    newsfeed gives an error
    newsfeed parser error
    6 Posts 2 Posters 4.0k Views 2 Watching
      bobbob601
      • O Offline
        ostfilinchen
        I don’t think the error Comes from the Soccer module. Here is the new log from pm2:
        mm-0 starting internet monitor node helper
        mm-0 Create new news fetcher for url: http://www.heise.de/security/news/news-top-atom.xml - Interval: 300000
        mm-0 Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
        mm-0 Whoops! There was an uncaught exception...
        mm-0 TypeError: parser.close is not a function
        mm-0     at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
        mm-0     at emitOne (events.js:96:13)
        mm-0     at SAXStream.emit (events.js:188:7)
        mm-0     at Object.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
        mm-0     at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:640:35)
        mm-0     at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:645:5)
        mm-0     at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:841:5)
        mm-0     at Object.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1404:13)
        mm-0     at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
        mm-0     at yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
        mm-0 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        mm-0 If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          bobbob601
          • O Offline
            ostfilinchen
            oh thanks… heise produce the error… :-(
              bobbob601
