newsfeed gives an error
newsfeed parser error
6 Posts 2 Posters 3.6k Views 2 Watching
  • O Offline
    ostfilinchen
    Hi all,
    i get an error with the newsfeed modul. I look in the logfile with ‘pm2 logs’ and i see this error:
    mm-0 Get league table for url http://api.football-data.org/v1/competitions/430/leagueTable
    mm-0 Can't parse feed item:
    mm-0 { text: '\n\n\n\n\n\n',
    mm-0   title: '',
    mm-0   link: { href: 'http://www.tagesschau.de' },
    mm-0   id: 'http://www.tagesschau.de',
    mm-0   updated: '',
    mm-0   summary: '' }
    mm-0 Title:
    mm-0 Description:
    mm-0 Pubdate:
    mm-0 Whoops! There was an uncaught exception...
    mm-0 TypeError: parser.close is not a function
    mm-0     at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
    mm-0     at emitOne (events.js:96:13)
    mm-0     at SAXStream.emit (events.js:188:7)
    mm-0     at Object.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
    mm-0     at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:640:35)
    mm-0     at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:645:5)
    mm-0     at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:841:5)
    mm-0     at Object.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1404:13)
    mm-0     at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
    mm-0     at yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
    mm-0 MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
    mm-0 If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
    A few lines is the fact that the system is deprecated.
    Had any one else these Errors?
    Best regards
    Daniel
      bobbob601
      • O Offline
        ostfilinchen
        I don’t think the error Comes from the Soccer module. Here is the new log from pm2:
        mm-0 starting internet monitor node helper
        mm-0 Create new news fetcher for url: http://www.heise.de/security/news/news-top-atom.xml - Interval: 300000
        mm-0 Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
          bobbob601
          • O Offline
            ostfilinchen
            oh thanks… heise produce the error… :-(
              bobbob601
