
              First, I should know your whole CSS and Configuration to give detail and exact answer,
              Anyway,
              Add this into your MagicMirror/css/custom.css
              .CALEXT .tableStyle {
                  margin:0;
                  max-width: 100%;
              More detailed adjustment could be needed. But most of case, this is enough.
              Because Tuesday has more long-text event than other day. I set this as relative-width. You can fix it by this.
              .CALEXT .tableStyle td {
                  /* Set values for your environment or screen size */
                  width: 17%;
                  max-width: 17%;
                  min-width: 17%;
              Or This.
                /* adjust for your screen size */
                  width: 100px;
              #CALEXT_weeks.tableStyle .event.endHere .eventContainer{
                border:none;
                border-radius:0;
              #CALEXT_weeks.tableStyle .event.startHere {
                border:none;
                border-radius:0;
              It is working. So, Some events are showing only start time. If you grow the width of cell, you can see more clearly.
              Anyway, weeks and months types are not so good for Vertical Screen because vertical-width could be around 1080px,(Maximized, when you remove all the default margin of MM) It means each cell could have only 140px width at most. it would be not enough space for displaying event. You need to use smaller font size.
              (you’d better to learn some CSS skills if you have interests.)
                cptkex @Guest
                @sean thanks for replying, and yes i should definitly learn more CSS if i want to use this. I just needed to know where to start, and i can work myself forward from there. I know the 1080 pixel space isnt optimal for a Weeks setup, but going through all the other alternatives, it provides just the right kind of data for my family´s day to day activities, so its more suitable. I am playing around with the font sizes, trying to find what fits within the design and how visible it is. I have tried other setups for greater visibility, but ended up with this being the best option together with the upcoming one that is more “at a glance”
                thank you so much for your help, ill try to read up on some CSS so i dont bother you with every little detail. My biggest problem has been that i dont know where to start, and now i have enough data to start changing parameters to learn what i need to change to achieve the best possible outcome.
                  @cptkex
                  I think https://www.w3schools.com/ is the best source for the beginners. I wish you have a good luck.
                    Smotx
                    It’s possible to start ‘roll’ at the date of current day and no first day of month ?
                    Thx
                      A Former User @Smotx
                      @smotx Sorry, it can’t without source modifying.
                        jimmysmalls
                        I can’t seem to figure out why I don’t have the start times on my calendar. I’m really liking it other than that. I’m sure it’s probably something simple but I’m open to feeling stupid after the time I’ve spend trying to figure it out haha
                              module: 'MMM-CalendarExt',
                              position: "lower_third", // ignore this.
                                system: {
                                  show: ['month'],
                                  locale: 'en',
                        	  showEmptyView: 1,
                                views: {
                                  month: {
                                    position:'lower_third',
                        	    showWeeks: 0,
                        	    onlyStartingTime:1,
                                calendars :[
                          A Former User @jimmysmalls
                          @jimmysmalls
                          By default, time of month/week view is hidden because there might be not enough space.
                          Add this into your css/custom.css;
                          .CALEXT .tableStyle .eventTime {
                             display: block;
                             order: 3; // when you want to display time under the event title.
                            jimmysmalls @Guest
                            @sean
                            That did the trick, thank you! One other quick question that maybe I’m overlooking the answer to in the documentation but is there a way to have it show the time on a 12 hour format instead of 24?
                              @jimmysmalls
                              use timeFormat: "hh:mm A" instead timeFormat: "HH:mm"
                              If you don’t want AM/PM indicator, just use "hh:mm"
                                JKTitanium @Vauxdvihl
                                @vauxdvihl
                                Hi, Sorry I new here. Do I need a seperate Calender for each icon/emoj? Can I use Rules for one single Calendar?
                                  A Former User @JKTitanium
                                  @jktitanium
                                  Symbol is fixed per calendar.
                                  However each event style(color or font except symbol) could be variable by condition.
                                  • F
                                    Frek
                                    Hi. In weeks view with event time displayed, is there a way to remove the starting time and ending time on full day events?
                                      A Former User @Frek
                                      @frek
                                      display: none;
                                      • F
                                        Frek @Guest
                                        @sean
                                        Thx for the reply.
                                        I already have this in my css to display time, that I want:
                                        div.CALEXT .tableStyle .eventTime {
                                        display:block;
                                        font-weight:normal;
                                        font-size:70%;
                                        But I was wondering if on full day events its possible to only show title, not the time
                                          A Former User @Frek
                                          @frek
                                          div.CALEXT .tableStyle .fulldayevent .eventTime {
                                            display:none;
                                          Try this.
                                          • F
                                            Frek @Guest
                                            @sean
                                            tried adding i to my custom.css and no change. my .css looks like:
                                             * Magic Mirror                                      *
                                             * Custom CSS                                        *
                                             * By Michael Teeuw http://michaelteeuw.nl           *
                                             * MIT Licensed.                                     *
                                             * Add any custom CSS below.                         *
                                             * Changes to this files will be ignored by GIT. *
                                             body {
                                              margin: 10px;
                                              height: calc(100% - 20px);
                                              width: calc(100% - 20px);
                                              display:none;
                                              display:block;
                                              font-weight:normal;
                                              font-size:70%;
                                             .CALEXT .tableStyle td.slot {
                                              max-height:200px;
                                              height:200px;
                                              margin:0;
                                              max-width: 100%;
                                            • 10
                                            • 7 / 10
