    is there a way to control MMM-carousel with buttons?
    11 Posts 3 Posters 7.0k Views 3 Watching
    • X Offline
      xela
      My Mirror is almost ready but i’m stuck with a this issue: is there a way to control MMM-carousel with buttons?
      All I want to do is by pressing a short press on the switch it will move to the next slide and pressing a long press it will move to the previous slide.
      If some one can point me to the right direction it will be amazing.
      Thanks!
        cyberphox
        This thread might help:
        https://forum.magicmirror.builders/topic/7247/mmm-carousel-switching-slides-using-mmm-buttons
        • X Offline
          xela
          thank you! I read it before I posted and as the last comment said, it doesn’t work…
          Not sure what I’m doing wrong.
            shbatm Module Developer
            Which version of MMM-Carousel are you using? If you use this one: MMM-Carousel w/ Slide Navigation you can navigate left and right or jump to a particular slide by sending a notification from another module.
            Just pushed an update to make this even easier. See the details at the bottom of the README
            C X 2 Replies Last reply Reply Quote 1
              cyberphox @shbatm
              @shbatm cool! Now that I run MM from a Synology Docker I’ve lost my Voice navigation options with pages…but this might be cool to try and install some buttons!
              • X Offline
                xela @shbatm
                @shbatm wow! thank you very much! I will try it shortly.
                  @cyberphox - You may be interested in checking this out too: https://forum.magicmirror.builders/topic/9291/mmm-remote-control-v2-dev-extensible-rest-api-and-socket-communication-update
                    cyberphox @shbatm
                    @shbatm i bet your mirror is pretty cool! :) Thanks!
                    • X Offline
                      xela @shbatm
                      @shbatm thank you so much! It worked perfectly! Unfortunately I had to have a cancer prostate removal operation on Friday (which I’m recovering of now) but my mirror works exactly like I wanted with two buttons that control the “mirror mode”. First press is like the Samsung family hub, second press is my home assistant dashboard, third press is an art work slideshow with 49 beautiful artworks and forth press is just a clear mirror with time and compliments only. On to of that I’ve implemented the GassistPi voice operation and the PIR module.
                      I’m so happy!!! Thank you so much!
                      C S 2 Replies Last reply Reply Quote 0
                        cyberphox @xela
                        @xela here’s to a speedy recovery! would love to hear more of how you got it all working when i decide to tackle it in the new year and implement my slideshow and Home Assistant dashboard as well!
