    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.7k Views 6 Watching
    • A
      AxLed Module Developer
      Is the module now working or do you still have issues?
      AxLED
      • evroomE
        evroom
        Same issues.
        Do not see any services list, so can not play one.
        All apiXXX settings in the config file work when pasted in the browser.
        XML output is simular like yours.
        I only left apizap empty.
        Perhaps you could output some ‘landmarks’ in the MM log, like:
        About - okay / not okay
        Services - okay / not okay
        EPGNow - okay / not okay
        Zap - okay / not okay
        Servicelistplayable - okay / not okay
        omxplayer started
        MagicMirror version: 2.37.0
        • A
          @evroom
          1. You can try another git pull of the master branch and test, as I found some more errors in my code (if not all of the 5 requests are successful).
          2. You can try to delete the MMM-Dreambox folder an do git clone --branch debug https://github.com/Ax-LED/MMM-Dreambox.git.
            I made this debug branch for you, with a different node_helper.js, which no shows some ‘landmarks’ in PM2 logs.
          AxLED
          evroomE 1 Reply Last reply
          • Cr4z33C
            Cr4z33 @AxLed
            @axled maybe I am misunderstanding everything, but I need to understand whether it’s just a Dreambox information module or whether I can actually stream into an omxplayer iframe?
            If that is what it can do then all I see right now is some information (and by the way in German) about the current channel playing on the VU+:
                                             DREAMBOX
            Model Duo² - dezeit läuft: (Rai 3 HD)
            Nothing else.
            No streaming stuff going on. :smiling_face_with_open_mouth_smiling_eyes:
            Here’s my module config and yes I use a different port than 80 or 8080.
            			module: 'MMM-Dreambox',
            			header: 'Dreambox',
            			position: 'bottom_right',
            			disabled: false,
            				apiBase: 'http://*.*.*.*:**',
            				omxargs: ' --win 320,180,1600,900  -o both ',
            				refreshInterval: 1000 * 30, //refresh every 30 seconds
            				apiabout: '/web/about',
            				apiservices: '/web/getallservices',
            				apiepgnow: '/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet',
            				apizap: '/web/zap?sRef=',
            				apiTimerlist: '/web/timerlist',
            				apiServicelistplayable: '/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet'
            A 1 Reply Last reply
            • evroomE
              evroom @AxLed
              @AxLed
              1. Same result. No services list.
              2. Same result. No services list. But …
              0|mm  | Starting node helper for: MMM-Dreambox
              0|mm  | MMM-Dreambox: 1. Request EPGNOW succeeded.
              0|mm  | MMM-Dreambox: 2. Request ABOUT succeeded.
              0|mm  | MMM-Dreambox: 3. Request Services succeeded.
              0|mm  | MMM-Dreambox: 4. Request Timerlist succeeded.
              0|mm  | MMM-Dreambox: 5. Request Servicelistplayable succeeded.
              0|mm  | MMM-Dreambox: Notification FETCH_DATAreceived. New datas from dreambox should be pulled.
              So, we are getting somewhere :-)
              In the debug branch, could you perhaps send the playable services list to the MM log ?
              • evroomE
                evroom @evroom
                I see in your code that the HTML requests are successful (status code 200), so next step is to determine if the parsing was successful.
                I know how json parsing works using Perl, but in MM context I have no clue, so I am not much of help there.
                • A
                  AxLed Module Developer @Cr4z33
                  @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                  @Cr4z33
                  Its an entertainment module, means it show informations of your receiver and you can stream the channels with the omxplayer as overlay on your monitor (monitor must be local connected to pi). The displayed informations are needed to control the dreambox/receiver.
                  Your config looks ok.
                  Can you please answer following questions:
                  1. do you have timers in your receiver (can be checked by http://IPofyourReceiver/web/timerlist)?
                  2. what if you open MM in a browser in the same network and use F12. Are there any errors?
                  AxLED
                  • A
                    @evroom
                    I think we are getting closer to a working module.
                    The 5 requests are successful, so config should be ok.
                    3. Can you send me following 5 xml files: …/web/about, …/web/getallservices, …/web/timerlist, …/web/servicelistplayable, … /web/epgnow
                    After this i can modifiy the node_helper.js of development branch for further debugging.
