    [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server
    47 Posts 17 Posters 37.0k Views 18 Watching
    • citizendevpiC Offline
      citizendevpi
        citizendevpi
        Any help
          shbatm Module Developer @citizendevpi
          @citizendevpi said in [octomirror-module] Monitor & Control an OctoPrint 3D Printer Server:
          Any help
          Sorry, I haven’t had a chance to fire up my printer and take a look yet. Going to try in the next few days. They’ve probably updated something in Octoprint that broke it.
          One thing I did think of to have you check on: make sure you have Allow CORS turned on in your Octoprint settings.
            @michael24h @citizendevpi Please update the module to the latest version and give it a try.
            Short version: OctoPrint changed the way the API login works.
            Long version: The new bundled OctoPrint plugin ForceLogin now requires the API to get a session ID and send it back to the socket before it will send any detailed messages. Detailed here and here.
            citizendevpiC 1 Reply Last reply Reply Quote 0
              citizendevpi @shbatm
              @shbatm so how do i fix it? add some more info in config or ???
                how do i fix it?
                Update the module. You shouldn’t need to add anything else.
                cd ~/MagicMirror/modules/octomirror-module
                git fetch
                git pull
                  SEMPL3X
                  Hey @shbatm Thanks for the module! It is soo great! But i have one question. When the Printer and Octoprint is Offline, but my MM runs, it is offline ok but when i start the Printer and octoprint it says in MM that the printer is offline. How can i fix that ? :) Hope u see this :D
                    jay.j.flynn
                    Is there a way to hide the module when the printer is offline?
                    TheMysticleT M 2 Replies Last reply Reply Quote 0
                    • TheMysticleT Offline
                      TheMysticle @jay.j.flynn
                      @jay-j-flynn Hi if you still have this running did you actually get it to work? I can’t get mine to display anything. It’s like it doesn’t connect to octopi.
                      • FoziF Offline
                        Fozi Project Sponsor @TheMysticle
                        @TheMysticle First I also couldn’t make the module work until I did the following:
                        1. Entered in config.js the IP-address of the RPi OctoPrint runs on
                        2. Enter the API key without any brackets (the ReadMe.md was a bit misleading)
                        My config looks like this:
                                module: "octomirror-module",
                                position: "middle_center",
                                    url: "http://192.168.0.123",
                                    printerName: "Ender 3 Pro",
                                    interactive: false, // Set to false to hide the file drop down and only show the stream.
                                    api_key: "1234567890ABCDEFGHI"
                        • 3 / 5
