Troubles updating to 2.6.0
I ran into troubles when updating to 2.6.0, before on 2.5.0 everything worked fine.
I get errors when update with git pull && npm install, below the npm debug_log
0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ] 2 info using npm@1.4.21 3 info using node@v8.11.1 4 verbose run-script [ 'prestart', 'start', 'poststart' ] 5 info prestart magicmirror@2.6.0 6 info start magicmirror@2.6.0 7 verbose unsafe-perm in lifecycle true 8 info magicmirror@2.6.0 Failed to exec start script 9 error magicmirror@2.6.0 start: `sh run-start.sh` 9 error Exit status 127 10 error Failed at the magicmirror@2.6.0 start script. 10 error This is most likely a problem with the magicmirror package, 10 error not with npm itself. 10 error Tell the author that this fails on your system: 10 error sh run-start.sh 10 error You can get their info via: 10 error npm owner ls magicmirror 10 error There is likely additional logging output above. 11 error System Linux 4.14.90-v7+ 12 error command "/usr/bin/node" "/usr/bin/npm" "start" 13 error cwd /home/pi/MagicMirror 14 error node -v v8.11.1 15 error npm -v 1.4.21 16 error code ELIFECYCLE 17 verbose exit [ 1, true ]when I manually try to start via npm start it states that
> magicmirror@2.6.0 start /home/pi/MagicMirror > sh run-start.sh run-start.sh: 4: run-start.sh: electron: not foundso I tried to install/update electon but had no luck
npm ERR! Error: Method Not Allowed npm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10) npm ERR! at /usr/share/npm/lib/cache/add-named.js:203:12 npm ERR! at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7) npm ERR! at FSReqWrap.oncomplete (fs.js:135:15) npm ERR! If you need help, you may report this *entire* log, npm ERR! including the npm and node versions, at: npm ERR! <http://github.com/npm/npm/issues> npm ERR! System Linux 4.14.90-v7+ npm ERR! command "/usr/bin/node" "/usr/bin/npm" "i" "electron" npm ERR! cwd /home/pi/MagicMirror npm ERR! node -v v8.11.1 npm ERR! npm -v 1.4.21 npm ERR! code E405 npm ERR! npm ERR! Additional logging details can be found in: npm ERR! /home/pi/MagicMirror/npm-debug.log npm ERR! not ok code 0what am I missing?
Your version of
npmis way too old - install the latest version through the terminal:
sudo npm install -g npm -
@azuettel - What command did you use to update Electron?
@azuettel u are running a very old version of npm, 1.x
Should be v 6 at least.
Your version of
npm install electron@latest
