    MMM-awesome-alexa snowboy issue
    9 Posts 3 Posters 2.8k Views 2 Watching
      Radu_Stancu
      Hi, I`m trying to install awesome-alexa but when I try to run the electron rebuild I get a huge error list…
      I updated electron, node-abi, every single thing that could be updated, ran npm audit-fix and still nothing.
      Here is the output:
      An unhandled error occurred inside electron-rebuild
      make: Entering directory ‘/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build’
      CXX(target) Release/obj.target/snowboy/swig/Node/snowboy.o
      In file included from …/…/nan/nan.h:192:0,
      from …/swig/Node/snowboy.cc:1:
      …/…/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe Nan::ForceSet(v8::Localv8::Object, v8::Localv8::Value, v8::Localv8::Value, v8::PropertyAttribute)’:
      …/…/nan/nan_maybe_43_inl.h:112:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
      return obj->ForceSet(isolate->GetCurrentContext(), key, value, attribs);
      In file included from …/swig/Node/snowboy.cc:1:0:
      …/…/nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value)’:
      …/…/nan/nan.h:835:60: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
      , v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]
      v8::Isolate::GetCurrent(), target, func, argc, argv);
      In file included from /home/linaro/.electron-gyp/.node-gyp/iojs-3.0.11/src/node.h:53:0,
      from …/…/nan/nan.h:49,
      /home/linaro/.electron-gyp/.node-gyp/iojs-3.0.11/src/node.h:94:50: note: declared here
      NODE_EXTERN v8::Localv8::Value MakeCallback(
      /home/linaro/.electron-gyp/.node-gyp/iojs-3.0.11/src/core.h:35:42: note: in definition of macro ‘NODE_DEPRECATED’
      attribute((deprecated(message))) declarator
      …/…/nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value
      …/…/nan/nan.h:850:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate*, v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]
      v8::Isolate::GetCurrent(), target, symbol, argc, argv);
      /home/linaro/.electron-gyp/.node-gyp/iojs-3.0.11/src/node.h:87:50: note: declared here
      …/…/nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, const char
      …/…/nan/nan.h:865:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
      , v8::Localv8::Object, const char*, int, v8::Localv8::Value)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]
      v8::Isolate::GetCurrent(), target, method, argc, argv);
      /home/linaro/.electron-gyp/.node-gyp/iojs-3.0.11/src/node.h:80:50: note: declared here
      …/…/nan/nan.h: In member function ‘v8::Localv8::Value Nan::Callback::Call_(v8::Isolate
      , v8::Localv8::Object, int, v8::Localv8::Value) const’:
      …/…/nan/nan.h:1479:5: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate
      , v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(…, async_context) [-Wdeprecated-declarations]
      snowboy.target.mk:107: recipe for target ‘Release/obj.target/snowboy/swig/Node/snowboy.o’ failed
      make: Leaving directory ‘/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build’
      make: *** [Release/obj.target/snowboy/swig/Node/snowboy.o] Error 1
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/node-gyp/lib/build.js:262:23)
      gyp ERR! stack at ChildProcess.emit (events.js:180:13)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:12)
      gyp ERR! System Linux 4.4.132+
      gyp ERR! command “/usr/bin/node” “/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/.bin/node-gyp” “rebuild” “–target=3.0.11” “–arch=arm” “–dist-url=https://atom.io/download/electron” “–build-from-source” “–module_name=snowboy” “–module_path=/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/lib/node/binding/Release/electron-v3.0-linux-arm” “–remote_path=./snowboy/v1.2.0/Release/” “–package_name=snowboy-v1.2.0-electron-v3.0-linux-arm.tar.gz” “–host=https://snowboy-release-node.s3-us-west-2.amazonaws.com”
      gyp ERR! cwd /home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy
      gyp ERR! node -v v9.11.2
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      Failed with exit code: 1
      Error: make: Entering directory ‘/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/snowboy/build’
      gyp ERR! not ok
      at SafeSubscriber._error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/spawn-rx/lib/src/index.js:277:84)
      at SafeSubscriber.__tryOrUnsub (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:238:16)
      at SafeSubscriber.error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:197:26)
      at Subscriber._error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:128:26)
      at Subscriber.error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:102:18)
      at MapSubscriber.Subscriber._error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:128:26)
      at MapSubscriber.Subscriber.error (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:102:18)
      at SafeSubscriber._next (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/spawn-rx/lib/src/index.js:251:65)
      at SafeSubscriber.__tryOrSetError (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:247:16)
      at SafeSubscriber.next (/home/linaro/MagicMirror/modules/MMM-awesome-alexa/node_modules/rxjs/Subscriber.js:187:27)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 255
      npm ERR! mmm-awesome-alexa@1.0.0 electron-rebuild: electron-rebuild --pre-gyp-fix
      npm ERR! Exit status 255
      npm ERR!
      npm ERR! Failed at the mmm-awesome-alexa@1.0.0 electron-rebuild script.
      npm ERR! /home/linaro/.npm/_logs/2018-12-13T13_18_01_671Z-debug.log
      If anybody else has encountered this and knows what to do, please help.
      Thanks.
        MattSharp
        I’ve got the same issue currently, no idea what’s causing it and I’ve been searching all over.
        M 1 Reply Last reply
          MattSharp @MattSharp
          @mattsharp said in MMM-awesome-alexa snowboy issue:
          I take that back, I just tried an npm update electron-rebuild and then npm run electron-rebuild and it seems to have worked! give that a try and let me know if it helped
          R 1 Reply Last reply
            Radu_Stancu @MattSharp
            @mattsharp Thanks for trying, I will try soon enough, I have tried the google assistant module, but I`ll probably return to alexa soon.
              MattSharp @Radu_Stancu
              @radu_stancu I still can’t seem to get it to work tbf, think I’ll try starting again with version 2.6.0
                @mattsharp I`m kind of reluctant to update to 2.6.0 so I do not mess anything. I have modified quite a lot of config files and custom css. This is my college project and I have to present in a few months. The google assistant is working decently, although I was hoping for better, I will have to stick with it until this issue with electron is fixed.
                  @radu_stancu Starting fresh with 2.6.0 now, I’ll let you know how it goes, fingers crossed haha
                    @mattsharp Thanks mate. I moved to MirrorMirroronthewall and almost got it working flawlessy. So don`t worry too much.
                      bhepler Module Developer
                      Please use the Markdown features of the board when posting code.
