    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 193.1k Views 6 Watching
    • Cr4z33C Offline
      Cr4z33 @AxLed
      @axled I put the IP and WebIf port of my Vu+ Duo², but then… how do I stream something? :smiling_face_with_smiling_eyes:
      I thought I was supposed to enter some M3U channel IPs or?
      • evroomE Offline
        evroom
        @AxLed
        I get “Modell: dm7020hd - dezeit läuft: (RTL7 HD)”, meaning that I did something right, but nothing streams; just a black box.
        Little Typo there, but German is difficult :-)
        The bRef and sRef give output in the browser, so that seems okay.
        When I use port 80, the MM log shows:
        0|mm  | Whoops! There was an uncaught exception...
        0|mm  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        0|mm  | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
        0|mm  | TypeError: Cannot read property 'code' of null
        0|mm  |     at Request._callback (/home/pi/MagicMirror/modules/MMM-Dreambox/node_helper.js:110:36)
        0|mm  |     at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
        0|mm  |     at emitTwo (events.js:126:13)
        0|mm  |     at Request.emit (events.js:214:7)
        0|mm  |     at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1161:10)
        0|mm  |     at emitOne (events.js:116:13)
        0|mm  |     at Request.emit (events.js:211:7)
        0|mm  |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1083:12)
        0|mm  |     at Object.onceWrapper (events.js:313:30)
        0|mm  |     at emitNone (events.js:111:20)
        Without port (URL only) I get:
        0|mm  | Starting node helper for: MMM-Dreambox
        But I do not see any stream nor a list of stations.
        pm2 list shows that no omxplayer stream is active.
        Can you tell me which parameters in the config are the most important and what I should see when I open those ‘personal’ URL’s in a browser ?
        MagicMirror version: 2.33.0
        Test environment:
        MagicMirror version: v2.33.0
          AxLed Module Developer @Cr4z33
          @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
          @Cr4z33
          In my case (Dreambox DM800se) i just entered the IP-Adress without port. You can crosscheck this with your browser: are you able to reach the webfrontend of your receiver with the IP-Adress you entered?
          The module works as follows (very short description): It reads the xml file of .../web/getallservices, build a list of the services and stations. The command DB-PLAY passes the selectede2servicereference to omxplayer.
          AxLED
            1. @evroom
            Thanks for your logs, i fixed the errorhandling and that typo.
            Please do a git pull now you should get detailed errors shown on the module in MM.
            2. How the module works (in the background).
            2.1 apiabout (About):
            Samplelink: http://dm800se.fritz.box/web/about
            I am reading two values, the model and what service is running (can be a station or playing a recorded movie).
            2.2 apiservices (Services):
            Samplelink: http://dm800se.fritz.box/web/getallservices
            I am reading all services (stations) of the receiver.
            Important: The part 1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet(your string might/will look different) is also needed for the parameters in config.js (apiServicelistplayable and apiepgnow).
            Sample:
            apiServicelistplayable: http://dm800se.fritz.box/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet
            apiepgnow: http://dm800se.fritz.box/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet
            3. apiTimerlist (Timerlist):
            Samplelink: http://dm800se.fritz.box/web/timerlist
            I am reading if any timers are active, so i can show it in the module.
            4. apiServicelistplayable (Servicelistplayable):
            Samplelink: http://dm800se.fritz.box/web/servicelistplayable?sRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet
            I am reading which stations are on the same bouquet, this is important, if any active timers are running. As timers have priority. All stations with the value false will be shown in a different css-style (gray and italic).
            Important: Check the following part with the one you get from http://dm800se.fritz.box/web/getallservices 1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM%20BOUQUET%20%22userbouquet.favourites.tv%22%20ORDER%20BY%20bouquet(your string might/will look different).
            5. apiepgnow (Epgnow):
            Samplelink: http://dm800se.fritz.box/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet
            I am reading the epg of my favorites (same source as servicelist), so i can write the beginning time and tite of the actual running program.
            Maybe this helps to find some configuration problems for the right link parameters.
            Regards
            AxLED
            • evroomE Offline
              evroom
              @AxLed
              So I guess we need to get a list displayed first, before sending the DB-PLAY command, right ?
              I have set “apiBase: ‘http://192.168.178.28’,” in the config, but it only shows the channel that is currently running on my box.
              No error in pm2 logs, just the “Starting node helper for: MMM-Dreambox”.
              The URL http://192.168.178.28/web/getallservices gives a list in XML style.
              (the code button </> does not work here)
              This XML file does not appear to have any style information associated with it. The document tree is shown below.
              1:7:1:0:0:0:0:0:0:0:FROM BOUQUET “userbouquet.favourites.tv” ORDER BY bouquet
              etc, etc, etc.
              Test environment:
                @evroom
                to your 1st question: yes we need a list displayed and selected one entry first, otherwise DB-PLAY wont work.
                Tipp: To insert xml code in the forum, you have to replace < by (& # 6 0 ; ) without spaces and > by (& # 6 2 ; ) without spaces.
                to your 2nd question: that http://192.168.178.28/web/getallservices is returning an xml file (if viewed in browser) is good.
                1. Question: Did you make a git pull, as i had some error in my errorhandling. If not, do git pull in the MMM-Dreambox folder first.
                2. Question: What is the xml showing under
                &#60;e2timerlist&#62;
                 &#60;e2timer&#62;
                  &#60;e2servicereference&#62;&#60;/e2servicereference&#62;
                1. Question: Same xml file, are there entries following (like my screenshot above?):
                &#60;e2servicelist&#62;
                 &#60;e2service&#62;
                AxLED
                • evroomE Offline
                  evroom
                  @AxLed
                  1. Just did. No (visible) changes.
                  2. All my timed programs. Exactly like in your example.
                  3.All my bouquets with the services in it. Like in your example.
                  We have simular Dreamboxes, so simular output.
                  I have 3 bouquets (Favourites (TV), Nederland (TV), Duitsland (TV))
                  I use WebControl Dreambox (via the DM IP) to control the box.
                  Unfortunate your tip with (& # 6 0 ; ) and (& # 6 2 ; ) is not working for me; it deletes everything between < and >:
                  That is a major flaw of this forum, besides not really being iPad friendly.
                  Test environment:
                    Is the module now working or do you still have issues?
                    AxLED
                    • evroomE Offline
                      evroom
                      Same issues.
                      Do not see any services list, so can not play one.
                      All apiXXX settings in the config file work when pasted in the browser.
                      XML output is simular like yours.
                      I only left apizap empty.
                      Perhaps you could output some ‘landmarks’ in the MM log, like:
                      About - okay / not okay
                      Services - okay / not okay
                      EPGNow - okay / not okay
                      Zap - okay / not okay
                      Servicelistplayable - okay / not okay
                      omxplayer started
                      Test environment:
                        @evroom
                        1. You can try another git pull of the master branch and test, as I found some more errors in my code (if not all of the 5 requests are successful).
                        2. You can try to delete the MMM-Dreambox folder an do git clone --branch debug https://github.com/Ax-LED/MMM-Dreambox.git.
                          I made this debug branch for you, with a different node_helper.js, which no shows some ‘landmarks’ in PM2 logs.
                        AxLED
                        • 15
                        • 16
                        • 1 / 16
