    newsfeed gives an error
    newsfeed parser error
    6 Posts 2 Posters 4.3k Views 2 Watching
    • O
      ostfilinchen
      Hi all,
      i get an error with the newsfeed modul. I look in the logfile with ‘pm2 logs’ and i see this error:
      mm-0 Get league table for url http://api.football-data.org/v1/competitions/430/leagueTable
      mm-0 Can't parse feed item:
      mm-0 { text: '\n\n\n\n\n\n',
      mm-0   title: '',
      mm-0   link: { href: 'http://www.tagesschau.de' },
      mm-0   id: 'http://www.tagesschau.de',
      mm-0   updated: '',
      mm-0   summary: '' }
      mm-0 Title:
      mm-0 Description:
      mm-0 Pubdate:
      mm-0 Whoops! There was an uncaught exception...
      mm-0 TypeError: parser.close is not a function
      mm-0     at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
      mm-0     at emitOne (events.js:96:13)
      mm-0     at SAXStream.emit (events.js:188:7)
      mm-0     at Object.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
      mm-0     at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:640:35)
      mm-0     at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:645:5)
      mm-0     at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:841:5)
      mm-0     at Object.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1404:13)
      mm-0     at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
      mm-0     at yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
      mm-0 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      mm-0 If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      A few lines is the fact that the system is deprecated.
      Had any one else these Errors?
      Best regards
      Daniel
        bobbob601
        • O
          ostfilinchen
          I don’t think the error Comes from the Soccer module. Here is the new log from pm2:
          mm-0 starting internet monitor node helper
          mm-0 Create new news fetcher for url: http://www.heise.de/security/news/news-top-atom.xml - Interval: 300000
          mm-0 Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
            bobbob601
            • O
              ostfilinchen
              oh thanks… heise produce the error… :-(
                bobbob601
