    worldclock - nobody made this, so I did.
    46 Posts 14 Posters 35.3k Views 14 Watching
    • A
      Arjen_lima
      Hi There,
      just starting out with MM and i like the module a lot.
      one question i have is how to organize the clock’s in row instead of one below the other.
      thanks
      Arjen
      ? 1 Reply Last reply
        A Former User @Arjen_lima
        @Arjen_lima
        Sorry for my English, I cannot catch your question.
        The order of clocks is defined in config.js by the section clocks, that is the array of clock, then the order of display is same with the order of array element.
        Or… If you mean another problem, give me more detailed information. Of course, an image could be the great help for understanding.
        A 1 Reply Last reply
        • A
          Arjen_lima @Guest
          @Sean said in worldclock - nobody made this, so I did.:
          @Arjen_lima
          Hey Sean,
          Its probably my english ;-),
          now the clocks in the array are all vertically aligned one clock below the next clock.
          in some of the screen shots they are in a 3x3 grid i was wondering how to get it like that
          my current lay out
          the lay out im looking for
            @Arjen_lima
            Sorry for the confusion. that image was just sample of the different layout configuration. That was not real, it was photoshopped.
              Peter
              Can somebody help me to change the font size of this module?
              I would like to have the time a little smaller; about the same as the size of the citynames.
              Thanks.
              Peter
              N 1 Reply Last reply
              • N
                ninjabreadman @Peter
                @Peter This should work:
                .worldclock {
                  font-size: 73%; /* adjust value as needed */
                P 1 Reply Last reply
                  Peter @ninjabreadman
                  @ninjabreadman thanks!
                  It works fine.
                  Peter
                    cookblook
                    very nice module. Is it possible to have the clocks horizontal instead of vertical?
                      A Former User @cookblook
                      @cookblook
                      You can redefine CSS of .worldclockand.worldclock .world to arrange horizontally with flex things of CSS3.
                      C 1 Reply Last reply
                        cookblook @Guest
                        @sean like display: flex;? tried that but it didn’t work
                          @cookblook
                          This will work, add this into your css/custom.css
                          .worldtime {
                            display:flex;
                            flex-direction:row;
                          .world{
                            width:200px;
                            cookblook
                            @sean Thanks!! That worked :-)
                            • BKeyportB
                              BKeyport Module Developer
                              Ulrich/Sean -
                              I’ve got a bug - supposedly it’s supposed to allow override of the time format per clock. I’m trying to get a 24 hour clock only on the UTC clock. “LT” is “hh:mm A” here…
                              Thanks!
                               module: "worldclock",
                               timeFormat: "LT", style: "left",
                               offsetTimezone: null,
                               clocks: [
                               title: "Local",
                               timezone: "America/Los_Angeles",
                               title: "UTC",
                               timezone: "UTC",
                               timeFormat: "HH:mm",
                              Thanks!
                              BKeyportB 1 Reply Last reply
                              • L
                                Lagmin
                                • BKeyportB
                                  I solved this. My fork is http://www.github.com/bkeyport/MMM-Worldclock if you’d like to use it. It’ll be fully supported, and I don’t plan to merge back into the original.
                                  • A
                                    alanodoug
                                    Hey guys,
                                    is it possible to change the flag-icon? Because the flag i want to use doesnt exist.
                                    Maybe i can use a image and put it in the folder?
                                    Thx
                                    • BKeyportB
                                      No. The flags are hardcoded. I’m trying to figure out how it works, because I want to use a flag for UTC, which don’t have one either.
                                      I’m about halfway there. I’ve figured out how to do everything but get the replacement flag into the right spot. It’ll display, but it’s not showing up at the right spot. Still crunching, will look more when time permits. . :|
                                      • BKeyportB
                                        @alanodoug said in worldclock - nobody made this, so I did.:
                                        Hey guys,
                                        I’ve added the functionality to MMM-Worldclock. The supported version™
                                        It’s not perfect, but it’s there.
                                        Is created by:
                                        			module: "MMM-Worldclock",
                                        				style: "right",
                                        				clocks: [
                                        						title: "Local",
                                        						altflag: "washington.png",
                                        						timeFormat: "hh:mm:ss a",
                                        						title: "ET",
                                        						timezone: "America/New_York",
                                        						flag: "us",
                                        						timeFormat: "hha MM/DD",
                                        						title: "CT",
                                        						timezone: "America/Chicago",
                                        						flag: "us",
                                        						title: "MT",
                                        						timezone: "America/Boise",
                                        						flag: "us",
                                        						title: "AK",
                                        						timezone: "America/Anchorage",
                                        						flag: "us",
                                        						title: "HI",
                                        						timezone: "Pacific/Honolulu",
                                        						flag: "us",
                                        						title: "UTC",
                                        						timezone: "UTC",
                                        						timeFormat: "HH:mm MM/DD",
                                        						altflag: "world.jpg"
                                        the module is located at http://www.github.com/BKeyport/MMM-Worldclock
                                        Cheers!
                                        I really need someone to help me with the CSS buildout. I’m not understanding how to get the icons down to the same size as the normal flags, and other little ticky stuff.
                                        What I added was “altflag” in the code, and based it off of what Sean did originally.
                                        The combo of JS and CSS is maddening me.
                                        • A
                                          alanodoug
                                          Oh cool, that looks good.
                                          is it not possible to create a custom css. Because in the worldclock.js is the link to the flags
                                          loadCSS: function() {
                                              var css = [
                                                  href: 'https://cdnjs.cloudflare.com/ajax/libs/flag-icon-css/2.8.0/css/flag-icon.min.css'
                                          and there are a lot of flags, wich I can change it maybe?
                                          But I cant find the svg.
                                          Maybe someone can help?
                                          Thanks a lot.
                                          • BKeyportB
                                            Those SVGs are for the built in flags. I figured it would be “download and place the file in the module directory” for the custom flags… Like I have “world.jpg” and “washington.png” (or is it the other way).
                                            Just make sure the flag image is square, and use “altflag” rather than “flag” with the filename of the image file, and it’ll pick it up.
                                            (the requirements are hopefully temporary for the alternate flag image, I’m working on learning CSS in my spare time, and how to fix the image insert later)
                                            • 2 / 3