                    AxLED
                    evroomE Cr4z33C 2 Replies Last reply
                    • evroomE
                      evroom @AxLed
                      @axled
                      1. Yes
                      2. Perhaps stupid, but do not how to do that. Cannot open MM using the MM IP.
                      3. Yes. Probably by pm.
                      evroomE A Cr4z33C 3 Replies Last reply
                      • evroomE
                        evroom @evroom
                        Can only upload pictures.
                        Do not see a pm option.
                        Hate it when you need to solve problems before you can solve problems.
                        • A
                          AxLed Module Developer @evroom
                          @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                          My MM config.js for IP looks like
                          config = {
                          	address: "192.168.56.101",
                          	port: 8080,
                          	ipWhitelist: [], // Set [] to allow all IP addresses
                          So can can open a browser in the same network and enter http://192.168.56.101:8080 to open MM in my browser. F12 shows a console where you can filter for errors.
                          Just send me the files by email ak10zeichen-xy@yahoo.de
                          AxLED
                          • Cr4z33C
                            Cr4z33 @AxLed
                            @AxLed
                            1. No timers are set right now.
                            2. Here is what it came out on the console running MM into Dev mode:
                            MMM-Dreambox.js:228 Uncaught TypeError: Cannot read property '0' of undefined
                                at Class.socketNotificationReceived (MMM-Dreambox.js:228)
                                at module.js:246
                                at r.<anonymous> (socketclient.js:25)
                                at r.emit (index.js:133)
                                at r.onevent (socket.js:270)
                                at r.MMSocket.self.socket.onevent (socketclient.js:19)
                                at r.onpacket (socket.js:228)
                                at r.<anonymous> (index.js:21)
                                at r.ondecoded (manager.js:345)
                            socketNotificationReceived @ MMM-Dreambox.js:228
                            (anonymous) @ module.js:246
                            (anonymous) @ socketclient.js:25
                            r.emit @ index.js:133
                            r.onevent @ socket.js:270
                            MMSocket.self.socket.onevent @ socketclient.js:19
                            r.onpacket @ socket.js:228
                            (anonymous) @ index.js:21
                            r.ondecoded @ manager.js:345
                            s.add @ index.js:241
                            r.ondata @ manager.js:335
                            r.onPacket @ socket.js:456
                            (anonymous) @ socket.js:273
                            r.onPacket @ transport.js:145
                            r.onData @ transport.js:137
                            ws.onmessage @ websocket.js:147
                            • Cr4z33C
                              Cr4z33 @evroom
                              1. Perhaps stupid, but do not how to do that. Cannot open MM using the MM IP.
                              Just run MM into DEV mode and in the right panel switch to the tab ‘Console’
                              cd ~/MagicMirror/
                              npm start dev
                              • A
                                Can you send me following 5 xml files: …/web/about, …/web/getallservices, …/web/timerlist, …/web/servicelistplayable, … /web/epgnow by email ak10zeichen-xy@yahoo.de
                                AxLED
                                Cr4z33C 1 Reply Last reply
                                • evroomE
                                  evroom @AxLed
                                  @axled
                                  Forgot the port.
                                  I see this error:
                                  TypeError: undefined is not an object (evaluating 'json.e2servicelistrecursive.e2bouquet.e2servicelist.e2service')
                                  In line 229 of MMM-Dreambox.js:
                                  this.sender = json.e2servicelistrecursive.e2bouquet.e2servicelist.e2service;
                                  Mailed you the files.
                                  • Cr4z33C
                                    Cr4z33 @AxLed
                                    @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                                    AxLED
                                    Me?
                                    • A
                                      @Cr4z33
                                      Yes.
                                      • Cr4z33C
                                        Cr4z33 @AxLed
                                        @axled OK gimme a minute and I send them. :winking_face:
                                        • evroomE
                                          evroom
                                          “You talking to me ?” (Robert de Niro - Taxi Driver).
                                          I sent the files, just in case.
                                          • A
                                            I sent the files
                                            @evroom
                                            Thanks for the files, i checked them and found an Error in MMM-Dreambox.js
                                            My “getallservices” xml only has one “bouquet”, so i checked only for one.
                                            As your “getallservices” xml has three “bouquets” i changed the code.
                                            If you do a git pull (master repository) it should work.
                                            So far i decided only to show the services/stations/channels of the first bouquet only, (userbouquet.favourites.tv) in your case.
                                            AxLED
                                            • 1 / 8
