    syntax errors
    11 Posts 5 Posters 3.9k Views 5 Watching
    • G Offline
      ganget
      Heey i just check your config file and found that there are some differences compared to the config in the readme file. Something i noticed is to check if there is a }, after each { . Example
        module: "MMM-AssistantMk2",
      deviceLocation: {
            coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
              latitude: 45.200049, // -90.0 - +90.0
              longitude: 7.568917, // -180.0 - +180.0
      there is twice }, at the end to close both the {
      Can you check for me if this works?
          // --- ESSENTIALS / modifying for your environment might be needed.
          deviceLocation: {
          defaultProfile: "default", // If you have several profiles and want to set one of them as default profile, describe here.
          profiles: {
            "default" : { // profile name.
              profileFile: "default.json", // profile file name.
              lang: "it-IT"
              //currently available (estimation, not all tested):
              //  de-DE, en-AU, en-CA, en-GB, en-US, en-IN
              // fr-CA, fr-FR, it-IT, ja-JP, es-ES, es-MX, ko-KR, pt-BR
              // https://developers.google.com/assistant/sdk/reference/rpc/languages
          record: { // Full values are in `FOR EXPERTS` section.
            recordProgram: "arecord",  // Defaults to "arecord" - also supports "rec" and "sox"
            device: null        // recording device (e.g.: "plughw:1")
          play: { // Full values are in `FOR EXPERTS` section.
            playProgram: "mpg321", // recommended.
      E 1 Reply Last reply Reply Quote 2
      • E Offline
        Egnos @ganget
        Sorry @ganget, but I’m not sure that the configuration you propose can work, because after opening a “{” is closed with a “},” and the “},” is used only for the closure of the entire module and not the single configurations. Correct?
        Is it possible that the problem is on the comma after “mpg321”?
        Thank you all!
          from the MM folder run
          node tests/configs/check_config.js
          find and fix all errors, starting from the top of the list
          • yawnsY Offline
            yawns Moderator
            @ganget is right, your { } are mixed up.
            This passes the test on jshint.com
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            		    deviceLocation: {
            			profiles: {
            				lang: "it-IT",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			header: "US Holidays",
            						symbol: "calendar-check-o ",
            			module: "compliments",
            			position: "lower_third"
            			module: "currentweather",
            				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
            			module: "weatherforecast",
            			header: "Weather Forecast",
            				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "New York Times",
            				showSourceTitle: true,
            				showPublishDate: true
            Also, if you look at the readme for this module configuration you notice the { } need to be set different.
            • E Offline
              Egnos @sdetweil
              @sdetweil said in syntax errors:
              Thanks, as soon possible I will try this command.
              Ok thanks @ganget, but I do not understand why if I remove the comma of the “}” referring to “play” the configuration does not give problems but if I remove the comma from the “}” referring to “record” it goes into error…
              Sorry for the banalities … but I’m a beginner.:smiling_face_with_open_mouth_cold_sweat:
              S G 2 Replies Last reply Reply Quote 0
                sdetweil @Egnos
                @egnos comma is continuation… its ok to have an EXTRA , after the play group,… it is NOT ok to have a missing , between things
                • G Offline
                  ganget @Egnos
                  @egnos As @sdetweil already stated the comma’s are for showing the code that there is more to run after the line. It is no problem to have a extra comma at the end. But if you don’t put a comma the code doesn’t run further and gives you a syntax error. The {} are for making a object in JS, if you don’t close the object with a } you will also get a syntax error.
