    Calendar Overflow Issue [solved]
    12 Posts 2 Posters 9.2k Views 1 Watching
      MechMatt @MichMich
      @MichMich how do you change the calendar to 24 hr? When i set the timeformat variable to 24 it only changes the clock and weather modules.
      • MichMichM
        MichMich
        I’m sorry … just checked: the time format of the clock is tied to the language (locale). There currently is no way to change the time format of the calendar.
        M 1 Reply Last reply
          MechMatt @MichMich
          @MichMich ok. Its also worth noting that I do not have the overflow issue with the clock module in 12 hr format as others have reported. My overflow issue only affects the calendar module.
          MichMichM 1 Reply Last reply
          • MichMichM
            MichMich @MechMatt
            @MechMatt That’s correct. The clock and weather currently have a hot fix in place. (Something which is more difficult for the calendar.)
            • MichMichM
              MichMich
              I just pushed a possible fix for this issue. Could you give it a try?
              (more info: https://github.com/MichMich/MagicMirror/issues/181)
                MechMatt
                awesome! I loaded it up and so far its looking good (been about an hour so far and usually the overflow problem happens within a few mins). I will leave it on for a while longer and report back if any issues come up.
                • MichMichM
                  MichMich @MechMatt
                  @MechMatt good to hear!
                  • MichMichM
                    MichMich
                    @MechMatt: any news regarding the overflow. Is it solved?
                      MechMatt @MichMich
                      @MichMich Its been on for 24 hours and still looking good!
                      • MichMichM
                        MichMich
                        Thanks. I’ve closed the issue.
